1. Re: Colormunki
twenty_one Apr 3, 2014 5:58 AM (in response to Trevor Dennis)Ah, well, matching the white point of two displays of different technologies (LED or CCFL), different brands and different models is always tricky and not always worth the trouble. But if you want to go ahead and try, you will almost certainly need different target settings.
Getting the white point right (luminance and temperature) is the one major consideration that everything else hinges on. You need to trust your eyes. What you want is a good visual match to paper white - given your specific working environment. So when you say "dimmer" the question is what your targets are. The general recommendation of 120 cd/m² may not work for you (my own is 110 at work and 95-100 at home).
Once you have the white point nailed (and possibly the black point too, if you want to be really critical), all the rest falls into place by itself.
As for temperature, the software usually lets you adjust along the blue/yellow Kelvin scale. However, if you need to adjust along the green/magenta axis, that often means you have to dive into the monitor's OSD "advanced" section. This is one of the advantages of hardware calibration to the monitor's internal circuitry, as opposed to software calibration in the video card (that's what the Munki does).
The ColorMunki sensor should be top notch. It's generally the same sensor as the i1 Display Pro (which I'm using with NEC Spectraview II software). It is generally regarded as one of the very best and most consistent colorimeters on the market.
