6 Replies Latest reply on May 30, 2007 6:26 AM by Newsgroup_User
    shorten this code?
    chrisatflash Level 1
      Hello,
      I am trying to make this work ..
      I have this code:
      ball.onRollOver = function() {
      movie_mc.gotoandStop("ball");
      ball.gotoAndPlay(2);
      red.onRollOver = function() {
      movie_mc.gotoAndStop("red");
      red.gotoAndPlay(2);
      and so on.. like 20 times..
      So i thought maybe this code can be shorten this way:
      function shortcode(test) {
      movie_mc.gotoAndStop(test);
      test.gotoAndPlay(2);
      ball.onRollOver = shortcode(ball);
      but this does not seem to work..
      Does anyone see what goes wrong?
      Regards,
      Micheal.
        • 1. Re: shorten this code
          Level 7
          Michealnl wrote:
          > Hello,
          This does not work. You would have to reference test as array element.
          Like this:
          this._parent[test].gotoAndPlay(2);
          But ...
          This doesn't work too. You can't put function parameter on an event. If
          ball is a movieclip you can use the clipname and try this:
          this._parent[this._name].gotoAndPlay(2);
          But easier than this you could just try this ..
          this.gotoAndPlay(2);
          .. instead of referencing to itself by name.
          • 2. Re: shorten this code?
            so it's not possiblee to try a function parameter on an event?
            Is there another way then to apply more actions like in my example
            function on a onRollOver event and to pass a parameter so
            i don't have to type every function repeatedly?
            • 3. Re: shorten this code?
              nITiNkIlLeRmEeRuT
              try this
              • 4. Re: shorten this code
                Level 7
                You're thinking is close to what you want, but you need to do something like
                so:
                var shortcode = function(){
                movie_mc.gotoAndStop(this._name);
                ball.onRollOver = shortcode;
                red.onRollOver = shortcode;
                You have to assign a function to the event handlers. However, as you have 20
                of them I'd probably do it with an array, as the prior responder said.
                Dave -
                Head Developer
                http://www.blurredistinction.com
                Adobe Community Expert
                http://www.adobe.com/communities/experts/
                • 5. Re: shorten this code?
                  Level 7
                  no.
                  Another way or workaround when you want to pass a parameter to an event
                  it to put a varaible set a variable on the clip. So if you have a loop
                  where you set the event-script of a clip you would do it like this.
                  Let's say you have 20 Balls (named "ball1_mc", "ball2_mc" ..)
                  fx = functon(){
                  // "this" would be the movieclip you put the script on
                  trace("this is Ball No. " + this.myID)
                  for (n=1;n<=20;n++){
                  _level0["ball" + n + "_mc"].myID = n;
                  _level0["ball" + n + "_mc"].onRollOver = fx;
                  But this won't work for buttons. Because buttons can't cary a value,
                  afaik. You would have to put a button in a clip to work with buttons.
                  • 6. Re: shorten this code?
                    Thanks guys! This works great! It saves me a lot of typing in actionscript!
                    Regards
                    Micheal.
