0 Replies Latest reply on Apr 2, 2014 2:23 PM by SmileySnr
    Filtering a dropdownlist
    SmileySnr
      Environment: FlashBuilder 4.6, Wamp 2.4 with Zend Framework.
      mySql
      7 base tables
      lecturers
      students
      modules
      ulms
      studentprogress
      studentmodules
      modulecontents
      I want to setup filtering across a number of the tables ... just one example is explained below;
      ModulesContents is a table which shows which ULMs are in which Module
      I use dropdownlists when  adding data to this table ...
      dropdownlist 1 (to list all the modules currently in the DB)
      dropdownlist 2 (to list all the ulms in the DB) and finally
      dropdownlist 3 (to list all the lecturers in the DB)
      These all work to a fashion. They all indeed return lists of all the elements in the database.
      Lets look at some data
      Modules Table
      Module1,Module2,Module3,...
      Ulms Table
      Ulm1, Ulm2,Ulm3,Ulm4,Ulm5,Ulm6,...
      Each module can contain upto 8 ULMs (Units of Learning Material).
      A sample ModuleContents table might look like
      Module 1 Ulm1
      Module 1 Ulm2
      Module 1 Ulm3
      Each time I click the dropdown menu for Ulms with Module1 selected, I see the full list of Ulms.
      What I would like to see is a filtered list based on what is NOT in the module already
      ie in this case ...
      Ulm4,Ulm5,Ulm6,...
      Any idea How I could do this?
      Any help would be appreciated
