1. Re: RoboHelp 10 (TCS4)/TFS in MS Visual Studio 2013 - Unable to connect RH to TFS
Willam van Weelden Apr 1, 2014 1:43 AM (in response to GnorbX)That's not very helpful of them.
Did you follow the tutotial on:
http://www.adobe.com/devnet/robohelp/articles/robohelp-tfs-integration.html
Which version of the MSSCCI provider do you use? And are you using the
32 bit of the 64 bit? I can imagine that you need the 32 bit for
RoboHelp to work.
Kind regards,
Willam
2. Re: RoboHelp 10 (TCS4)/TFS in MS Visual Studio 2013 - Unable to connect RH to TFS
GnorbX Apr 1, 2014 1:10 PM (in response to Willam van Weelden)Hey
Yeah, I went through that tutorial, as well as this one: http://helpx.adobe.com/robohelp/kb/registry-settings-microsoft-team-foundation.html
Ultimately, as you mentioned, the issue was that I was using the 64-bit version of the MSSCCI Provider rather than the 32-bit version. Installing the 32-bit version did the trick. I downloaded it from here: http://visualstudiogallery.msdn.microsoft.com/b5b5053e-af34-4fa3-9098-aaa3f3f007cd.
Thanks!
EDIT: One very HUGE caveat here: I installed MS Visual Studio 2012, and uninstalled 2013. I don't know if this would have worked for the 2013 version because I ultimately did not test it.
