1 Reply Latest reply on Mar 31, 2014 3:29 PM by [Jongware]
    Will indesign allow me to create a calendar using the lunar cycle?
    D.Motola Level 1
      I need to be able to create a calendar using the lunar cycle instead of the standard gregorian cycle. Does Indesign's calendar wizard/software allow me to do this or would I have to create it manually through something like photoshp/illustrator?
        • 1. Re: Will indesign allow me to create a calendar using the lunar cycle?
          InDesign does not come with a Calender Wizard script, so you probably downloaded this elsewhere. you'll have to ask where you got it from.
          (If this "lunar cycle" thing is not in the feature list of that script, chances are it's not hidden in there somewhere either. If I included such a feature, I'd make sure to advertise it. If it isn't available, you can probably contact the author and see if s/he is willing to add it.)
