7 Replies Latest reply on Mar 31, 2014 11:47 AM by Donny Bradfield
    Help needed in getting my Alesis Multimix Firewire 16 to work with Audition CS6
    Donny Bradfield
      I've just bought a new Fujitsu AH 532 Lifebook Laptop with a Windows 8, 64 bit OS. I've installed my Adobe Audition CS6 on it and I've connected my Alesis Multimix 16 Firewire to it via my StarTech 34mm Firewire Express Card which has a Texas Instrument Chipset. AA CS6 sees the mixer but only allows a stereo track input but it also does not want to record. I've attached some images of the audio channel mapping, audio hardware setup, and also the multitrack recording view. Also I'm using the Alesis Windows 7 driver for the mixer. You will also see that I cannot select the sample rate in the audio hardware setup panel, the sample rate is stuck on zero. In the multitrack view there's no signal when I press the record button.
      All suggestions and help will be highly appreciated.
      Regards,
      Donovan.
