1 Reply Latest reply on May 30, 2007 10:15 PM by TimmyTears
    Dynamic Chart
    Brauliori
      Hello..
      Exists a way of doing a dynamical graph in his axis X and Y ?
      For example:
      <mx:BarSeries yField="type" xField="s18"/>
      but with yField and xField dynamic
        • 1. Re: Dynamic Chart
          TimmyTears
          Not sure if I fully understand your question but if you mean dynamic scaling then most definitely. Make sure baseAtZero property is set to false and that the minimum and maximum values of your axis renderers are set to NaN. The min and max should already be defaulted to NaN and you should only need to set baseAtZero property.
          Hope this helps
