1. Re: Audio does not add to sequence (mts files)
JSS1138 Apr 3, 2014 7:37 AM (in response to EckleySP)Post a screen shot of your sequence.
2. Re: Audio does not add to sequence (mts files)
EckleySP Apr 3, 2014 9:34 AM (in response to JSS1138) -
3. Re: Audio does not add to sequence (mts files)
John T Smith Apr 3, 2014 9:35 AM (in response to EckleySP)Are you copying the entire folder from SD card to hard drive?
Metadata contained in folder http://forums.adobe.com/thread/1015001?tstart=0
-and http://helpx.adobe.com/premiere-pro/using/transferring-importing-files.html
-http://helpx.adobe.com/premiere-pro/using/importing-assets-tapeless-formats.html
Are you allowing enough time before trying to edit?
Read Bill Hunt on Audio Conforming http://forums.adobe.com/thread/726693
4. Re: Audio does not add to sequence (mts files)
EckleySP Apr 3, 2014 11:19 AM (in response to John T Smith)Yes and yes. I've worked with these file types for years.
IN this case, there were two folders from two cameras. Each set (folder) contained 17 video files (00000 to 00016). Yesterday I worked with a few of the files (making a multi cam sequence) and had no issues. Last night, the problem started. Today, I can't get the files that worked yesterday to cooperate.
Something has changed. I've deleted cache files and rebooted. I've created another project, imported the same assets and have the same problem.
I may try yet another new project and different assets. . .
UPDATE.
Tried a new project with different files (still MTS) that worked last month. Same result. Can't load a second clip and have the audio load as well.
ANOTHER UPDATE
I just used Premiere Pro CS6 and I have no problem dragging in the same files . . . definitely something in CC.
5. Re: Audio does not add to sequence (mts files)
Sandeep Singh Apr 3, 2014 11:21 AM (in response to EckleySP) -
6. Re: Audio does not add to sequence (mts files)
EckleySP Apr 3, 2014 12:59 PM (in response to Sandeep Singh)Well, I had to watch a video to find out what Source patching was, but you are genious. Works now.
7. Re: Audio does not add to sequence (mts files)
JSS1138 Apr 3, 2014 1:01 PM (in response to EckleySP)I had to watch a video to find out what Source patching was
Or, read the manial.
