1 Reply Latest reply on Apr 8, 2014 10:27 PM by Kyle.Techtron
    Struggling to install CC for teams
    Kyle.Techtron Level 1
      Hi All,
      I'm struggling to install Adobe Creative Cloud for Teams.
      The install msi simply disappears while it is installing
      I've looked at the MSI log and found an error 1603 and after searching for that tried the suggested steps like
      Tried Safe mode.
      Tried reregistering the msiexec
      Tried deleting temp files.
      Tried disabling The AV and uninstalling it completely
      Nothing has worked so far.
      Here is the PDApp.log
      03/26/14 12:07:28:663 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 1932 | Build Version - 1.4.0.37
      03/26/14 12:07:28:663 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 1932 | Logging Level verbosity Set  to 4
      03/26/14 12:07:31:798 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2116 | Build Version - 1.4.0.37
      03/26/14 12:07:31:798 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2116 | Logging Level verbosity Set  to 4
      03/26/14 12:07:31:798 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2116 | Executing immediate custom action for install mode.
      03/26/14 12:07:31:798 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2116 | The CustomActionData string is : mode=install;sourceDir=C:\Users\Hamish\Desktop\temp\Software\Production\Build\;installDir =;origDB=C:\Users\Hamish\Desktop\temp\Software\Production\Build\Production.msi
      03/26/14 12:07:31:814 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2116 | Successfully executed the immediate custom action for install mode .
      03/26/14 12:07:39:146 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Build Version - 1.4.0.37
      03/26/14 12:07:39:146 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Logging Level verbosity Set  to 4
      03/26/14 12:07:39:146 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Executing the deferred custom action.
      03/26/14 12:07:39:162 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Obtained the following as CustomActionData
      03/26/14 12:07:39:162 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | mode=install;sourceDir=C:\Users\Hamish\Desktop\temp\Software\Production\Build\;installDir =;origDB=C:\Users\Hamish\Desktop\temp\Software\Production\Build\Production.msi
      03/26/14 12:07:39:162 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Original database path is : C:\Users\Hamish\Desktop\temp\Software\Production\Build\Production.msi
      03/26/14 12:07:39:177 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | OptionXML saved at location :: C:\Users\TECHSU~1\AppData\Local\Temp\{37A76E15-4F03-4504-A252-C535F32E1A71}\\{E0470426-09 B5-4669-8270-90706AACED78}
      03/26/14 12:07:39:193 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Build Version - 1.4.0.37
      03/26/14 12:07:39:193 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Logging Level verbosity Set  to 4
      03/26/14 12:07:39:193 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Initializing Custom Action Data from parameters
      03/26/14 12:07:39:193 | [INFO] |  | ASU | DeploymentManager | Utilities |  |  | 2144 | Folder does not exist
      03/26/14 12:07:39:193 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Provisioning Tool path is (C:\Users\TECHSU~1\AppData\Local\Temp\{37A76E15-4F03-4504-A252-C535F32E1A71}\\{2E336D4F-6 719-4C1B-886C-0742DC348C07}).
      03/26/14 12:07:39:193 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Starting to run the custom action for install mode
      03/26/14 12:07:39:193 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | STEP 1: Starting to parse Option XML.
      03/26/14 12:07:39:240 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Self-Update BootStrapper Relative Path doesn't exist.
      03/26/14 12:07:39:240 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | No of updates found (17).
      03/26/14 12:07:39:255 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Number of Medias found = 9
      03/26/14 12:07:39:255 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Deployment Manager is running in Install Mode.
      03/26/14 12:07:39:318 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Deployment XML created at path :: C:\Users\TECHSU~1\AppData\Local\Temp\{EC9F799F-2AEF-4C68-8222-390BF290B84E}\\{BF8D9B50-E7 4C-4185-9751-4CF429827622}
      03/26/14 12:07:39:364 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Override XML created at path :: C:\Users\TECHSU~1\AppData\Local\Temp\{EC9F799F-2AEF-4C68-8222-390BF290B84E}\\{7EA30DF6-41 5B-40D7-B19C-352E659E6B93}
      03/26/14 12:07:39:427 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Deployment XML created at path :: C:\Users\TECHSU~1\AppData\Local\Temp\{EC9F799F-2AEF-4C68-8222-390BF290B84E}\\{627716F1-29 50-41AE-8E97-226DFD5AD822}
      03/26/14 12:07:39:458 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Override XML created at path :: C:\Users\TECHSU~1\AppData\Local\Temp\{EC9F799F-2AEF-4C68-8222-390BF290B84E}\\{400E210D-A9 DA-4A52-8794-2BFAEE7EBCAD}
      03/26/14 12:07:39:489 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Deployment XML created at path :: C:\Users\TECHSU~1\AppData\Local\Temp\{EC9F799F-2AEF-4C68-8222-390BF290B84E}\\{38585983-0C 66-4FD0-B9BE-9988FFEDD9A4}
      03/26/14 12:07:39:536 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Override XML created at path :: C:\Users\TECHSU~1\AppData\Local\Temp\{EC9F799F-2AEF-4C68-8222-390BF290B84E}\\{4C9E4165-B2 F5-4B48-9EA8-1A9D07CF4140}
      03/26/14 12:07:39:583 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Deployment XML created at path :: C:\Users\TECHSU~1\AppData\Local\Temp\{EC9F799F-2AEF-4C68-8222-390BF290B84E}\\{787CA694-D5 95-4085-81FB-37940A77CE78}
      03/26/14 12:07:39:645 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Override XML created at path :: C:\Users\TECHSU~1\AppData\Local\Temp\{EC9F799F-2AEF-4C68-8222-390BF290B84E}\\{AD774B82-21 03-44A5-AE12-22FF0FC44912}
      03/26/14 12:07:39:708 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Deployment XML created at path :: C:\Users\TECHSU~1\AppData\Local\Temp\{EC9F799F-2AEF-4C68-8222-390BF290B84E}\\{076A4620-10 16-452E-A0EF-9A29B4724FFC}
      03/26/14 12:07:39:739 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Override XML created at path :: C:\Users\TECHSU~1\AppData\Local\Temp\{EC9F799F-2AEF-4C68-8222-390BF290B84E}\\{26346FFB-D0 81-4D0A-B3F9-165CCE6EC0B8}
      03/26/14 12:07:39:770 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Deployment XML created at path :: C:\Users\TECHSU~1\AppData\Local\Temp\{EC9F799F-2AEF-4C68-8222-390BF290B84E}\\{9BA5A258-00 3B-42AD-BAF2-855D9C52BE44}
      03/26/14 12:07:39:848 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Override XML created at path :: C:\Users\TECHSU~1\AppData\Local\Temp\{EC9F799F-2AEF-4C68-8222-390BF290B84E}\\{31BE2A71-24 49-4A06-B547-21761B370C8F}
      03/26/14 12:07:39:895 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Deployment XML created at path :: C:\Users\TECHSU~1\AppData\Local\Temp\{EC9F799F-2AEF-4C68-8222-390BF290B84E}\\{FBC2DB5E-98 BD-4211-AFEC-7EF496A9A3AC}
      03/26/14 12:07:39:926 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Override XML created at path :: C:\Users\TECHSU~1\AppData\Local\Temp\{EC9F799F-2AEF-4C68-8222-390BF290B84E}\\{D5085E58-89 53-4C55-9BF5-C8EAC00EE711}
      03/26/14 12:07:39:973 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Deployment XML created at path :: C:\Users\TECHSU~1\AppData\Local\Temp\{EC9F799F-2AEF-4C68-8222-390BF290B84E}\\{9B34F7F7-1A 11-47C8-BFD9-65BEA4CDF737}
      03/26/14 12:07:40:035 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Override XML created at path :: C:\Users\TECHSU~1\AppData\Local\Temp\{EC9F799F-2AEF-4C68-8222-390BF290B84E}\\{22197089-12 64-48F9-99BA-25288F5AF5A5}
      03/26/14 12:07:40:066 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Deployment XML created at path :: C:\Users\TECHSU~1\AppData\Local\Temp\{EC9F799F-2AEF-4C68-8222-390BF290B84E}\\{32E1B193-30 B0-4FBF-9148-B474308DC27F}
      03/26/14 12:07:40:113 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Override XML created at path :: C:\Users\TECHSU~1\AppData\Local\Temp\{EC9F799F-2AEF-4C68-8222-390BF290B84E}\\{DCAF1AF9-7D EF-4EEF-A726-FA686E2FA062}
      03/26/14 12:07:40:238 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | STEP 2: Starting to launch ASU AAM.
      03/26/14 12:07:40:238 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Bootstrapper launch location is :: C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\Set-up.dat
      03/26/14 12:07:40:737 | [INFO] |  | ASU | OPM | OPM |  |  | 2168 | Build Version - 8.0.0.19
      03/26/14 12:07:40:737 | [INFO] |  | ASU | OPM | OPM |  |  | 2168 | Logging Level verbosity Set  to 4
      03/26/14 12:07:40:940 | [WARN] |  | ASU | OPM | OPM |  |  | 2168 | Failed in key3List generation
      03/26/14 12:07:40:940 | [ERROR] |  | ASU | OPM | CryptEngine |  |  | 2168 | Failed in key3List generation
      03/26/14 12:07:40:987 | [INFO] |  | ASU | OPM | OPM |  |  | 2168 | Schema version and schema compatibility version are same or greater than current
      03/26/14 12:07:41:283 | [INFO] |  | ASU | OPM | OPM |  |  | 2168 | Successfully opened opm session, db location:C:\Users\techsupport\AppData\Local\Adobe\OOBE\opm.db in opm_createLibRef
      03/26/14 12:07:41:283 | [INFO] |  | ASU | OPM | OPM |  |  | 2168 | _opm_handle_OPDReturnedStatus called with opdStatus as:0
      03/26/14 12:07:41:283 | [INFO] |  | ASU | OPM | OPM |  |  | 2168 | No Record found for the input fields in opm_getValueForKey
      03/26/14 12:07:41:283 | [INFO] |  | ASU | OPM | OPM |  |  | 2168 | Released OPM refrence successfully in opm_freeLibRef
      03/26/14 12:07:41:502 | [INFO] |  | ASU | PIM | PIM |  |  | 2168 | Build Version - 2.5.0.367
      03/26/14 12:07:41:517 | [INFO] |  | ASU | PIM | PIM |  |  | 2168 | Logging Level verbosity Set  to 4
      03/26/14 12:07:41:517 | [INFO] |  | ASU | PIM | PIM |  |  | 2168 | Creating PIM instance for path: C:\Program Files (x86)\Adobe\Adobe Creative Cloud
      03/26/14 12:07:41:580 | [INFO] |  | ASU | PIM | PIM |  |  | 2168 | trying to createOrUpdatePIMDbSchema.
      03/26/14 12:07:41:673 | [INFO] |  | ASU | PIM | PIM |  |  | 2168 | Current db schema version on machine 2.
      03/26/14 12:07:41:673 | [INFO] |  | ASU | PIM | PIM |  |  | 2168 | Current db schema version to install 2.
      03/26/14 12:07:41:673 | [INFO] |  | ASU | PIM | PIM |  |  | 2168 | PIM DB Schema is up to date. Current schema version is 2.
      03/26/14 12:07:41:673 | [INFO] |  | ASU | PIM | PIM |  |  | 2168 | PIM Database is Up To Date.
      03/26/14 12:07:41:689 | [INFO] |  | ASU | PIM | PIM |  |  | 2168 | PIMSqlite closeDB status 0
      03/26/14 12:07:41:689 | [INFO] |  | ASU | PIM | PIM |  |  | 2168 | sqlite(pim.db) at path C:\Program Files (x86)\Adobe\Adobe Creative Cloud is already closed
      03/26/14 12:07:41:689 | [INFO] |  | ASU | PIM | PIM |  |  | 2168 | FREE PIM Instance ...
      03/26/14 12:07:41:767 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Build Version - 2.5.0.367
      03/26/14 12:07:41:767 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Logging Level verbosity Set  to 4
      03/26/14 12:07:41:782 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Build Version - 2.5.0.367
      03/26/14 12:07:41:782 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Logging Level verbosity Set  to 4
      03/26/14 12:07:41:782 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Creating PIM instance for path: C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp
      03/26/14 12:07:41:845 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | trying to createOrUpdatePIMDbSchema.
      03/26/14 12:07:41:860 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Current db schema version on machine 1.
      03/26/14 12:07:41:860 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Current db schema version to install 2.
      03/26/14 12:07:41:860 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS Created Tables.
      03/26/14 12:07:41:860 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | PIM Database is Up To Date.
      03/26/14 12:07:42:219 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Build Version - 2.5.0.367
      03/26/14 12:07:42:219 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Logging Level verbosity Set  to 4
      03/26/14 12:07:42:219 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Creating PIM instance for path: C:\Program Files (x86)\Adobe\Adobe Creative Cloud
      03/26/14 12:07:42:219 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | trying to createOrUpdatePIMDbSchema.
      03/26/14 12:07:42:219 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Current db schema version on machine 2.
      03/26/14 12:07:42:219 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Current db schema version to install 2.
      03/26/14 12:07:42:219 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | PIM DB Schema is up to date. Current schema version is 2.
      03/26/14 12:07:42:219 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | PIM Database is Up To Date.
      03/26/14 12:07:42:874 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Checking installation space required for application
      03/26/14 12:07:47:866 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 33497895
      03/26/14 12:07:48:646 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 61426237
      03/26/14 12:07:48:646 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Total installation space required for application: 94924132
      03/26/14 12:07:48:646 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Executing Adobe Genuine Validation for all the packages
      03/26/14 12:07:48:646 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\AAM\UWA\UWA.pimx'
      03/26/14 12:07:48:693 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\AAM\UWA\UWA.pima'
      03/26/14 12:07:48:787 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\AAM\core\PDApp.pimx'
      03/26/14 12:07:48:802 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\AAM\core\PDApp.pima'
      03/26/14 12:07:48:912 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\AAM\D6\D6.pimx'
      03/26/14 12:07:48:927 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\AAM\D6\D6.pima'
      03/26/14 12:07:48:958 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\AAM\DECore\DECore.pi mx'
      03/26/14 12:07:48:974 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\AAM\DECore\DECore.pi ma'
      03/26/14 12:07:49:036 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\AAM\DWA\DWA.pimx'
      03/26/14 12:07:49:052 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\AAM\DWA\DWA.pima'
      03/26/14 12:07:49:099 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\AAM\P6\P6.pimx'
      03/26/14 12:07:49:114 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\AAM\P6\P6.pima'
      03/26/14 12:07:49:192 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\AAM\LWA\LWA.pimx'
      03/26/14 12:07:49:208 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\AAM\LWA\LWA.pima'
      03/26/14 12:07:49:270 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\AAM\CCM\CCM.pimx'
      03/26/14 12:07:49:317 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\AAM\CCM\CCM.pima'
      03/26/14 12:07:49:333 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\AAM\P7\P7.pimx'
      03/26/14 12:07:49:349 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\AAM\P7\P7.pima'
      03/26/14 12:07:49:442 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\AAM\IPC\IPC.pimx'
      03/26/14 12:07:49:442 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\AAM\IPC\IPC.pima'
      03/26/14 12:07:49:473 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\ACC\Runtime\Runtime. pimx'
      03/26/14 12:07:49:473 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\ACC\Runtime\Runtime. pima'
      03/26/14 12:07:49:661 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\ACC\Core\Core.pimx'
      03/26/14 12:07:49:676 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\ACC\Core\Core.pima'
      03/26/14 12:07:49:676 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\ACC\ACCC\ACCC.pimx'
      03/26/14 12:07:49:692 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\ACC\ACCC\ACCC.pima'
      03/26/14 12:07:49:848 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\ACC\NEX\NEX.pimx'
      03/26/14 12:07:49:863 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\ACC\NEX\NEX.pima'
      03/26/14 12:07:49:879 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\ACC\HEX\HEX.pimx'
      03/26/14 12:07:49:895 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\ACC\HEX\HEX.pima'
      03/26/14 12:07:49:973 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\ACC\CoreExt\CoreExt. pimx'
      03/26/14 12:07:49:988 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\ACC\CoreExt\CoreExt. pima'
      03/26/14 12:07:50:019 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\ACC\Utils\Utils.pimx '
      03/26/14 12:07:50:035 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\ACC\Utils\Utils.pima '
      03/26/14 12:07:50:097 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\ACC\CoreSyncV1\CoreS yncV1.pimx'
      03/26/14 12:07:50:113 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\ACC\CoreSyncV1\CoreS yncV1.pima'
      03/26/14 12:07:50:207 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\ACC\LiveTypeV1\LiveT ypeV1.pimx'
      03/26/14 12:07:50:238 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\ACC\LiveTypeV1\LiveT ypeV1.pima'
      03/26/14 12:07:50:253 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\ACC\ANSClientV1\ANSC lientV1.pimx'
      03/26/14 12:07:50:285 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\ACC\ANSClientV1\ANSC lientV1.pima'
      03/26/14 12:07:50:300 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\ACC\CoreSync\CoreSyn c.pimx'
      03/26/14 12:07:50:316 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\ACC\CoreSync\CoreSyn c.pima'
      03/26/14 12:07:50:425 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\ACC\LiveType\LiveTyp e.pimx'
      03/26/14 12:07:50:441 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\ACC\LiveType\LiveTyp e.pima'
      03/26/14 12:07:50:456 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\ACC\ANSClient\ANSCli ent.pimx'
      03/26/14 12:07:50:456 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\ACC\ANSClient\ANSCli ent.pima'
      03/26/14 12:07:50:472 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\ACC\ExchangePlugin\E xchangePlugin.pimx'
      03/26/14 12:07:50:487 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\ACC\ExchangePlugin\E xchangePlugin.pima'
      03/26/14 12:07:50:940 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\ACC\HomePanel\HomePa nel.pimx'
      03/26/14 12:07:51:033 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\ACC\HomePanel\HomePa nel.pima'
      03/26/14 12:07:51:174 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\ACC\AppsPanel\AppsPa nel.pimx'
      03/26/14 12:07:51:189 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\ACC\AppsPanel\AppsPa nel.pima'
      03/26/14 12:07:51:221 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\ACC\FilesPanel\Files Panel.pimx'
      03/26/14 12:07:51:236 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\ACC\FilesPanel\Files Panel.pima'
      03/26/14 12:07:51:252 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\ACC\FontsPanel\Fonts Panel.pimx'
      03/26/14 12:07:51:267 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\ACC\FontsPanel\Fonts Panel.pima'
      03/26/14 12:07:51:283 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\ACC\BehancePanel\Beh ancePanel.pimx'
      03/26/14 12:07:51:299 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\ACC\BehancePanel\Beh ancePanel.pima'
      03/26/14 12:07:51:314 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Adobe Genuine Validation PASSED for all the packages
      03/26/14 12:07:51:314 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Starting installation for all the packages
      03/26/14 12:07:51:314 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Semaphore is not locked
      03/26/14 12:07:51:314 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | START install Package UWA
      03/26/14 12:07:51:564 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Schema Version is 1
      03/26/14 12:07:51:564 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | This schema version does not have Applet Relationship Info Table
      03/26/14 12:07:51:579 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deleteAppletRegInfoRecords.
      03/26/14 12:07:51:735 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deletePackageUpgradeInfoRecords.
      03/26/14 12:07:51:735 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deletePackageInstallationInfoRecords.
      03/26/14 12:07:51:767 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertPackageUpdateList.
      03/26/14 12:07:51:767 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertAppletRegInfoList.
      03/26/14 12:07:51:767 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertAppletRelInfoList.
      03/26/14 12:07:51:813 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Backup Folder Created
      03/26/14 12:07:53:405 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS installPackage at file 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\AAM\UWA\UWA.pimx'
      03/26/14 12:07:53:405 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Trying to delete back up folder
      03/26/14 12:07:53:717 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | START install Package PDApp
      03/26/14 12:07:53:732 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Path to Process :C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\core\AAMCustomHook.exe Process Directory :C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\core arguments being passed :"C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\core\AAMCustomHook.exe" --removeInventory=1 --update=true
      03/26/14 12:07:53:779 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Success in CreateProcess
      03/26/14 12:07:53:779 | [INFO] |  | ASU | AAMCustomHook | AAMCustomHook |  |  | 2240 | Build Version - 8.0.0.22
      03/26/14 12:07:53:779 | [INFO] |  | ASU | AAMCustomHook | AAMCustomHook |  |  | 2240 | Logging Level verbosity Set  to 4
      03/26/14 12:07:53:779 | [INFO] |  | ASU | AAMCustomHook |  |  |  | 2240 | Parsing the command line provided. Number of command line arguments is 3
      03/26/14 12:07:53:779 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Sucessfully launched and executed process...
      03/26/14 12:07:53:779 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Successfully executed uninstall modifier at path: 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\core\AAMCustomHook.exe'
      03/26/14 12:07:53:966 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Schema Version is 1
      03/26/14 12:07:53:966 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | This schema version does not have Applet Relationship Info Table
      03/26/14 12:07:53:966 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deleteAppletRegInfoRecords.
      03/26/14 12:07:54:231 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deletePackageUpgradeInfoRecords.
      03/26/14 12:07:54:231 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deletePackageInstallationInfoRecords.
      03/26/14 12:07:54:278 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertPackageUpdateList.
      03/26/14 12:07:54:278 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertAppletRegInfoList.
      03/26/14 12:07:54:278 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertAppletRelInfoList.
      03/26/14 12:07:54:309 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Backup Folder Created
      03/26/14 12:07:56:369 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Path to Process :C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\core\AAMCustomHook.exe Process Directory :C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\core arguments being passed :"C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\core\AAMCustomHook.exe" --createInventory=1 --doPostInstallStep=1 --update=true
      03/26/14 12:07:56:369 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Success in CreateProcess
      03/26/14 12:07:56:369 | [INFO] |  | ASU | AAMCustomHook | AAMCustomHook |  |  | 2308 | Build Version - 8.0.0.22
      03/26/14 12:07:56:369 | [INFO] |  | ASU | AAMCustomHook | AAMCustomHook |  |  | 2308 | Logging Level verbosity Set  to 4
      03/26/14 12:07:56:369 | [INFO] |  | ASU | AAMCustomHook |  |  |  | 2308 | Parsing the command line provided. Number of command line arguments is 4
      03/26/14 12:07:56:961 | [INFO] |  | ASU | AAMCustomHook | AAMCustomHook |  |  | 2308 | Updater Inventory location: 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\UWA\updaterinventory.dll'
      03/26/14 12:07:57:008 | [INFO] |  | ASU | AAMCustomHook | AAMCustomHook |  |  | 2308 | Going to create or update inventory
      03/26/14 12:07:57:086 | [INFO] |  | ASU | AAMCustomHook | AAMCustomHook |  |  | 2308 | Inventory Already present on the machine...
      03/26/14 12:07:57:086 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Sucessfully launched and executed process...
      03/26/14 12:07:57:086 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Successfully executed install modifier at path: 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\core\AAMCustomHook.exe'
      03/26/14 12:07:57:086 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS installPackage at file 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\AAM\core\PDApp.pimx'
      03/26/14 12:07:57:086 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Trying to delete back up folder
      03/26/14 12:07:57:398 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | START install Package D6
      03/26/14 12:07:57:539 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Schema Version is 1
      03/26/14 12:07:57:539 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | This schema version does not have Applet Relationship Info Table
      03/26/14 12:07:57:539 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deleteAppletRegInfoRecords.
      03/26/14 12:07:57:726 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deletePackageUpgradeInfoRecords.
      03/26/14 12:07:57:726 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deletePackageInstallationInfoRecords.
      03/26/14 12:07:57:741 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertPackageUpdateList.
      03/26/14 12:07:57:741 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertAppletRegInfoList.
      03/26/14 12:07:57:741 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertAppletRelInfoList.
      03/26/14 12:07:57:773 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Backup Folder Created
      03/26/14 12:07:58:428 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS installPackage at file 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\AAM\D6\D6.pimx'
      03/26/14 12:07:58:428 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Trying to delete back up folder
      03/26/14 12:07:59:847 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | START install Package DECore
      03/26/14 12:08:00:035 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Schema Version is 1
      03/26/14 12:08:00:035 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | This schema version does not have Applet Relationship Info Table
      03/26/14 12:08:00:035 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deleteAppletRegInfoRecords.
      03/26/14 12:08:00:222 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deletePackageUpgradeInfoRecords.
      03/26/14 12:08:00:222 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deletePackageInstallationInfoRecords.
      03/26/14 12:08:00:253 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertPackageUpdateList.
      03/26/14 12:08:00:253 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertAppletRegInfoList.
      03/26/14 12:08:00:253 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertAppletRelInfoList.
      03/26/14 12:08:00:269 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Backup Folder Created
      03/26/14 12:08:02:094 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS installPackage at file 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\AAM\DECore\DECore.pi mx'
      03/26/14 12:08:02:094 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Trying to delete back up folder
      03/26/14 12:08:02:312 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | START install Package DWA
      03/26/14 12:08:02:453 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Schema Version is 1
      03/26/14 12:08:02:453 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | This schema version does not have Applet Relationship Info Table
      03/26/14 12:08:02:453 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deleteAppletRegInfoRecords.
      03/26/14 12:08:02:468 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deletePackageUpgradeInfoRecords.
      03/26/14 12:08:02:468 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deletePackageInstallationInfoRecords.
      03/26/14 12:08:02:484 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertPackageUpdateList.
      03/26/14 12:08:02:484 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertAppletRegInfoList.
      03/26/14 12:08:02:484 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertAppletRelInfoList.
      03/26/14 12:08:03:420 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Backup Folder Created
      03/26/14 12:08:04:137 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS installPackage at file 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\AAM\DWA\DWA.pimx'
      03/26/14 12:08:04:137 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Trying to delete back up folder
      03/26/14 12:08:04:340 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | START install Package P6
      03/26/14 12:08:04:496 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Schema Version is 1
      03/26/14 12:08:04:496 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | This schema version does not have Applet Relationship Info Table
      03/26/14 12:08:04:496 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deleteAppletRegInfoRecords.
      03/26/14 12:08:04:964 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deletePackageUpgradeInfoRecords.
      03/26/14 12:08:04:964 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deletePackageInstallationInfoRecords.
      03/26/14 12:08:04:980 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertPackageUpdateList.
      03/26/14 12:08:04:980 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertAppletRegInfoList.
      03/26/14 12:08:04:980 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertAppletRelInfoList.
      03/26/14 12:08:05:354 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Backup Folder Created
      03/26/14 12:08:07:835 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS installPackage at file 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\AAM\P6\P6.pimx'
      03/26/14 12:08:07:835 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Trying to delete back up folder
      03/26/14 12:08:11:657 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | START install Package LWA
      03/26/14 12:08:11:797 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Schema Version is 1
      03/26/14 12:08:11:797 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | This schema version does not have Applet Relationship Info Table
      03/26/14 12:08:11:797 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deleteAppletRegInfoRecords.
      03/26/14 12:08:11:813 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deletePackageUpgradeInfoRecords.
      03/26/14 12:08:11:813 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deletePackageInstallationInfoRecords.
      03/26/14 12:08:11:828 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertPackageUpdateList.
      03/26/14 12:08:11:828 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertAppletRegInfoList.
      03/26/14 12:08:11:828 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertAppletRelInfoList.
      03/26/14 12:08:11:844 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Backup Folder Created
      03/26/14 12:08:13:794 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS installPackage at file 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\AAM\LWA\LWA.pimx'
      03/26/14 12:08:13:794 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Trying to delete back up folder
      03/26/14 12:08:16:399 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | START install Package CCM
      03/26/14 12:08:16:820 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Schema Version is 1
      03/26/14 12:08:16:820 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | This schema version does not have Applet Relationship Info Table
      03/26/14 12:08:16:820 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deleteAppletRegInfoRecords.
      03/26/14 12:08:16:867 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deletePackageUpgradeInfoRecords.
      03/26/14 12:08:16:867 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deletePackageInstallationInfoRecords.
      03/26/14 12:08:16:898 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertPackageUpdateList.
      03/26/14 12:08:16:898 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertAppletRegInfoList.
      03/26/14 12:08:16:898 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertAppletRelInfoList.
      03/26/14 12:08:16:929 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Backup Folder Created
      03/26/14 12:08:17:351 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS installPackage at file 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\AAM\CCM\CCM.pimx'
      03/26/14 12:08:17:351 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Trying to delete back up folder
      03/26/14 12:08:17:475 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | START install Package P7
      03/26/14 12:08:17:600 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Schema Version is 1
      03/26/14 12:08:17:600 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | This schema version does not have Applet Relationship Info Table
      03/26/14 12:08:17:600 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deleteAppletRegInfoRecords.
      03/26/14 12:08:17:616 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deletePackageUpgradeInfoRecords.
      03/26/14 12:08:17:616 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deletePackageInstallationInfoRecords.
      03/26/14 12:08:17:616 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertPackageUpdateList.
      03/26/14 12:08:17:616 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertAppletRegInfoList.
      03/26/14 12:08:17:616 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertAppletRelInfoList.
      03/26/14 12:08:17:647 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Backup Folder Created
      03/26/14 12:08:20:205 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS installPackage at file 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\AAM\P7\P7.pimx'
      03/26/14 12:08:20:205 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Trying to delete back up folder
      03/26/14 12:08:28:489 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | START install Package IPC
      03/26/14 12:08:29:019 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Path to Process :C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\IPC\customhook\AdobeIPCBrokerCustomHook.exe Process Directory :C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\IPC\customhook arguments being passed :"C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\IPC\customhook\AdobeIPCBrokerCustomHook.exe" -uninstall --update=true
      03/26/14 12:08:29:144 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Success in CreateProcess
      03/26/14 12:08:29:144 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Sucessfully launched and executed process...
      03/26/14 12:08:29:144 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Successfully executed uninstall modifier at path: 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\IPC\customhook\AdobeIPCBrokerCustomHook.exe'
      03/26/14 12:08:29:409 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Schema Version is 1
      03/26/14 12:08:29:409 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | This schema version does not have Applet Relationship Info Table
      03/26/14 12:08:29:409 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deleteAppletRegInfoRecords.
      03/26/14 12:08:29:409 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deletePackageUpgradeInfoRecords.
      03/26/14 12:08:29:409 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deletePackageInstallationInfoRecords.
      03/26/14 12:08:29:409 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertPackageUpdateList.
      03/26/14 12:08:29:409 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertAppletRegInfoList.
      03/26/14 12:08:29:409 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertAppletRelInfoList.
      03/26/14 12:08:33:840 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Backup Folder Created
      03/26/14 12:08:34:214 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Path to Process :C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\IPC\customhook\AdobeIPCBrokerCustomHook.exe Process Directory :C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\IPC\customhook arguments being passed :"C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\IPC\customhook\AdobeIPCBrokerCustomHook.exe" -uninstall --update=true
      03/26/14 12:08:34:214 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Success in CreateProcess
      03/26/14 12:08:34:230 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Sucessfully launched and executed process...
      03/26/14 12:08:34:230 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Successfully executed install modifier at path: 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\IPC\customhook\AdobeIPCBrokerCustomHook.exe'
      03/26/14 12:08:34:230 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS installPackage at file 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\AAM\IPC\IPC.pimx'
      03/26/14 12:08:34:230 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Trying to delete back up folder
      03/26/14 12:08:34:417 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | START install Package Runtime
      03/26/14 12:08:34:854 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Schema Version is 2
      03/26/14 12:08:34:869 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deleteAppletRelInfoRecords.
      03/26/14 12:08:34:869 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deleteAppletRegInfoRecords.
      03/26/14 12:08:35:103 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deletePackageUpgradeInfoRecords.
      03/26/14 12:08:35:103 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deletePackageInstallationInfoRecords.
      03/26/14 12:08:35:119 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertPackageUpdateList.
      03/26/14 12:08:35:119 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertAppletRegInfoList.
      03/26/14 12:08:35:119 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertAppletRelInfoList.
      03/26/14 12:08:35:150 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Backup Folder Created
      03/26/14 12:08:35:649 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Modifier Executable's Absolute Path is C:\Program Files (x86)\Adobe\Adobe Creative Cloud\Runtime\customhook\RuntimeCustomHook.exe
      03/26/14 12:08:35:649 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Path to Process :C:\Program Files (x86)\Adobe\Adobe Creative Cloud\Runtime\customhook\RuntimeCustomHook.exe Process Directory :C:\Program Files (x86)\Adobe\Adobe Creative Cloud\Runtime\customhook arguments being passed :"C:\Program Files (x86)\Adobe\Adobe Creative Cloud\Runtime\customhook\RuntimeCustomHook.exe" /q /norestart --update=true
      03/26/14 12:08:35:649 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Success in CreateProcess
      03/26/14 12:19:20:298 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Sucessfully launched and executed process...
      03/26/14 12:19:20:298 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Successfully executed install modifier at path: 'C:\Program Files (x86)\Adobe\Adobe Creative Cloud\Runtime\customhook\RuntimeCustomHook.exe'
      03/26/14 12:19:20:298 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS installPackage at file 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\ACC\Runtime\Runtime. pimx'
      03/26/14 12:19:20:298 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Trying to delete back up folder
      03/26/14 12:19:20:438 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | START install Package Core
      03/26/14 12:19:20:672 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Schema Version is 2
      03/26/14 12:19:20:672 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deleteAppletRelInfoRecords.
      03/26/14 12:19:20:672 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deleteAppletRegInfoRecords.
      03/26/14 12:19:21:171 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deletePackageUpgradeInfoRecords.
      03/26/14 12:19:21:171 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deletePackageInstallationInfoRecords.
      03/26/14 12:19:21:171 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertPackageUpdateList.
      03/26/14 12:19:21:171 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertAppletRegInfoList.
      03/26/14 12:19:21:171 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertAppletRelInfoList.
      03/26/14 12:19:21:203 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Backup Folder Created
      03/26/14 12:19:21:593 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS installPackage at file 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\ACC\Core\Core.pimx'
      03/26/14 12:19:21:593 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Trying to delete back up folder
      03/26/14 12:19:21:764 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | START install Package ACCC
      03/26/14 12:19:21:936 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Schema Version is 2
      03/26/14 12:19:21:936 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deleteAppletRelInfoRecords.
      03/26/14 12:19:21:951 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deleteAppletRegInfoRecords.
      03/26/14 12:19:22:217 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deletePackageUpgradeInfoRecords.
      03/26/14 12:19:22:217 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deletePackageInstallationInfoRecords.
      03/26/14 12:19:22:217 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertPackageUpdateList.
      03/26/14 12:19:22:217 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertAppletRegInfoList.
      03/26/14 12:19:22:217 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertAppletRelInfoList.
      03/26/14 12:19:22:310 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Backup Folder Created
      03/26/14 12:19:23:933 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS installPackage at file 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\ACC\ACCC\ACCC.pimx'
      03/26/14 12:19:23:933 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Trying to delete back up folder
      03/26/14 12:19:24:993 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | START install Package NEX
      03/26/14 12:19:25:274 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Schema Version is 2
      03/26/14 12:19:25:274 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deleteAppletRelInfoRecords.
      03/26/14 12:19:25:274 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deleteAppletRegInfoRecords.
      03/26/14 12:19:25:383 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deletePackageUpgradeInfoRecords.
      03/26/14 12:19:25:383 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deletePackageInstallationInfoRecords.
      03/26/14 12:19:25:399 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertPackageUpdateList.
      03/26/14 12:19:25:399 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertAppletRegInfoList.
      03/26/14 12:19:25:399 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertAppletRelInfoList.
      03/26/14 12:19:25:415 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Backup Folder Created
      03/26/14 12:19:25:883 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS installPackage at file 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\ACC\NEX\NEX.pimx'
      03/26/14 12:19:25:883 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Trying to delete back up folder
      03/26/14 12:19:26:023 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | START install Package HEX
      03/26/14 12:19:26:195 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Schema Version is 2
      03/26/14 12:19:26:195 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deleteAppletRelInfoRecords.
      03/26/14 12:19:26:195 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deleteAppletRegInfoRecords.
      03/26/14 12:19:26:304 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deletePackageUpgradeInfoRecords.
      03/26/14 12:19:26:304 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deletePackageInstallationInfoRecords.
      03/26/14 12:19:26:304 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertPackageUpdateList.
      03/26/14 12:19:26:304 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertAppletRegInfoList.
      03/26/14 12:19:26:304 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertAppletRelInfoList.
      03/26/14 12:19:26:335 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Backup Folder Created
      03/26/14 12:19:27:755 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS installPackage at file 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\ACC\HEX\HEX.pimx'
      03/26/14 12:19:27:755 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Trying to delete back up folder
      03/26/14 12:19:28:067 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | START install Package CoreExt
      03/26/14 12:19:28:254 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Schema Version is 2
      03/26/14 12:19:28:254 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deleteAppletRelInfoRecords.
      03/26/14 12:19:28:254 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deleteAppletRegInfoRecords.
      03/26/14 12:19:28:269 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deletePackageUpgradeInfoRecords.
      03/26/14 12:19:28:269 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deletePackageInstallationInfoRecords.
      03/26/14 12:19:28:269 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertPackageUpdateList.
      03/26/14 12:19:28:269 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertAppletRegInfoList.
      03/26/14 12:19:28:269 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertAppletRelInfoList.
      03/26/14 12:19:28:316 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Backup Folder Created
      03/26/14 12:19:29:112 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS installPackage at file 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\ACC\CoreExt\CoreExt. pimx'
      03/26/14 12:19:29:112 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Trying to delete back up folder
      03/26/14 12:19:29:408 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | START install Package Utils
      03/26/14 12:19:29:408 | [ERROR] |  | ASU | PIM | PIM |  |  | 2196 | Process CreativeCloud(URIHandler).exe could not be killed
      03/26/14 12:19:29:408 | [ERROR] |  | ASU | PIM | PIM |  |  | 2196 | Process Creative Cloud Helper.exe could not be killed
      03/26/14 12:19:29:408 | [ERROR] |  | ASU | PIM | PIM |  |  | 2196 | Process Creative Cloud Uninstaller.exe could not be killed
      03/26/14 12:19:29:439 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Path to Process :C:\Program Files (x86)\Adobe\Adobe Creative Cloud\Utils\CreativeCloud(URIHandler).exe Process Directory :C:\Program Files (x86)\Adobe\Adobe Creative Cloud\Utils arguments being passed :"C:\Program Files (x86)\Adobe\Adobe Creative Cloud\Utils\CreativeCloud(URIHandler).exe" --unregister=true --deleteShortcut=true --update=true
      03/26/14 12:19:29:471 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Success in CreateProcess
      03/26/14 12:19:29:861 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Sucessfully launched and executed process...
      03/26/14 12:19:29:861 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Successfully executed uninstall modifier at path: 'C:\Program Files (x86)\Adobe\Adobe Creative Cloud\Utils\CreativeCloud(URIHandler).exe'
      03/26/14 12:19:30:110 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Schema Version is 2
      03/26/14 12:19:30:110 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deleteAppletRelInfoRecords.
      03/26/14 12:19:30:110 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deleteAppletRegInfoRecords.
      03/26/14 12:19:30:204 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deletePackageUpgradeInfoRecords.
      03/26/14 12:19:30:204 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deletePackageInstallationInfoRecords.
      03/26/14 12:19:30:204 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertPackageUpdateList.
      03/26/14 12:19:30:204 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertAppletRegInfoList.
      03/26/14 12:19:30:204 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertAppletRelInfoList.
      03/26/14 12:19:30:407 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Backup Folder Created
      03/26/14 12:19:33:433 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Path to Process :C:\Program Files (x86)\Adobe\Adobe Creative Cloud\Utils\CreativeCloud(URIHandler).exe Process Directory :C:\Program Files (x86)\Adobe\Adobe Creative Cloud\Utils arguments being passed :"C:\Program Files (x86)\Adobe\Adobe Creative Cloud\Utils\CreativeCloud(URIHandler).exe" --register=true --createShortcut=true --update=true
      03/26/14 12:19:33:480 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Success in CreateProcess
      03/26/14 12:19:33:995 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Sucessfully launched and executed process...
      03/26/14 12:19:33:995 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Successfully executed install modifier at path: 'C:\Program Files (x86)\Adobe\Adobe Creative Cloud\Utils\CreativeCloud(URIHandler).exe'
      03/26/14 12:19:33:995 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS installPackage at file 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\ACC\Utils\Utils.pimx '
      03/26/14 12:19:33:995 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Trying to delete back up folder
      03/26/14 12:19:34:275 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | START install Package CoreSyncV1
      03/26/14 12:19:34:447 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Schema Version is 2
      03/26/14 12:19:34:447 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deleteAppletRelInfoRecords.
      03/26/14 12:19:34:447 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deleteAppletRegInfoRecords.
      03/26/14 12:19:34:525 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deletePackageUpgradeInfoRecords.
      03/26/14 12:19:34:525 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deletePackageInstallationInfoRecords.
      03/26/14 12:19:34:603 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertPackageUpdateList.
      03/26/14 12:19:34:603 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertAppletRegInfoList.
      03/26/14 12:19:34:603 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertAppletRelInfoList.
      03/26/14 12:19:34:931 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Backup Folder Created
      03/26/14 12:19:35:757 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS installPackage at file 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\ACC\CoreSyncV1\CoreS yncV1.pimx'
      03/26/14 12:19:35:757 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Trying to delete back up folder
      03/26/14 12:19:36:132 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | START install Package LiveTypeV1
      03/26/14 12:19:36:303 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Schema Version is 2
      03/26/14 12:19:36:303 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deleteAppletRelInfoRecords.
      03/26/14 12:19:36:303 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deleteAppletRegInfoRecords.
      03/26/14 12:19:36:303 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deletePackageUpgradeInfoRecords.
      03/26/14 12:19:36:303 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deletePackageInstallationInfoRecords.
      03/26/14 12:19:36:303 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertPackageUpdateList.
      03/26/14 12:19:36:303 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertAppletRegInfoList.
      03/26/14 12:19:36:303 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertAppletRelInfoList.
      03/26/14 12:19:37:271 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS installPackage at file 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\ACC\LiveTypeV1\LiveT ypeV1.pimx'
      03/26/14 12:19:37:458 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | START install Package ANSClientV1
      03/26/14 12:19:37:598 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Schema Version is 2
      03/26/14 12:19:37:598 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deleteAppletRelInfoRecords.
      03/26/14 12:19:37:598 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deleteAppletRegInfoRecords.
      03/26/14 12:19:37:630 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deletePackageUpgradeInfoRecords.
      03/26/14 12:19:37:630 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deletePackageInstallationInfoRecords.
      03/26/14 12:19:37:630 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertPackageUpdateList.
      03/26/14 12:19:37:630 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertAppletRegInfoList.
      03/26/14 12:19:37:630 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertAppletRelInfoList.
      03/26/14 12:19:37:988 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS installPackage at file 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\ACC\ANSClientV1\ANSC lientV1.pimx'
      03/26/14 12:19:38:160 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | START install Package CoreSync
      03/26/14 12:19:38:176 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Modifier Executable's Absolute Path is C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CoreSync\customhook\CoreSyncCustomHook.exe
      03/26/14 12:19:38:176 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Path to Process :C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CoreSync\customhook\CoreSyncCustomHook.exe Process Directory :C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CoreSync\customhook arguments being passed :"C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CoreSync\customhook\CoreSyncCustomHook.exe" -uninstall --update=true
      03/26/14 12:19:38:207 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Success in CreateProcess
      03/26/14 12:19:38:784 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Sucessfully launched and executed process...
      03/26/14 12:19:38:784 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Successfully executed uninstall modifier at path: 'C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CoreSync\customhook\CoreSyncCustomHook.exe'
      03/26/14 12:19:39:205 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Schema Version is 2
      03/26/14 12:19:39:205 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deleteAppletRelInfoRecords.
      03/26/14 12:19:39:205 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deleteAppletRegInfoRecords.
      03/26/14 12:19:39:268 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deletePackageUpgradeInfoRecords.
      03/26/14 12:19:39:268 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deletePackageInstallationInfoRecords.
      03/26/14 12:19:39:283 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertPackageUpdateList.
      03/26/14 12:19:39:283 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertAppletRegInfoList.
      03/26/14 12:19:39:283 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertAppletRelInfoList.
      03/26/14 12:19:39:798 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Backup Folder Created
      03/26/14 12:19:40:703 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Modifier Executable's Absolute Path is C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CoreSync\customhook\CoreSyncCustomHook.exe
      03/26/14 12:19:40:703 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Argument Path is -install "C:\Program Files (x86)\Adobe\Adobe Creative Cloud"
      03/26/14 12:19:40:703 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Path to Process :C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CoreSync\customhook\CoreSyncCustomHook.exe Process Directory :C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CoreSync\customhook arguments being passed :"C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CoreSync\customhook\CoreSyncCustomHook.exe" -install "C:\Program Files (x86)\Adobe\Adobe Creative Cloud" --update=true
      03/26/14 12:19:40:734 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Success in CreateProcess
      03/26/14 12:19:41:296 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Sucessfully launched and executed process...
      03/26/14 12:19:41:296 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Successfully executed install modifier at path: 'C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CoreSync\customhook\CoreSyncCustomHook.exe'
      03/26/14 12:19:41:296 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS installPackage at file 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\ACC\CoreSync\CoreSyn c.pimx'
      03/26/14 12:19:41:296 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Trying to delete back up folder
      03/26/14 12:19:41:982 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | START install Package LiveType
      03/26/14 12:19:42:216 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Schema Version is 2
      03/26/14 12:19:42:216 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deleteAppletRelInfoRecords.
      03/26/14 12:19:42:216 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deleteAppletRegInfoRecords.
      03/26/14 12:19:42:263 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deletePackageUpgradeInfoRecords.
      03/26/14 12:19:42:263 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deletePackageInstallationInfoRecords.
      03/26/14 12:19:42:263 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertPackageUpdateList.
      03/26/14 12:19:42:263 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertAppletRegInfoList.
      03/26/14 12:19:42:263 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertAppletRelInfoList.
      03/26/14 12:19:43:183 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS installPackage at file 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\ACC\LiveType\LiveTyp e.pimx'
      03/26/14 12:19:43:339 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | START install Package ANSClient
      03/26/14 12:19:43:526 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Schema Version is 2
      03/26/14 12:19:43:526 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deleteAppletRelInfoRecords.
      03/26/14 12:19:43:526 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deleteAppletRegInfoRecords.
      03/26/14 12:19:43:573 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deletePackageUpgradeInfoRecords.
      03/26/14 12:19:43:573 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deletePackageInstallationInfoRecords.
      03/26/14 12:19:43:573 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertPackageUpdateList.
      03/26/14 12:19:43:573 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertAppletRegInfoList.
      03/26/14 12:19:43:573 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertAppletRelInfoList.
      03/26/14 12:19:43:994 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS installPackage at file 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\ACC\ANSClient\ANSCli ent.pimx'
      03/26/14 12:19:44:228 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | START install Package ExchangePlugin
      03/26/14 12:19:44:416 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Schema Version is 2
      03/26/14 12:19:44:416 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deleteAppletRelInfoRecords.
      03/26/14 12:19:44:416 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deleteAppletRegInfoRecords.
      03/26/14 12:19:44:462 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deletePackageUpgradeInfoRecords.
      03/26/14 12:19:44:462 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deletePackageInstallationInfoRecords.
      03/26/14 12:19:44:462 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertPackageUpdateList.
      03/26/14 12:19:44:462 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertAppletRegInfoList.
      03/26/14 12:19:44:462 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertAppletRelInfoList.
      03/26/14 12:19:46:194 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS installPackage at file 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\ACC\ExchangePlugin\E xchangePlugin.pimx'
      03/26/14 12:19:46:381 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | START install Package HomePanel
      03/26/14 12:19:47:021 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Schema Version is 2
      03/26/14 12:19:47:021 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deleteAppletRelInfoRecords.
      03/26/14 12:19:47:021 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deleteAppletRegInfoRecords.
      03/26/14 12:19:47:317 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deletePackageUpgradeInfoRecords.
      03/26/14 12:19:47:317 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deletePackageInstallationInfoRecords.
      03/26/14 12:19:47:333 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertPackageUpdateList.
      03/26/14 12:19:47:333 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertAppletRegInfoList.
      03/26/14 12:19:47:333 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertAppletRelInfoList.
      03/26/14 12:19:47:489 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Backup Folder Created
      03/26/14 12:19:48:300 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS installPackage at file 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\ACC\HomePanel\HomePa nel.pimx'
      03/26/14 12:19:48:300 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Trying to delete back up folder
      03/26/14 12:19:49:673 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | START install Package AppsPanel
      03/26/14 12:19:49:860 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Schema Version is 2
      03/26/14 12:19:49:860 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deleteAppletRelInfoRecords.
      03/26/14 12:19:49:860 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deleteAppletRegInfoRecords.
      03/26/14 12:19:49:891 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deletePackageUpgradeInfoRecords.
      03/26/14 12:19:49:891 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deletePackageInstallationInfoRecords.
      03/26/14 12:19:49:907 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertPackageUpdateList.
      03/26/14 12:19:49:907 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertAppletRegInfoList.
      03/26/14 12:19:49:907 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertAppletRelInfoList.
      03/26/14 12:19:49:938 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Backup Folder Created
      03/26/14 12:19:50:796 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS installPackage at file 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\ACC\AppsPanel\AppsPa nel.pimx'
      03/26/14 12:19:50:796 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Trying to delete back up folder
      03/26/14 12:19:51:436 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | START install Package FilesPanel
      03/26/14 12:19:51:701 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Schema Version is 2
      03/26/14 12:19:51:701 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deleteAppletRelInfoRecords.
      03/26/14 12:19:51:701 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deleteAppletRegInfoRecords.
      03/26/14 12:19:51:732 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deletePackageUpgradeInfoRecords.
      03/26/14 12:19:51:732 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deletePackageInstallationInfoRecords.
      03/26/14 12:19:51:732 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertPackageUpdateList.
      03/26/14 12:19:51:732 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertAppletRegInfoList.
      03/26/14 12:19:51:732 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertAppletRelInfoList.
      03/26/14 12:19:51:763 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Backup Folder Created
      03/26/14 12:19:52:356 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS installPackage at file 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\ACC\FilesPanel\Files Panel.pimx'
      03/26/14 12:19:52:356 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Trying to delete back up folder
      03/26/14 12:19:53:401 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | START install Package FontsPanel
      03/26/14 12:19:53:557 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Schema Version is 2
      03/26/14 12:19:53:557 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deleteAppletRelInfoRecords.
      03/26/14 12:19:53:557 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deleteAppletRegInfoRecords.
      03/26/14 12:19:53:573 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deletePackageUpgradeInfoRecords.
      03/26/14 12:19:53:573 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deletePackageInstallationInfoRecords.
      03/26/14 12:19:53:588 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertPackageUpdateList.
      03/26/14 12:19:53:588 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertAppletRegInfoList.
      03/26/14 12:19:53:588 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertAppletRelInfoList.
      03/26/14 12:19:53:620 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Backup Folder Created
      03/26/14 12:19:54:088 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS installPackage at file 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\ACC\FontsPanel\Fonts Panel.pimx'
      03/26/14 12:19:54:088 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Trying to delete back up folder
      03/26/14 12:19:54:368 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | START install Package BehancePanel
      03/26/14 12:19:54:712 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Schema Version is 2
      03/26/14 12:19:54:712 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deleteAppletRelInfoRecords.
      03/26/14 12:19:54:712 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deleteAppletRegInfoRecords.
      03/26/14 12:19:54:727 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deletePackageUpgradeInfoRecords.
      03/26/14 12:19:54:727 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS deletePackageInstallationInfoRecords.
      03/26/14 12:19:54:727 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertPackageUpdateList.
      03/26/14 12:19:54:727 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertAppletRegInfoList.
      03/26/14 12:19:54:727 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS insertAppletRelInfoList.
      03/26/14 12:19:54:899 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Backup Folder Created
      03/26/14 12:19:55:460 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | SUCCESS installPackage at file 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\ASU\packages\ACC\BehancePanel\Beh ancePanel.pimx'
      03/26/14 12:19:55:460 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Trying to delete back up folder
      03/26/14 12:19:55:741 | [ERROR] |  | ASU | PIM | PIM |  |  | 2196 | Setting values for registry Key SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Creative Cloud
      03/26/14 12:19:55:741 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Registry set successfull for value "Adobe Creative Cloud" with the name "DisplayName".
      03/26/14 12:19:55:741 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Registry set successfull for value ""C:\Program Files (x86)\Adobe\Adobe Creative Cloud\Utils\Creative Cloud Uninstaller.exe"" with the name "UninstallString".
      03/26/14 12:19:55:741 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Registry set successfull for value "Adobe Systems Incorporated" with the name "Publisher".
      03/26/14 12:19:55:741 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Registry set successfull for value ""C:\Program Files (x86)\Adobe\Adobe Creative Cloud\Utils\Creative Cloud Uninstaller.exe"" with the name "DisplayIcon".
      03/26/14 12:19:55:741 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Registry set successfull for value "2.5.0.367" with the name "DisplayVersion".
      03/26/14 12:19:55:772 | [ERROR] |  | ASU | PIM | PIM |  |  | 2196 | AAM ref file already exists at  2 C:\Program Files (x86)\Common Files\Adobe\AdobeApplicationManager\AAMRefs/ACC.aamref/RefCount.txt
      03/26/14 12:19:55:772 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Starting uninstallation of package: 'ServiceManager'
      03/26/14 12:19:55:772 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | Package 'ServiceManager' not installed. So it can't be uninstalled
      03/26/14 12:19:55:772 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | End installation for all the packages
      03/26/14 12:19:55:772 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | PIMSqlite closeDB status 0
      03/26/14 12:19:55:772 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | sqlite(pim.db) at path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp is already closed
      03/26/14 12:19:55:772 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | FREE PIM Instance ...
      03/26/14 12:19:55:772 | [INFO] |  | ASU | PIM | PIM |  |  | 2196 | sqlite(pim.db) at path C:\Program Files (x86)\Adobe\Adobe Creative Cloud is already closed
      03/26/14 12:19:57:738 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Build Version - 1.4.0.37
      03/26/14 12:19:57:738 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Logging Level verbosity Set  to 4
      03/26/14 12:19:57:738 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | The return code from the Bootstrapper Process is (0).
      03/26/14 12:19:57:738 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Starting apply AAMEE Self-Update.
      03/26/14 12:19:57:738 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Bootstrapper launch location is :: C:\Users\Hamish\Desktop\temp\Software\Production\Build\Patches\AdobeApplicationManager-1. 0_update7\Set-up.dat
      3/26/2014 12:19:57 [INFO] Setup - Build Version - 6.2.136.0
      3/26/2014 12:19:57 [INFO] Setup - Logging Level verbosity Set  to 4
      3/26/2014 12:19:57 [INFO] Setup - Start Adobe Setup
      3/26/2014 12:19:57 [INFO] Setup - TimeLog: Bootstrapper Start
      3/26/2014 12:19:57 [INFO] Setup - TimeLog: Start initial checks
      3/26/2014 12:19:57 [INFO] Setup - Action specified - "install"
      3/26/2014 12:19:57 [ERROR] Setup - Error parsing command line arguments at - "--edtWorkFlow=1".
      Expected arguments are -
                --mode=silent
                --overrideFile="<FilePath>"
      3/26/2014 12:19:57 [ERROR] Setup - Error parsing command line arguments at - "--skipServiceManager=1".
                --mode=silent
      3/26/2014 12:19:57 [INFO] PIM - Trying to access xml at path:C:\Users\Hamish\Desktop\temp\Software\Production\Build\Patches\AdobeApplicationManag er-1.0_update7\resources\setup.xml
      3/26/2014 12:19:57 [INFO] PIM - XML is valid
      3/26/2014 12:19:57 [WARN] PIM - Failed to find Node
      3/26/2014 12:19:57 [INFO] Setup - Found 7 packages in setup manifest
      3/26/2014 12:19:57 [WARN] Setup - Reboot is pending from earlier installation.
      3/26/2014 12:19:58 [INFO] Utilities - Semaphore is not locked
      3/26/2014 12:19:58 [INFO] PIM - Build Version - 6.2.136.0
      3/26/2014 12:19:58 [INFO] PIM - Logging Level verbosity Set  to 4
      3/26/2014 12:19:58 [INFO] Utilities - File does not exist
      3/26/2014 12:19:58 [INFO] PIM - CREATE PIM Instance ...
      3/26/2014 12:19:58 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
      3/26/2014 12:19:58 [INFO] PIM - Current db schema version on machine 1.
      3/26/2014 12:19:58 [INFO] PIM - Current db schema version to install 1.
      3/26/2014 12:19:58 [INFO] PIM - PIM DB Schema is up to date. Current schema version is 1.
      3/26/2014 12:19:58 [INFO] PIM - PIM Database is Up To Date.
      3/26/2014 12:19:58 [INFO] PIM - Updater Inventory location:C:\Users\Hamish\Desktop\temp\Software\Production\Build\Patches\AdobeApplicationM anager-1.0_update7\resources\updaterinventory.dll
      3/26/2014 12:19:58 [INFO] PIM - Acquired System level ACF lock ...
      3/26/2014 12:19:58 [INFO] PIM - Trying to access xml at path:C:\Users\Hamish\Desktop\temp\Software\Production\Build\Patches\AdobeApplicationManag er-1.0_update7\packages\core\PDApp.pimx
      3/26/2014 12:19:58 [INFO] PIM - XML is valid
      3/26/2014 12:19:58 [WARN] PIM - Failed to find Node
      3/26/2014 12:19:58 [INFO] PIM - Package id 5AA1D762-31AF-4FC3-A0C0-66BF663B2117 is a Old Package, a newer package is installed in the system.
      3/26/2014 12:19:58 [INFO] PIM - Trying to access xml at path:C:\Users\Hamish\Desktop\temp\Software\Production\Build\Patches\AdobeApplicationManag er-1.0_update7\packages\D6\D6.pimx
      3/26/2014 12:19:58 [INFO] PIM - Package id 54FD72DC-72EC-4CDC-8828-F07C4E9E6FA2 is a Old Package, a newer package is installed in the system.
      3/26/2014 12:19:58 [INFO] PIM - Trying to access xml at path:C:\Users\Hamish\Desktop\temp\Software\Production\Build\Patches\AdobeApplicationManag er-1.0_update7\packages\DECore\DECore.pimx
      3/26/2014 12:19:58 [INFO] PIM - Package id 6D2A548B-C50D-46BA-B83E-C8199C6A9406 is a Old Package, a newer package is installed in the system.
      3/26/2014 12:19:58 [INFO] PIM - Trying to access xml at path:C:\Users\Hamish\Desktop\temp\Software\Production\Build\Patches\AdobeApplicationManag er-1.0_update7\packages\DWA\DWA.pimx
      3/26/2014 12:19:58 [INFO] PIM - Package id 99477136-88AD-496B-9551-BAE72699A32C is a Old Package, a newer package is installed in the system.
      3/26/2014 12:19:58 [INFO] PIM - Trying to access xml at path:C:\Users\Hamish\Desktop\temp\Software\Production\Build\Patches\AdobeApplicationManag er-1.0_update7\packages\P6\P6.pimx
      3/26/2014 12:19:58 [INFO] PIM - Package id FAFC744B-DDFB-4097-A41D-7E9539FEBAF9 is a Old Package, a newer package is installed in the system.
      3/26/2014 12:19:58 [INFO] PIM - Trying to access xml at path:C:\Users\Hamish\Desktop\temp\Software\Production\Build\Patches\AdobeApplicationManag er-1.0_update7\packages\LWA\LWA.pimx
      3/26/2014 12:19:58 [INFO] PIM - Package id B322281B-C04F-438E-82D7-7DA34A359526 is already installed
      3/26/2014 12:19:58 [INFO] PIM - Trying to access xml at path:C:\Users\Hamish\Desktop\temp\Software\Production\Build\Patches\AdobeApplicationManag er-1.0_update7\packages\UWA\UWA.pimx
      3/26/2014 12:19:58 [INFO] PIM - Package id B1313DE3-08DF-4834-91D9-CBD1A91488E5 is a Old Package, a newer package is installed in the system.
      3/26/2014 12:19:58 [INFO] PIM - Trying to access xml at path:C:\Users\Hamish\Desktop\temp\Software\Production\Build\Patches\AdobeApplicationManag er-1.0_update7\packages\CCM\CCM.pimx
      3/26/2014 12:19:58 [INFO] PIM - Package id F0158AAB-0779-4B40-A07D-3F2A21D47E74 is a Old Package, a newer package is installed in the system.
      3/26/2014 12:19:58 [INFO] PIM - pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 12067961
      3/26/2014 12:19:58 [INFO] Setup - TimeLog: End initial checks
      3/26/2014 12:19:58 [INFO] Setup - TimeLog: Begin Installing
      3/26/2014 12:19:58 [INFO] Setup - Start Installing core package - C:\Users\Hamish\Desktop\temp\Software\Production\Build\Patches\AdobeApplicationManager-1. 0_update7\packages\core\PDApp.pimx
      3/26/2014 12:19:58 [INFO] PIM - START installPackage at file C:\Users\Hamish\Desktop\temp\Software\Production\Build\Patches\AdobeApplicationManager-1. 0_update7\packages\core\PDApp.pimx
      3/26/2014 12:19:58 [INFO] PIM - NOTE package id 5AA1D762-31AF-4FC3-A0C0-66BF663B2117 is a Old Package, a newer package is installed in the system.
      3/26/2014 12:19:58 [INFO] Setup - Finished Installing core package - C:\Users\Hamish\Desktop\temp\Software\Production\Build\Patches\AdobeApplicationManager-1. 0_update7\packages\core\PDApp.pimx, Return status: 40
      3/26/2014 12:19:58 [INFO] Setup - Start Installing package - C:\Users\Hamish\Desktop\temp\Software\Production\Build\Patches\AdobeApplicationManager-1. 0_update7\packages\D6\D6.pimx
      3/26/2014 12:19:58 [INFO] PIM - START installPackage at file C:\Users\Hamish\Desktop\temp\Software\Production\Build\Patches\AdobeApplicationManager-1. 0_update7\packages\D6\D6.pimx
      3/26/2014 12:19:58 [INFO] PIM - NOTE package id 54FD72DC-72EC-4CDC-8828-F07C4E9E6FA2 is a Old Package, a newer package is installed in the system.
      3/26/2014 12:19:58 [INFO] Setup - Finished Installing package - C:\Users\Hamish\Desktop\temp\Software\Production\Build\Patches\AdobeApplicationManager-1. 0_update7\packages\D6\D6.pimx
      3/26/2014 12:19:58 [INFO] Setup - Start Installing package - C:\Users\Hamish\Desktop\temp\Software\Production\Build\Patches\AdobeApplicationManager-1. 0_update7\packages\DECore\DECore.pimx
      3/26/2014 12:19:58 [INFO] PIM - START installPackage at file C:\Users\Hamish\Desktop\temp\Software\Production\Build\Patches\AdobeApplicationManager-1. 0_update7\packages\DECore\DECore.pimx
      3/26/2014 12:19:58 [INFO] PIM - NOTE package id 6D2A548B-C50D-46BA-B83E-C8199C6A9406 is a Old Package, a newer package is installed in the system.
      3/26/2014 12:19:58 [INFO] Setup - Finished Installing package - C:\Users\Hamish\Desktop\temp\Software\Production\Build\Patches\AdobeApplicationManager-1. 0_update7\packages\DECore\DECore.pimx
      3/26/2014 12:19:58 [INFO] Setup - Start Installing package - C:\Users\Hamish\Desktop\temp\Software\Production\Build\Patches\AdobeApplicationManager-1. 0_update7\packages\DWA\DWA.pimx
      3/26/2014 12:19:58 [INFO] PIM - START installPackage at file C:\Users\Hamish\Desktop\temp\Software\Production\Build\Patches\AdobeApplicationManager-1. 0_update7\packages\DWA\DWA.pimx
      3/26/2014 12:19:58 [INFO] PIM - NOTE package id 99477136-88AD-496B-9551-BAE72699A32C is a Old Package, a newer package is installed in the system.
      3/26/2014 12:19:58 [INFO] Setup - Finished Installing package - C:\Users\Hamish\Desktop\temp\Software\Production\Build\Patches\AdobeApplicationManager-1. 0_update7\packages\DWA\DWA.pimx
      3/26/2014 12:19:58 [INFO] Setup - Start Installing package - C:\Users\Hamish\Desktop\temp\Software\Production\Build\Patches\AdobeApplicationManager-1. 0_update7\packages\P6\P6.pimx
      3/26/2014 12:19:58 [INFO] PIM - START installPackage at file C:\Users\Hamish\Desktop\temp\Software\Production\Build\Patches\AdobeApplicationManager-1. 0_update7\packages\P6\P6.pimx
      3/26/2014 12:19:58 [INFO] PIM - NOTE package id FAFC744B-DDFB-4097-A41D-7E9539FEBAF9 is a Old Package, a newer package is installed in the system.
      3/26/2014 12:19:58 [INFO] Setup - Finished Installing package - C:\Users\Hamish\Desktop\temp\Software\Production\Build\Patches\AdobeApplicationManager-1. 0_update7\packages\P6\P6.pimx
      3/26/2014 12:19:58 [INFO] Setup - Start Installing package - C:\Users\Hamish\Desktop\temp\Software\Production\Build\Patches\AdobeApplicationManager-1. 0_update7\packages\LWA\LWA.pimx
      3/26/2014 12:19:58 [INFO] PIM - START installPackage at file C:\Users\Hamish\Desktop\temp\Software\Production\Build\Patches\AdobeApplicationManager-1. 0_update7\packages\LWA\LWA.pimx
      3/26/2014 12:19:58 [INFO] PIM - Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\Patches\AdobeApplicationManager-1 .0_update7\packages\LWA\LWA.pimx'
      3/26/2014 12:19:58 [INFO] PIM - Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\Patches\AdobeApplicationManager-1 .0_update7\packages\LWA\LWA.pima'
      3/26/2014 12:19:58 [INFO] PIM - SUCCESS deleteAppletRegInfoRecords.
      3/26/2014 12:19:58 [INFO] PIM - SUCCESS deletePackageUpgradeInfoRecords.
      3/26/2014 12:19:58 [INFO] PIM - SUCCESS deletePackageInstallationInfoRecords.
      3/26/2014 12:19:58 [INFO] PIM - SUCCESS insertPackageUpdateList.
      3/26/2014 12:19:58 [INFO] PIM - SUCCESS insertAppletRegInfoList.
      3/26/2014 12:19:58 [INFO] PIM - Backup Folder Created
      3/26/2014 12:19:59 [INFO] Utilities - File does not exist
      3/26/2014 12:20:01 [INFO] PIM - SUCCESS installPackage at file C:\Users\Hamish\Desktop\temp\Software\Production\Build\Patches\AdobeApplicationManager-1. 0_update7\packages\LWA\LWA.pimx.
      3/26/2014 12:20:01 [INFO] Setup - Finished Installing package - C:\Users\Hamish\Desktop\temp\Software\Production\Build\Patches\AdobeApplicationManager-1. 0_update7\packages\LWA\LWA.pimx
      3/26/2014 12:20:01 [INFO] Setup - Start Installing package - C:\Users\Hamish\Desktop\temp\Software\Production\Build\Patches\AdobeApplicationManager-1. 0_update7\packages\UWA\UWA.pimx
      3/26/2014 12:20:01 [INFO] PIM - START installPackage at file C:\Users\Hamish\Desktop\temp\Software\Production\Build\Patches\AdobeApplicationManager-1. 0_update7\packages\UWA\UWA.pimx
      3/26/2014 12:20:01 [INFO] PIM - Trying to access xml at path:C:\Users\Hamish\Desktop\temp\Software\Production\Build\Patches\AdobeApplicationManag er-1.0_update7\packages\UWA\UWA.pimx
      3/26/2014 12:20:01 [INFO] PIM - XML is valid
      3/26/2014 12:20:01 [WARN] PIM - Failed to find Node
      3/26/2014 12:20:01 [INFO] PIM - NOTE package id B1313DE3-08DF-4834-91D9-CBD1A91488E5 is a Old Package, a newer package is installed in the system.
      3/26/2014 12:20:01 [INFO] Setup - Finished Installing package - C:\Users\Hamish\Desktop\temp\Software\Production\Build\Patches\AdobeApplicationManager-1. 0_update7\packages\UWA\UWA.pimx
      3/26/2014 12:20:01 [INFO] Setup - Start Installing package - C:\Users\Hamish\Desktop\temp\Software\Production\Build\Patches\AdobeApplicationManager-1. 0_update7\packages\CCM\CCM.pimx
      3/26/2014 12:20:01 [INFO] PIM - START installPackage at file C:\Users\Hamish\Desktop\temp\Software\Production\Build\Patches\AdobeApplicationManager-1. 0_update7\packages\CCM\CCM.pimx
      3/26/2014 12:20:01 [INFO] PIM - Trying to access xml at path:C:\Users\Hamish\Desktop\temp\Software\Production\Build\Patches\AdobeApplicationManag er-1.0_update7\packages\CCM\CCM.pimx
      3/26/2014 12:20:01 [INFO] PIM - NOTE package id F0158AAB-0779-4B40-A07D-3F2A21D47E74 is a Old Package, a newer package is installed in the system.
      3/26/2014 12:20:01 [INFO] Setup - Finished Installing package - C:\Users\Hamish\Desktop\temp\Software\Production\Build\Patches\AdobeApplicationManager-1. 0_update7\packages\CCM\CCM.pimx
      3/26/2014 12:20:01 [INFO] PIM - Processing ... _pimCreateOrUpdateAAMInventory
      3/26/2014 12:20:01 [INFO] PIM - Higher version of AAM Updater inventory is already present in the machine. So skipping the creation of AAM Updater Inventory
      3/26/2014 12:20:01 [INFO] PIM - Return ... SUCCESS _pimCreateOrUpdateAAMInventory
      3/26/2014 12:20:01 [INFO] Setup - TimeLog: End Installing. Now launching PDApp
      3/26/2014 12:20:01 [INFO] Setup - =================  End Adobe Setup. Exit code: 0  =================
      3/26/2014 12:20:01 [INFO] PIM - PIMSqlite closeDB status 0
      3/26/2014 12:20:01 [INFO] PIM - FREE PIM Instance ...
      03/26/14 12:20:02:090 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Build Version - 1.4.0.37
      03/26/14 12:20:02:090 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Logging Level verbosity Set  to 4
      03/26/14 12:20:02:090 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | The return code from the Bootstrapper Process is (0).
      03/26/14 12:20:02:090 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | SelfUpdate Path - C:\Users\Hamish\Desktop\temp\Software\Production\Build\Patches\AdobeApplicationManager-1. 0_update7
      03/26/14 12:20:02:090 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | STEP 3: Starting to launch Bootstrapper of Media (PHSP14.0en_GB).
      03/26/14 12:20:02:153 | [INFO] |  | ASU | DeploymentManager | Utilities |  |  | 2144 | Folder does not exist
      03/26/14 12:20:02:153 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Bootstrapper launch location is :: C:\Users\Hamish\Desktop\temp\Software\Production\Build\Setup\PHSP14.0en_GB\Set-up.dat
      03/26/14 12:20:02:324 | [INFO] |  | ASU | Setup | Setup |  |  | 2372 | Build Version - 7.0.0.324
      03/26/14 12:20:02:324 | [INFO] |  | ASU | Setup | Setup |  |  | 2372 | Logging Level verbosity Set  to 4
      03/26/14 12:20:02:324 | [INFO] |  | ASU | Setup | Utilities |  |  | 2372 | File 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\core\AAMConfig.xml' does not exist
      03/26/14 12:20:02:324 | [INFO] |  | ASU | Setup |  |  |  | 2372 | Event Guid generated is: 'eadc6aff-7d2e-4e6b-a4b0-ff47f04e433f'
      03/26/14 12:20:02:324 | [INFO] |  | ASU | Setup | Setup |  |  | 2372 | Start Adobe Setup
      03/26/14 12:20:02:324 | [INFO] |  | ASU | Setup | Setup |  |  | 2372 | TimeLog: Bootstrapper Start
      03/26/14 12:20:02:324 | [INFO] |  | ASU | Setup | Setup |  |  | 2372 | TimeLog: Start initial checks
      03/26/14 12:20:02:324 | [INFO] |  | ASU | Setup | Setup |  |  | 2372 | Action specified - "install"
      03/26/14 12:20:02:340 | [INFO] |  | ASU | Setup |  |  |  | 2400 | Event with guid 'eadc6aff-7d2e-4e6b-a4b0-ff47f04e433f' is being sent
      03/26/14 12:20:02:340 | [INFO] |  | ASU | Setup |  |  |  | 2400 | GetIEProxyInfo - No default proxy present on the user machine
      03/26/14 12:20:02:340 | [INFO] |  | ASU | Setup |  |  |  | 2400 | GetIEProxyInfo - proxy Url is
      03/26/14 12:20:03:245 | [INFO] |  | ASU | Setup | PIM |  |  | 2372 | XML is valid
      03/26/14 12:20:03:245 | [WARN] |  | ASU | Setup | PIM |  |  | 2372 | Failed to find Node
      03/26/14 12:20:03:245 | [WARN] |  | ASU | Setup | Setup |  |  | 2372 | Reboot is pending from earlier installation.
      03/26/14 12:20:03:292 | [INFO] |  | ASU | Setup | Utilities |  |  | 2372 | Semaphore is not locked
      03/26/14 12:20:03:292 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | Build Version - 7.0.0.324
      03/26/14 12:20:03:292 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | Logging Level verbosity Set  to 4
      03/26/14 12:20:03:292 | [INFO] |  | ASU | PIM | Utilities |  |  | 2372 | File 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\pim.db-journal' does not exist
      03/26/14 12:20:03:292 | [INFO] |  | ASU | PIM | Utilities |  |  | 2372 | File 'C:\Users\TECHSU~1\AppData\Local\Temp\\asuap.txt' does not exist
      03/26/14 12:20:03:292 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | CREATE PIM Instance ...
      03/26/14 12:20:03:292 | [INFO] |  | ASU | PIM | Utilities |  |  | 2372 | File 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\pim.db-journal' does not exist
      03/26/14 12:20:03:292 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | trying to createOrUpdatePIMDbSchema.
      03/26/14 12:20:03:292 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | Current db schema version on machine 1.
      03/26/14 12:20:03:292 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | Current db schema version to install 1.
      03/26/14 12:20:03:292 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | PIM DB Schema is up to date. Current schema version is 1.
      03/26/14 12:20:03:292 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | PIM Database is Up To Date.
      03/26/14 12:20:03:292 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | Updater Inventory location:C:\Users\Hamish\Desktop\temp\Software\Production\Build\Setup\PHSP14.0en_GB\resou rces\updaterinventory.dll
      03/26/14 12:20:03:323 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | Acquired System level ACF lock ...
      03/26/14 12:20:03:323 | [INFO] |  | ASU | Setup | Setup |  |  | 2372 | TimeLog: End initial checks
      03/26/14 12:20:03:323 | [INFO] |  | ASU | Setup | Setup |  |  | 2372 | TimeLog: Begin Installing
      03/26/14 12:20:03:323 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | Current OS version is: Major:6, Minor:1, ServicePack:1
      03/26/14 12:20:03:338 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | XML is valid
      03/26/14 12:20:03:338 | [WARN] |  | ASU | PIM | PIM |  |  | 2372 | Failed to find Node
      03/26/14 12:20:03:338 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | Package id 641563BC-5FB7-4196-9601-4F601264993F is a Old Package, a newer package is installed in the system.
      03/26/14 12:20:03:354 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | XML is valid
      03/26/14 12:20:03:354 | [WARN] |  | ASU | PIM | PIM |  |  | 2372 | Failed to find Node
      03/26/14 12:20:03:354 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | Package id BA766F12-BE9C-4379-91C3-58F25E139016 is a Old Package, a newer package is installed in the system.
      03/26/14 12:20:03:370 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | XML is valid
      03/26/14 12:20:03:370 | [WARN] |  | ASU | PIM | PIM |  |  | 2372 | Failed to find Node
      03/26/14 12:20:03:370 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | Package id 4919ECF4-E77F-4B20-A59B-F64405B27C9C is a Old Package, a newer package is installed in the system.
      03/26/14 12:20:03:385 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | XML is valid
      03/26/14 12:20:03:385 | [WARN] |  | ASU | PIM | PIM |  |  | 2372 | Failed to find Node
      03/26/14 12:20:03:385 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | Package id 99477136-88AD-496B-9551-BAE72699A32C is a Old Package, a newer package is installed in the system.
      03/26/14 12:20:03:401 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | XML is valid
      03/26/14 12:20:03:401 | [WARN] |  | ASU | PIM | PIM |  |  | 2372 | Failed to find Node
      03/26/14 12:20:03:401 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | Package id 429FE862-5E6B-4361-833D-C2FF90E4D79D is a Old Package, a newer package is installed in the system.
      03/26/14 12:20:03:416 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | XML is valid
      03/26/14 12:20:03:416 | [WARN] |  | ASU | PIM | PIM |  |  | 2372 | Failed to find Node
      03/26/14 12:20:03:416 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | Package id B322281B-C04F-438E-82D7-7DA34A359526 is already installed
      03/26/14 12:20:03:432 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | XML is valid
      03/26/14 12:20:03:432 | [WARN] |  | ASU | PIM | PIM |  |  | 2372 | Failed to find Node
      03/26/14 12:20:03:432 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | Package id 9D663CEF-4B15-4D98-8021-0387A0BB4A9C is a Old Package, a newer package is installed in the system.
      03/26/14 12:20:03:448 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | XML is valid
      03/26/14 12:20:03:448 | [WARN] |  | ASU | PIM | PIM |  |  | 2372 | Failed to find Node
      03/26/14 12:20:03:448 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | Package id 0C391415-DEAB-4A0B-ABBD-116054284845 is a Old Package, a newer package is installed in the system.
      03/26/14 12:20:03:463 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | XML is valid
      03/26/14 12:20:03:463 | [WARN] |  | ASU | PIM | PIM |  |  | 2372 | Failed to find Node
      03/26/14 12:20:03:463 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | Package id C231243C-63C8-49E5-9457-F187ED30904D is a Old Package, a newer package is installed in the system.
      03/26/14 12:20:03:463 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 12067961
      03/26/14 12:20:03:463 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | Executing Adobe Genuine Validation for all the AAM packages
      03/26/14 12:20:03:463 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\Setup\PHSP14.0en_GB\packages\core \PDApp.pimx'
      03/26/14 12:20:03:479 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\Setup\PHSP14.0en_GB\packages\core \PDApp.pima'
      03/26/14 12:20:03:588 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\Setup\PHSP14.0en_GB\packages\D6\D 6.pimx'
      03/26/14 12:20:03:604 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\Setup\PHSP14.0en_GB\packages\D6\D 6.pima'
      03/26/14 12:20:03:635 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\Setup\PHSP14.0en_GB\packages\DECo re\DECore.pimx'
      03/26/14 12:20:03:635 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\Setup\PHSP14.0en_GB\packages\DECo re\DECore.pima'
      03/26/14 12:20:03:744 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\Setup\PHSP14.0en_GB\packages\DWA\ DWA.pimx'
      03/26/14 12:20:03:760 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\Setup\PHSP14.0en_GB\packages\DWA\ DWA.pima'
      03/26/14 12:20:03:806 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\Setup\PHSP14.0en_GB\packages\P6\P 6.pimx'
      03/26/14 12:20:03:822 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\Setup\PHSP14.0en_GB\packages\P6\P 6.pima'
      03/26/14 12:20:03:916 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\Setup\PHSP14.0en_GB\packages\LWA\ LWA.pimx'
      03/26/14 12:20:03:931 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\Setup\PHSP14.0en_GB\packages\LWA\ LWA.pima'
      03/26/14 12:20:03:994 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\Setup\PHSP14.0en_GB\packages\UWA\ UWA.pimx'
      03/26/14 12:20:04:009 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\Setup\PHSP14.0en_GB\packages\UWA\ UWA.pima'
      03/26/14 12:20:04:072 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\Setup\PHSP14.0en_GB\packages\CCM\ CCM.pimx'
      03/26/14 12:20:04:087 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\Setup\PHSP14.0en_GB\packages\CCM\ CCM.pima'
      03/26/14 12:20:04:150 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\Setup\PHSP14.0en_GB\packages\P7\P 7.pimx'
      03/26/14 12:20:04:165 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | Validating package file: 'C:\Users\Hamish\Desktop\temp\Software\Production\Build\Setup\PHSP14.0en_GB\packages\P7\P 7.pima'
      03/26/14 12:20:04:243 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | Adobe Genuine Validation PASSED for all the AAM packages
      03/26/14 12:20:04:243 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | START installPackage at file C:\Users\Hamish\Desktop\temp\Software\Production\Build\Setup\PHSP14.0en_GB\packages\core\ PDApp.pimx
      03/26/14 12:20:04:243 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | XML is valid
      03/26/14 12:20:04:243 | [WARN] |  | ASU | PIM | PIM |  |  | 2372 | Failed to find Node
      03/26/14 12:20:04:243 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | NOTE package id 641563BC-5FB7-4196-9601-4F601264993F is a Old Package, a newer package is installed in the system.
      03/26/14 12:20:04:243 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | START installPackage at file C:\Users\Hamish\Desktop\temp\Software\Production\Build\Setup\PHSP14.0en_GB\packages\D6\D6 .pimx
      03/26/14 12:20:04:243 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | NOTE package id BA766F12-BE9C-4379-91C3-58F25E139016 is a Old Package, a newer package is installed in the system.
      03/26/14 12:20:04:243 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | START installPackage at file C:\Users\Hamish\Desktop\temp\Software\Production\Build\Setup\PHSP14.0en_GB\packages\DECor e\DECore.pimx
      03/26/14 12:20:04:243 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | NOTE package id 4919ECF4-E77F-4B20-A59B-F64405B27C9C is a Old Package, a newer package is installed in the system.
      03/26/14 12:20:04:243 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | START installPackage at file C:\Users\Hamish\Desktop\temp\Software\Production\Build\Setup\PHSP14.0en_GB\packages\DWA\D WA.pimx
      03/26/14 12:20:04:243 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | NOTE package id 99477136-88AD-496B-9551-BAE72699A32C is a Old Package, a newer package is installed in the system.
      03/26/14 12:20:04:243 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | START installPackage at file C:\Users\Hamish\Desktop\temp\Software\Production\Build\Setup\PHSP14.0en_GB\packages\P6\P6 .pimx
      03/26/14 12:20:04:259 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | XML is valid
      03/26/14 12:20:04:259 | [WARN] |  | ASU | PIM | PIM |  |  | 2372 | Failed to find Node
      03/26/14 12:20:04:259 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | NOTE package id 429FE862-5E6B-4361-833D-C2FF90E4D79D is a Old Package, a newer package is installed in the system.
      03/26/14 12:20:04:259 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | START installPackage at file C:\Users\Hamish\Desktop\temp\Software\Production\Build\Setup\PHSP14.0en_GB\packages\LWA\L WA.pimx
      03/26/14 12:20:04:259 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | Package id B322281B-C04F-438E-82D7-7DA34A359526 is already installed
      03/26/14 12:20:04:368 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | SUCCESS deleteAppletRegInfoRecords.
      03/26/14 12:20:04:368 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | SUCCESS deletePackageUpgradeInfoRecords.
      03/26/14 12:20:04:368 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | SUCCESS deletePackageInstallationInfoRecords.
      03/26/14 12:20:04:399 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | SUCCESS insertPackageUpdateList.
      03/26/14 12:20:04:399 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | SUCCESS insertAppletRegInfoList.
      03/26/14 12:20:04:415 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | Backup Folder Created
      03/26/14 12:20:04:430 | [WARN] |  | ASU | PIM | PIM |  |  | 2372 | Failed to find Node
      03/26/14 12:20:06:022 | [INFO] |  | ASU | PIM | Utilities |  |  | 2372 | File 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\LWA\LWA.pimx' does not exist
      03/26/14 12:20:06:536 | [INFO] |  | ASU | Setup |  |  |  | 2816 | HTTP Request Status code 200.
      03/26/14 12:20:06:536 | [INFO] |  | ASU | Setup |  |  |  | 2400 | The http request returned HTTP_Status:0 HttpCommunicator error:0
      03/26/14 12:20:07:441 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | SUCCESS installPackage at file C:\Users\Hamish\Desktop\temp\Software\Production\Build\Setup\PHSP14.0en_GB\packages\LWA\L WA.pimx.
      03/26/14 12:20:07:738 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | START installPackage at file C:\Users\Hamish\Desktop\temp\Software\Production\Build\Setup\PHSP14.0en_GB\packages\UWA\U WA.pimx
      03/26/14 12:20:07:738 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | XML is valid
      03/26/14 12:20:07:738 | [WARN] |  | ASU | PIM | PIM |  |  | 2372 | Failed to find Node
      03/26/14 12:20:07:738 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | NOTE package id 9D663CEF-4B15-4D98-8021-0387A0BB4A9C is a Old Package, a newer package is installed in the system.
      03/26/14 12:20:07:738 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | START installPackage at file C:\Users\Hamish\Desktop\temp\Software\Production\Build\Setup\PHSP14.0en_GB\packages\CCM\C CM.pimx
      03/26/14 12:20:07:753 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | XML is valid
      03/26/14 12:20:07:753 | [WARN] |  | ASU | PIM | PIM |  |  | 2372 | Failed to find Node
      03/26/14 12:20:07:753 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | NOTE package id 0C391415-DEAB-4A0B-ABBD-116054284845 is a Old Package, a newer package is installed in the system.
      03/26/14 12:20:07:753 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | START installPackage at file C:\Users\Hamish\Desktop\temp\Software\Production\Build\Setup\PHSP14.0en_GB\packages\P7\P7 .pimx
      03/26/14 12:20:07:753 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | NOTE package id C231243C-63C8-49E5-9457-F187ED30904D is a Old Package, a newer package is installed in the system.
      03/26/14 12:20:07:894 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | Processing ... _pimCreateOrUpdateAAMInventory
      03/26/14 12:20:07:909 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | Higher version of AAM Updater inventory is already present in the machine. So skipping the creation of AAM Updater Inventory
      03/26/14 12:20:07:909 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | Return ... SUCCESS _pimCreateOrUpdateAAMInventory
      03/26/14 12:20:07:909 | [INFO] |  | ASU | Setup | Setup |  |  | 2372 | TimeLog: End Installing. Now launching PDApp
      03/26/14 12:20:08:424 | [INFO] |  | ASU | Setup | Setup |  |  | 2372 | Deployment File Path not specified in command line arguments. Skipping payload deployment part
      03/26/14 12:20:08:424 | [INFO] |  | ASU | Setup |  |  |  | 2372 | Event Guid generated is: 'e65d7e43-74f8-4cb4-a2e3-f7d96e6ff75a'
      03/26/14 12:20:08:424 | [INFO] |  | ASU | Setup | Setup |  |  | 2372 | =================  End Adobe Setup. Exit code: 0  =================
      03/26/14 12:20:08:424 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | PIMSqlite closeDB status 0
      03/26/14 12:20:08:424 | [INFO] |  | ASU | PIM | PIM |  |  | 2372 | FREE PIM Instance ...
      03/26/14 12:20:08:424 | [INFO] |  | ASU | Setup |  |  |  | 2372 | Waiting for the async thread to get the task completed
      03/26/14 12:20:08:440 | [INFO] |  | ASU | Setup |  |  |  | 2400 | Event with guid 'e65d7e43-74f8-4cb4-a2e3-f7d96e6ff75a' is being sent
      03/26/14 12:20:08:440 | [INFO] |  | ASU | Setup |  |  |  | 2400 | GetIEProxyInfo - No default proxy present on the user machine
      03/26/14 12:20:08:440 | [INFO] |  | ASU | Setup |  |  |  | 2400 | GetIEProxyInfo - proxy Url is
      03/26/14 12:20:11:450 | [INFO] |  | ASU | Setup |  |  |  | 2816 | HTTP Request Status code 200.
      03/26/14 12:20:11:450 | [INFO] |  | ASU | Setup |  |  |  | 2400 | The http request returned HTTP_Status:0 HttpCommunicator error:0
      03/26/14 12:20:11:450 | [INFO] |  | ASU | Setup |  |  |  | 2400 | Async thread is completed. Now exiting from function.
      03/26/14 12:20:11:466 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Build Version - 1.4.0.37
      03/26/14 12:20:11:466 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Logging Level verbosity Set  to 4
      03/26/14 12:20:11:466 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | The return code from the Bootstrapper Process is (0).
      03/26/14 12:20:11:466 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Correcting Dependencies in local db.
      03/26/14 12:20:16:130 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | STEP 4: Starting to launch Adobe Installer.
      03/26/14 12:20:16:130 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Obtained Adobe Common Folder Path.
      03/26/14 12:20:16:130 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Adobe Installer launch location is :: C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\Setup.exe
      03/26/14 12:20:16:146 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | deploymentFile = (C:\Users\TECHSU~1\AppData\Local\Temp\{EC9F799F-2AEF-4C68-8222-390BF290B84E}\\{BF8D9B50-E 74C-4185-9751-4CF429827622}), installSourcePath = (C:\Users\Hamish\Desktop\temp\Software\Production\Build\Setup\PHSP14.0en_GB)
      03/26/14 12:20:26:614 | [INFO] |  | ASU | DeploymentManager | AAMEEUtilities |  |  | 2144 | Process creation completed.
      03/26/14 12:20:26:614 | [FATAL] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | The return code from the Adobe Installer Process is (34).Stopping the installation process.
      03/26/14 12:20:26:614 | [ERROR] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Media Failed (PHSP14.0en_GB)
      03/26/14 12:20:26:614 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Starting to clean the partially installed payloads.
      03/26/14 12:20:26:723 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Undeployment XML created at path :: C:\Users\TECHSU~1\AppData\Local\Temp\{EC9F799F-2AEF-4C68-8222-390BF290B84E}\\{CB2F55F2-DE CD-4A8D-8265-505B0718A6F4}
      03/26/14 12:20:26:723 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Starting to launch the Adobe Installer for uninstall mode.
      03/26/14 12:20:26:723 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Obtained Adobe Common Folder Path.
      03/26/14 12:20:26:723 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\Setup.exe
      03/26/14 12:20:27:799 | [INFO] |  | ASU | PIM-Uninstall | PIM-Uninstall |  |  | 1480 | Build Version - 8.0.0.22
      03/26/14 12:20:27:799 | [INFO] |  | ASU | PIM-Uninstall | PIM-Uninstall |  |  | 1480 | Logging Level verbosity Set  to 4
      03/26/14 12:20:27:799 | [INFO] |  | ASU | PIM-Uninstall | PIM-Uninstall |  |  | 1480 | Start: Adobe Application Manager Uninstall...
      03/26/14 12:20:27:799 | [INFO] |  | ASU | PIM-Uninstall | PIM-Uninstall |  |  | 1480 | Get RIBS Product count
      03/26/14 12:20:27:830 | [INFO] |  | ASU | PIM-Uninstall | PIM-Uninstall |  |  | 1480 | RIBS Products install status :1
      03/26/14 12:20:27:830 | [INFO] |  | ASU | PIM-Uninstall | PIM-Uninstall |  |  | 1480 | There are some ribs products using AAM. RIBS product use flag is 1.
      03/26/14 12:20:27:830 | [INFO] |  | ASU | DeploymentManager | AAMEEUtilities |  |  | 2144 | Process creation completed.
      03/26/14 12:20:27:830 | [FATAL] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | The return code from the Adobe Installer Process is (33).Stopping the uninstallation process.
      03/26/14 12:20:27:940 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Undeployment XML created at path :: C:\Users\TECHSU~1\AppData\Local\Temp\{EC9F799F-2AEF-4C68-8222-390BF290B84E}\\{E77F075F-B6 70-4BF2-B29A-DEC71AFEB890}
      03/26/14 12:20:27:940 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Starting to launch the Adobe Installer for uninstall mode.
      03/26/14 12:20:27:940 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Obtained Adobe Common Folder Path.
      03/26/14 12:20:27:940 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\Setup.exe
      03/26/14 12:20:28:064 | [INFO] |  | ASU | DeploymentManager | AAMEEUtilities |  |  | 2144 | Process creation completed.
      03/26/14 12:20:28:064 | [FATAL] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | The return code from the Adobe Installer Process is (33).Stopping the uninstallation process.
      03/26/14 12:20:28:080 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Undeployment XML created at path :: C:\Users\TECHSU~1\AppData\Local\Temp\{EC9F799F-2AEF-4C68-8222-390BF290B84E}\\{2C5A2FB3-7F 72-47C5-916F-8A396DDF3FCB}
      03/26/14 12:20:28:080 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Starting to launch the Adobe Installer for uninstall mode.
      03/26/14 12:20:28:080 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Obtained Adobe Common Folder Path.
      03/26/14 12:20:28:080 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\Setup.exe
      03/26/14 12:20:28:158 | [INFO] |  | ASU | DeploymentManager | AAMEEUtilities |  |  | 2144 | Process creation completed.
      03/26/14 12:20:28:158 | [FATAL] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | The return code from the Adobe Installer Process is (33).Stopping the uninstallation process.
      03/26/14 12:20:28:174 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Undeployment XML created at path :: C:\Users\TECHSU~1\AppData\Local\Temp\{EC9F799F-2AEF-4C68-8222-390BF290B84E}\\{02FD8DE6-12 09-4D13-AEC8-C4BBE0987158}
      03/26/14 12:20:28:174 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Starting to launch the Adobe Installer for uninstall mode.
      03/26/14 12:20:28:174 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Obtained Adobe Common Folder Path.
      03/26/14 12:20:28:174 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\Setup.exe
      03/26/14 12:20:28:236 | [INFO] |  | ASU | DeploymentManager | AAMEEUtilities |  |  | 2144 | Process creation completed.
      03/26/14 12:20:28:236 | [FATAL] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | The return code from the Adobe Installer Process is (33).Stopping the uninstallation process.
      03/26/14 12:20:28:314 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Undeployment XML created at path :: C:\Users\TECHSU~1\AppData\Local\Temp\{EC9F799F-2AEF-4C68-8222-390BF290B84E}\\{5D67EB36-79 F1-4C76-A027-449486A5D20F}
      03/26/14 12:20:28:314 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Starting to launch the Adobe Installer for uninstall mode.
      03/26/14 12:20:28:314 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Obtained Adobe Common Folder Path.
      03/26/14 12:20:28:314 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\Setup.exe
      03/26/14 12:20:28:439 | [INFO] |  | ASU | DeploymentManager | AAMEEUtilities |  |  | 2144 | Process creation completed.
      03/26/14 12:20:28:439 | [FATAL] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | The return code from the Adobe Installer Process is (33).Stopping the uninstallation process.
      03/26/14 12:20:28:501 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Undeployment XML created at path :: C:\Users\TECHSU~1\AppData\Local\Temp\{EC9F799F-2AEF-4C68-8222-390BF290B84E}\\{EA653537-19 08-4241-97AE-D97C55AE6425}
      03/26/14 12:20:28:501 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Starting to launch the Adobe Installer for uninstall mode.
      03/26/14 12:20:28:501 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Obtained Adobe Common Folder Path.
      03/26/14 12:20:28:501 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\Setup.exe
      03/26/14 12:20:28:610 | [INFO] |  | ASU | DeploymentManager | AAMEEUtilities |  |  | 2144 | Process creation completed.
      03/26/14 12:20:28:610 | [FATAL] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | The return code from the Adobe Installer Process is (33).Stopping the uninstallation process.
      03/26/14 12:20:28:626 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Undeployment XML created at path :: C:\Users\TECHSU~1\AppData\Local\Temp\{EC9F799F-2AEF-4C68-8222-390BF290B84E}\\{D161DB13-A8 14-4ACB-8EF6-E2A317CBDDC8}
      03/26/14 12:20:28:626 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Starting to launch the Adobe Installer for uninstall mode.
      03/26/14 12:20:28:626 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Obtained Adobe Common Folder Path.
      03/26/14 12:20:28:626 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\Setup.exe
      03/26/14 12:20:28:782 | [INFO] |  | ASU | DeploymentManager | AAMEEUtilities |  |  | 2144 | Process creation completed.
      03/26/14 12:20:28:782 | [FATAL] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | The return code from the Adobe Installer Process is (33).Stopping the uninstallation process.
      03/26/14 12:20:28:829 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Undeployment XML created at path :: C:\Users\TECHSU~1\AppData\Local\Temp\{EC9F799F-2AEF-4C68-8222-390BF290B84E}\\{907E7D9F-08 A9-4159-A172-94F6A056D04C}
      03/26/14 12:20:28:829 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Starting to launch the Adobe Installer for uninstall mode.
      03/26/14 12:20:28:829 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Obtained Adobe Common Folder Path.
      03/26/14 12:20:28:829 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\Setup.exe
      03/26/14 12:20:28:938 | [INFO] |  | ASU | DeploymentManager | AAMEEUtilities |  |  | 2144 | Process creation completed.
      03/26/14 12:20:28:938 | [FATAL] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | The return code from the Adobe Installer Process is (33).Stopping the uninstallation process.
      03/26/14 12:20:29:016 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Undeployment XML created at path :: C:\Users\TECHSU~1\AppData\Local\Temp\{EC9F799F-2AEF-4C68-8222-390BF290B84E}\\{735D5BB1-F8 97-4911-AE5E-2548F84999B9}
      03/26/14 12:20:29:016 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Starting to launch the Adobe Installer for uninstall mode.
      03/26/14 12:20:29:016 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | Obtained Adobe Common Folder Path.
      03/26/14 12:20:29:016 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\Setup.exe
      03/26/14 12:20:29:125 | [INFO] |  | ASU | DeploymentManager | AAMEEUtilities |  |  | 2144 | Process creation completed.
      03/26/14 12:20:29:125 | [FATAL] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | The return code from the Adobe Installer Process is (33).Stopping the uninstallation process.
      03/26/14 12:20:29:172 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2144 | The install workflow is terminating.
      03/26/14 12:20:29:578 | [INFO] |  | ASU | MSIInvoker | AAMEEUtilities |  |  | 1932 | Process creation completed.
      03/26/14 12:20:29:578 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 1932 | utilLaunchApplicationDeelevated : The return Code from Create Process (1603).
      Thanks in advance for any advice
