3 Replies Latest reply on Mar 31, 2014 1:03 AM by CarlosCanto
    Changing the text in a scriptUI window
    Franck Payen MVP & Adobe Community Professional
      I'm sure it's trivial, but i cannot get it.
      I've got his window displaying my document's name and a button that triggers an action (init)
      When going to another illustrator document, since my init action checks the document's name, i'd love the script window to display the right name to avoid confusion.
      I know how to build a dialogue, but i don't know how to update part of it (let's say a statictext)
      see the code here, doing nothing but alert(doctitle) on click :
      /*jslint vars: true, plusplus: true, devel: true, nomen: true, regexp: true, indent: 4, maxerr: 50 */
      /*global $, Folder*/
      Script Test
      Par Franck Payen mars 2014
      http://fr32c.free.fr
      var doc; // document actif
      var docTitle; // titre du document actif
      function displayUI() {
          var dialogue = new Window ("palette", "Afficher les calques ", undefined, {closeButton:true, resizeable: true});
          dialogue.orientation = "column";
          dialogue.alignChildren = "fill";
          dialogue.margins = 10;
          dialogue.location = [0,40];
          dialogue.preferredsize = [200, 400];
          // onResize needed on Mac OS X
          dialogue.onResizing = dialogue.onResize = function () {this.layout.resize ();}
          var groupe0 = dialogue.add ("group", undefined);
          groupe0.orientation = "column";
          groupe0.alignChildren = "fill";
          var monDocTitle = groupe0.add ("statictext", undefined, docTitle);
          var groupe2 = dialogue.add ("group", undefined);
          groupe2.orientation = "column";
          groupe2.alignChildren = "fill";
          var boutonInit = groupe2.add ("button", undefined, "Reinitialiser");
          boutonInit.onClick = function (){
              var messageBT = new BridgeTalk();
              messageBT.target = "illustrator";
              var messageBTcorps = "initScript()";
              messageBT.body = messageBTcorps;
              messageBT.send();
           dialogue.onClose = function (){
              dialogue.hide();
          //alert (dialogue); //will work and return [object Window]
          dialogue.show();
      function initScript(){
          if (app.documents.length == 0){
              alert("Merci d'ouvrir un document avant de lancer ce script.\nL'opération a été interrompue.", "Pas de document ouvert");
              return;
          doc = app.activeDocument;
          docTitle = app.activeDocument.name.split(".")[0];
          alert(docTitle);
          //alert (dialogue); //won't work and refuse to launch the script
      //    displayUI(); // v1, lance le display après l'initialisation. Scindé pour utiliser le bouton réinitialiser.
      #target Illustrator
      #targetengine main
      var versionAi = new Number (app.version.slice (0,2));
      if (versionAi > 12){
          initScript();
          displayUI();
      else
      if (versionAi < 13){
         alert("Ce script n'es pas compatible avec Illustrator CS2 ou des versions plus anciennes.\nL'opération a été interrompue.", "Version incompatible");
        • 1. Re: Changing the text in a scriptUI window
          CarlosCanto Adobe Community Professional & MVP
          no, it is not trivial, I found it was very difficult at first...
          you need two things, have Illustrator return a value to bridgeTalk,
                  return;
              return docTitle;
          then have bridgeTalk read the returned value, then you can use it in your Palette
                              messageBT.onResult = function(returned) {
                                        var docname = returned.body;
                                        monDocTitle.text = docname;
                                        dialogue.layout.layout(true);
                  messageBT.send();
          • 2. Re: Changing the text in a scriptUI window
            Awesome.
            Works as advertised !
            Small question about the forum, what is the markup (down?) you use to get the code quote look clean ?
            • 3. Re: Changing the text in a scriptUI window
              in your reply window, click on the "Use Advanced Editor" button
              then you'll get more buttons, click on the "Insert" button and pick Syntax Highlight->Java
