3 Replies Latest reply: Apr 4, 2014 11:22 AM by jackblackweb RSS
    check if sprite is off screen
    xirokx Community Member
      Hi there guys,
      I am making a game which has a gun that fires bullets, Id like the gun to fire so long as the previous bullet is off the stage
      Whats the easiest way to do this please?
      I tried:
      if sprite(13).locV = < -100 then
         variable 1 = false
      end if
      but it does not work, it allows me to repeatedly fire and cancels the existing bullet on the screen so does not register a hit....
      any ideas what I am doing wrong please?
      please help
      thanks
      p.s. in an ideal world I would like to fire bullets repeatedly irrespective if existing bullets are on the stage or not and to register a hit....
        • 1. Re: check if sprite is off screen
          jackblackweb Community Member
          Xirokx,
          These smart forum folks can help.  I think more of the
          game code and aspects are needed. Is this 3D? What is the LINGO
          that fires the bullets? What version of Director? What platform?
          Good Luck,
          Jack
          • 2. Re: check if sprite is off screen
            Hi jack
            Thanks for your reply
            OK so the lingo for firing the bullets is inside an if statement which checks if the space key is pressed if it is then it fires. This if statement is inside an exit handler
            The game is not 3D, its director 11.5 on the PC
            I know I am real close the good thing is my code is very simple unlike the examples I found online so was hoping someone could suggest a simple solution
            • 3. Re: check if sprite is off screen
              Xirokx,
              Unsure without viewing the actual Lingo.
              Variables only work as a single string of characters with no SPACE.
              variable 1 = false, should cause an error alert if sprite(13).locV = < -100
              You're right, the simpler the code the better.
              Jack
