12 Replies Latest reply on Apr 11, 2015 11:50 PM by CoSA_DaveS
    The Next Version of Premiere Pro CC - Warp Stabilizer
    DMH79 Level 2
      With the recent post of what's coming in the next version of PPro CC, I was sad to see no mention of Warp Stabilizer. As amazing of an effect as it is, it needs a bit of help. I know there are improvements and fixes that probably weren't mentioned in the post so I'm still holding out hope. We use Warp Stabilizer more than anyone I know. Several hundred times per week. Yes, per week, no exaggeration. Over the last few years, we've built an entire style of shooting around the strengths of this awesome effect that emulates the use of a slider, steadicam and crane all without having to have them. So we've become really familiar with its PROS and CONS.
      Here is a short list of SEVEN things that should be addressed with regards to warp stabilizer within Premiere Pro CC to maximize its effectiveness (and yes we did submit multiple Feature Requests for these so far to no avail):
      1. FIrst and foremost and by far MOST IMPORTANT to us - Allow users to create a CUSTOM PRESET with any altered settings that will engage (or begin Analyzing/Stabilizing) automatically when added to a clip!! This is huge. If you double click on Warp Stabilizer with a clip selected, it is applied to that clip and begins the process of stabilizing that clip. However, the vast majority of the time we need to alter the settings of the effect. If we create a custom preset, that's all fine and good, but when we add that to a clip, it does NOT begin stabilizing. Instead you have to manually go into the Effect Controls for each clip and select ANALYZE. Huge waste of time when adding this effect to hundreds of clips. PLEASE FIX!
      2. BUG when saving projects!!! - If this is not a bug, it needs to be fixed because it's awful. - If you have more than one sequence with multiple warp stabilizations added and GPU ACCELERATION IS ENABLED, then after you SAVE a project (or if it auto-saves) when you toggle between the two sequences you are hit with a delay or freeze while the render bar goes from Yellow to Red...and finally back to yellow again. No work can be done during this delay/freeze. The more stabilized clips, the longer the delay. For us, on our larger projects this delay is sometimes 30 seconds to almost a full minute! Once it turns back to yellow, you can toggle between sequences without the delay...but as soon as it saves again...and you toggle between sequences, the delay hits again. If this is a bug, or somehow a result of Premiere Pro's way of CACHING projects after it's saved, then I sincerely hope it's fixed asap. It's awful!
      3. The third is more of a feature request than a fix - Add the ability to set the maximum scale to work WITH the smoothness control so that if you never want your clips to scale more than say 105%, you can set that and have Warp Stabilizer stabilize the clip and adjust the "smoothness" percentage from the default "50%" down to whatever it needs to be in order for that clip to be fully stabilized and scaled to no more than 105%. Correct me if I'm wrong, but this is not possible currently. Right now we have to manually adjust each clip if it is initially scaled too much by dropping down the Smoothness %.
      4. Another great feature would be the ability to manually keyframe the scaling so that if you have a longer clip that starts fairly steady, then needs to be smoothed out a bit more in the middle, before it ends relatively steady again, you can slowly and seamlessly ramp up the stabilization/scaling so that the whole clip doesn't have to be scaled to make up for the misgivings of one portion of the clip.
      5. Minor bug - sometimes when you have extended the length of a clip, the clip needs to be re-analyzed again. However, the "analyze" button is often greyed out. You need to click away from the clip and then click on the clip again to make that button appear again. Nothing big, but still, a small bug.
      6. After Effects Warp Stablizer VFX feature carried over - It would be nice to carry over to Premiere the ability to isolate what in frame is supposed to be stable (sometimes someone nodding their head can trick the effect into thinking that it's the camera shaking). Great to have it in AE, but would be nice to carry over to Premiere Pro CC.
      7. Finally, I've always believed that no matter how cool "Subspace Warp" sounds, it is not as effective as "Position, Scale & Rotation". This SHOULD be the deafult "method" within the Warp's settings. I'd say 95% of the thousands and thousands of clips we've stabilized we ended up switching the "Method" within the settings to "Position, Scale & Rotation" because it either scaled the shot less or created less "wobble" in the resulting stabilized clip. I know everyone shoots differently, and sometimes Subspace Warp is the way to go, but we have stabilized all sorts of shots with great success by simply switching this setting. Granted...if #1 on this list was taken care of we could then easily have this set as our default setting.
      Hopefully this list either reaches someone within Adobe that can do something about them or at the very least inspires others to write feature requests and bug fixes as we have. Even resolving #1, #2 and #3 would be HUGE and would save our editors probably 10 hours per week.  It's an awesome effect, far better than "smoothcam" on FCP7, it just needs a little love.
        • 1. Re: The Next Version of Premiere Pro CC - Warp Stabilizer
          WilfredAP
          After reading, I can only agree with all those points!
          Thanks DMH79 for you clear description, and hopefully someone will do something with this.
          • 2. Re: The Next Version of Premiere Pro CC - Warp Stabilizer
            Greg Baber Adobe Employee
            Did you share this on the feature request/bug report page?  That page is monitored closely by our engineering teams.
            Here's the address - https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
            • 3. Re: The Next Version of Premiere Pro CC - Warp Stabilizer
              WilfredAP Level 1
              Yes, I did!
              Hopefully the take also a look at this thread.
              • 4. Re: The Next Version of Premiere Pro CC - Warp Stabilizer
                DMH79 Level 2
                Hi Greg!
                I did just now share the link. Prior to today I had submitted all these fixes &  features individually over the last 6 months or so. Hope the engineering team gets ahold of this.
                • 5. Re: The Next Version of Premiere Pro CC - Warp Stabilizer
                  DMH79 Level 2
                  Hey Greg! - Nice meeting you and Kevin today in Vegas. Thanks again for helping in any way with this list. Much appreciated!
                  • 6. Re: The Next Version of Premiere Pro CC - Warp Stabilizer
                    CoSA_DaveS Adobe Employee
                    All good points, thanks for posting.
                    For #1, you can make this work in AE at least. This tip is from my colleague DanW:
                         If you make a preset by only selecting the values you change (and not a preset for the whole effect) then it will auto-analyze on apply.
                         Simplest way: apply WS, make edits, hit UU to reveal changed params, select all "i-beams" in the Timeline, drag them to the Effects & Presets panel.
                    For #4, you can get manual control over the scaling by setting Framing to Stabilize Only, and then keyframe Additional Scale to taste. At one point we were going to try to automate this, but found automatic scaling to be very subjective as to the best way to handle it.
                    For #6, Warp Stabilizer will not track areas with zero alpha channel. So you can pre-mask the input to reveal just the parts you want to stabilize. Do this inside a nested sequence, with Warp Stabilizer applied downstream (in the outer sequence). The just-announced masking & tracking capabilities of the next CC version should be handy for this.
                    -DaveS, Adobe Dynamic Media, Advanced Product Development
                    • 7. Re: The Next Version of Premiere Pro CC - Warp Stabilizer
                      DMH79 Level 2
                      Hi DaveS!
                      Great to hear that you guys are taking a look at this list. Hope it helps make it better.  #1, #2, and #3 are by far the biggest time killers for us so hopefully they'll be able to be fixed/resolved within Premiere soon.
                      Regarding your note about #1: Allowing this functionality within Premiere specifically would be very helpful. Would it be possible to eventually allow Premiere to auto-analyze when a saved custom preset is applied to a clip? I tried it in AE as you suggested, and couldn't figure it out. But realistically we use Warp Stabilizer on so many clips that round tripping literally hundreds of short clips to AE would be just as time consuming as going into the settings in premiere for each one and adjusting the parameters. We usually adjust the method and then adjust the smoothness scale so that it doesn't "Auto-Scale" more than 104%. That's where our #3 suggestion would help. I didn't quite understand how to make a preset of specific changed values. I tried, but couldn't follow DanW's suggestion. Granted, I'm not that great with AE. I really just use it for the Warp VFX's ability to isolate what in frame is stabilized (hope that comes to Premiere one day) and that's about it. And I really only have to do that a couple times per project. Anyway, I'm sure I'm doing DanW's suggestions wrong but regardless, I'm not sure it would save us much time when we have several hundred individual little clips that would all need to be sent to AE. Any hope for adding this auto-analyze functionality (hopefully allowing a custom preset on the whole effect and all it's adjusted parameters) in Premiere CC?
                      Regarding your note about #4: That is a valid work around for now. I appreciate that thought. Thanks!
                      Regarding your note about #6: I think I half understand what you described. I'd have to try it. Although, as I said before, the AE way of doing it is ideal and I just hoped that ability to show the tracking points and delete them over time would come to Premiere CC one day. When the next CC comes out I'd love to try this masking method although I think I'll have to claify exactly what you want me to do just to be safe. Is there no hope to port this added functionality that's in AE's Warp VFX over to Premiere's Warp Stabilizer? Again, not the end of the world for us. I'd rather #1, #2 and #3 be addressed inside Premiere Pro CC for now.
                      Fixing the first 3 on this list would be HUGE time saver for us.
                      Thanks again DaveS to you and the rest of the Adobe team for looking into this list. Very much appreciated.
                      • 8. Re: The Next Version of Premiere Pro CC - Warp Stabilizer
                        All of your requests are possible, but we have to balance them against all the other things that are also important. In the end we try to use our limited resources to help the largest number of our users. With our new subscription model, that's more important than ever.
                        I forgot to mention that the reason we defaulted to Subspace Warp is that it's the only method that can remove rolling-shutter ripple. And in our testing it usually was the best choice. Of course everone's footage is different, and I understand you would prefer a different default.
                        Thanks for the detailed feedback.
                        • 9. Re: The Next Version of Premiere Pro CC - Warp Stabilizer
                          DMH79 Level 2
                          ...I understand you would prefer a different default.
                          Glad to know it's allpossible DaveS. Gives me hope. I know I'm just a small voice up against probably much bigger features and upgrades but I figured it was worth writing this because I'm guessing it is a widely used effect. Doubt anyone uses it in volume like we do so I'm sure the "balance" you mentioned probably is tipped the other way toward other issues. It works great. Just could use a bit of fine tuning to limit delays and save time when used a lot. Like I said before, #1, #2, and #3 are most important to us.
                          Refresh:
                          1) Allow for Custom Preset of Warp Settings to be Automatically engaged/analyzed when applied to a clip (like the default effect does).
                          2) Take care of the delay/freeze issue when toggling between multiple sequences with Warp Stablizer after every time a project is saved or auto-saved.
                          3) Allow users to set a "maximum amount that a clip could be scaled" so that if they never want it to crop in more than 105% for example, they can simply set that in their Custom Preset.
                          I hope others who read this feel the same and are inspired to write their own Bug Reports and Feature Requests.
                          As for the "different default"...interesting to hear why it was chosen. Okay. Thank you for letting me know. Really there would be no issue at all if Adobe would take care of #1 on the list. Then I could just save what works best for us as a custom preset and all would be well.
                          Thank you again for your time.
                          • 10. Re: The Next Version of Premiere Pro CC - Warp Stabilizer
                            Sebastian IBK
                            we have been doing the "masking out of disturbing movements" with the "precompose trick" a lot but pointing towards the new mask tracking feature is a way better work around! thank you Dave !
                            Also thanks to DMH79 for putting out all those requests!
                            • 11. Re: The Next Version of Premiere Pro CC - Warp Stabilizer
                              joshstape Level 1
                              I am editing such a basic clip with a little shake and yet this "amazing" effect called Warp Stabilizer makes every few frames look warped!  It's accomplishing the complete opposite of the intention.  Just 5% of Smooth Motion creates a ridiculous warping of everything in the clip.  I'm envious of these folks showing how well it works on YouTube, watching them do it with footage that's far more shaky than mine, yet for me it creates more issues than it's even worth! Unbelievable. Hours and hours wasted with crashes and jarring effects on a simple clip.  So disappointing and so frustrating.  Call Adobe and all they do it take 20 minutes looking up the answer on their own help pages.  Just wasting all of our time.
                              • 12. Re: The Next Version of Premiere Pro CC - Warp Stabilizer
                                Sorry to hear it's not working for you. As you noted for others, it does usually work well with little to no changing of parameters. If you're willing to share your footage, please send me a download link (using dropbox or the like) and instructions for reproducing the problem, along with your operating system info & hardware setup.
                                DaveS (dsimons at adobe.com)
