1 Reply Latest reply on May 25, 2007 2:53 AM by cpgenius
    Add Sound
      much appreciated!
        • 1. Re: Add Sound
          cpgenius Level 1
          Easiest method is to add the sound to your library and then drag and drop it on your stage. As long as there are as many frames as the long as the duration of the sound, then you'll see it in the timeline represented by a wave form.
          If you're looking to load it dynamically, you'll need to look into attachSound or loadSound. Try looking up sound in the help file and you'll find plenty of examples in the Learning Actionscript section.
          http://www.kirupa.com/developer/actionscript/sound.htm might help get you started as well.
