2 Replies Latest reply on Apr 8, 2014 12:21 AM by DBLjan
    [AS] replace fonts by script or change default font of "Replace font"-dialog (Minion)
    DBLjan Level 2
      Hello again,
      we are in the process of switching our ci-font to Myriad. Lots of documents will be changed in future, not by batch, but time after time by hand.
      I want to enhance my workflow a bit, keeping the steps towards this small.
      My 2 ideas are this:
      I need a AS-script, which changes our previous fonts Futura and Frutiger to the new upon execution. I would guess, there allready is a script for this. I would need that in AppleScript, to make our adjustments. I should be able to expand the list for the different styles of one font.
      Futura ND Book » Myriad Pro Regular
      Futura ND demibold » Myriad Pro Semibold
      Fritiger Next Pro Light Condesed » Myriad Pro Light Condesed
      If I understand the syntax of the script, i would add every font-style and the replacement.
      My second idea:
      To keep steps few, is there a way to ged rid of the default-font Minion in the "Replace font"-menu, that I only have to do the different styles but InD by default has Myriad in there?
      Any suggestions would be great!
        • 1. Re: [AS] replace fonts by script or change default font of "Replace font"-dialog (Minion)
          Ronald63 Level 4
          I wrote this script there a few years, I hope this can help you
          set myMissingDocFonts to {}
          set myInddFonts to {}
          set myOldTID to text item delimiters
          set text item delimiters to tab
          tell application "Adobe InDesign CS5"
              activate
              tell document 1
                  try
                      set myMissingDocFonts to get name of fonts whose status ≠ installed
                  end try
                  set myLen to length of myMissingDocFonts
              end tell
              set myInddFonts to get name of fonts
              if myLen = 0 then
                  set myFonts to myInddFonts
              else if myLen = 1 then
                  set myFonts to {":::Police absente:::"} & myMissingDocFonts & {":::Polices disponibles:::"} & myInddFonts
              else
                  set myFonts to {":::Polices absentes:::"} & myMissingDocFonts & {":::Polices disponibles:::"} & myInddFonts
              end if
              try
                  set myDialog to make dialog with properties {name:":::Polices dans les feuilles de styles de " & name of document 1 & ":::"}
              on error
                  display dialog "Veuillez ouvrir un document." with icon 2
                  return 0
              end try
              tell myDialog
                  tell (make dialog column)
                      tell (make border panel)
                              tell (make dialog row)
                                      make static text with properties {static label:"Rechercher:", min width:100}
                                      make static text with properties {static label:"Remplacer par:", min width:100}
                                  end tell
                                      set SearchFontDialog to make dropdown with properties {string list:myFonts, selected index:0}
                                      set ReplaceFontDialog to make dropdown with properties {string list:myInddFonts, selected index:0}
                                  end tell
                              end tell
                                      make static text with properties {static label:"", min width:100}
                                  end tell
                                      set ParagraphStyleDialog to make checkbox control with properties {static label:"Styles de paragraphes", checked state:true, min width:45}
                                      set CharacterStyleDialog to make checkbox control with properties {static label:"Styles de caractères", checked state:true, min width:45}
                                  end tell
                              end tell
                          end tell
                      end tell
                  end tell
              end tell
              set myResult to show myDialog
              if myResult then
                  tell document 1
                      set allParagraphStyle to every paragraph style
                      set allCharacterStyle to every character style
                      if checked state of ParagraphStyleDialog then
                          repeat with aParagraphStyle in allParagraphStyle
                              if name of applied font of aParagraphStyle = item ((selected index of SearchFontDialog) + 1) of myFonts then
                                  set applied font of aParagraphStyle to item ((selected index of ReplaceFontDialog) + 1) of myInddFonts
                              end if
                          end repeat
                      end if
                      if checked state of CharacterStyleDialog then
                          set mySearchFont to text items of item ((selected index of SearchFontDialog) + 1) of myFonts
                          set myReplaceFont to text items of item ((selected index of ReplaceFontDialog) + 1) of myInddFonts
                          repeat with aCharacterStyle in allCharacterStyle
                              if applied font of aCharacterStyle = (item 1 of mySearchFont) and font style of aCharacterStyle = (item 2 of mySearchFont) then
                                  set applied font of aCharacterStyle to item 1 of myReplaceFont
                                  set font style of aCharacterStyle to item 2 of myReplaceFont
                              end if
                          end repeat
                      end if
                  end tell
              end if
              destroy myDialog
          end tell
          set text item delimiters to myOldTID
          Regards
          • 2. Re: [AS] replace fonts by script or change default font of "Replace font"-dialog (Minion)
            DBLjan Level 2
            Well, thank you for your answer, this was helpful and I tried to make it work for me, but I couldnt…then I stumbled upon an other thread, and worked it around to this:
            tell application "Adobe InDesign CS5.5"
              activate
                      if not (exists active document) then
                                display dialog "Kein Dokument geöffnet." buttons {"Hmpf."} default button 1 with icon 2
                      else
                                set user interaction level of script preferences to never interact
              -- Suchabfragen speichern
                                set oldFTP to properties of find text preferences
                                set oldCTP to properties of change text preferences
              -- Wechsel
                                set find text preferences to nothing
                                set change text preferences to nothing
                                set properties of find text preferences to {applied font:"Futura ND", font style:"Bold"}
                                set properties of change text preferences to {applied font:"JaneAusten", font style:"NoSecret"}
              change text
              -- Suchabfragen wiederherstellen
                                set properties of find text preferences to oldFTP
                                set properties of change text preferences to oldCTP
                                set user interaction level of script preferences to interact with all
                      end if
            end tell
            Now I can add a whole bunch of converts for every font style. JaneAusten was a obvoius test, but it works.
