I've tried everything I know of to get Flash to install correctly. I've read all the FAQ and related info but nothing works. The downloaded file only shows 6mb when I check Control Panel in Windows and the file is almost 3 times that size.
Also, Reader will not open files the way my older version did. I can't open by clicking on the file anymore and have to 'Save As' in order to read by utility bills. This is NOT ACCEPTABLE!!
My system 32 bits, running Windows 7 with a Pentium 4 CPU @ 3.2ghz. and 2.50GB memory.
With Flash the 'Error 1772' message has appeared - 'A program run as part of the setup DID NOT FINISH as expected' Contact administrator. I am the Administrator (my home system), that is why I'm inquiring as to the what the problem is and how I might correct it and get BOTH of these products to run as advertised. HELP!!
I have made adjustments to Internet Explorer etc. as per instructions on your FAQ section. No help!
I would appreciate a solution to my dilemma, as I am about out of ideas as to where to go. So help would be greatly appreciated. Thank you.
The FULL installer is 18mb (Flash Player for ActiveX (Internet Explorer))
Once installed it's between 51 and 114mb depending whether you have a 32 or 64 bit system. The Control Panel shows ONLY a certain few files that actually install. It's always been that way.
This is purely a browser setting. See: http://helpx.adobe.com/acrobat/using/display-pdf-browser-acrobat-xi.html
See: http://forums.adobe.com/message/4041846 for instructions to perform a "clean install".
