1 Reply Latest reply on Mar 30, 2014 7:25 PM by A.T. Romano
      • 1. Re: Changing the format of the time scale?
        A.T. Romano Level 7
        GizmoTX
        What version of Premiere Elements are you using and on what computer operating system is it running? Assuming a NTSC set up...
        Generalized answer is....
        Over the Timeline is a timecode like display 00;00;00;00 (hours;minutes;seconds;frames). That can also be set for Frames.
        At the Timeline level, you can toggle between the two display formats by holding down the Ctrl key of the computer main keyboard and clicking once on the time format that  you see.
        Alternatively, you can go to Edit Menu/Project Settings/General and set the Display Format
        a. 30 fps Drop-Frame Code
        or
        b. Frames
        Please let us know if you have questions or need clarification, after you supply more information so that we can fine tune the reply.
        Thanks.
        ATR
