2 Replies Latest reply on Apr 4, 2014 5:02 AM by ALeon
    Ratio in calcualted field
    ALeon Level 1
      I am trying to create a field on an interactive form in Acrobat XI Pro that will create a ratio (A:B). I have two fields that the user will enter data (Number of Students and Number of Instructors). I want a third field (Ratio of Students to Instructors) that will create the ratio in the smallest possible value (i.e. 3:1, not 9:3).
      I believe I need to use the Custom calculation script, but have not done this before. Any help would be appreciated.
      I was trying this, but it obviously did not work:
      //custom calculation script for ratio of students to instuctors
      var cDivisor = "Number of Instuctors";
      var cDividend = "Number of Students";
      //clear field value in case no update
      event.value = "";
      //get the value of the fields
      var nDivisor = this.getField(cDivisor).valueAsString;
      var nDividend = this.getField(cDividend).valueAsString;
      //process if non-blank, non-zero divisor
      if(nDivisor != "" && Number(nDivisor) !=0 && !isNaN(Number(nDivisor))){
          var x = nDivisor/nDividend;
         event.value = x+":1";
        • 1. Re: Ratio in calcualted field
          George_Johnson MVP & Adobe Community Professional
          What you need to do is divide each number by the greatest common divisor of the two numbers, which is easy to calculate. Here are two functions you can use:
          // Document-level functions
          function gcd(a, b) {
              // Recursive function to determine the greatest common divisor
              // of two integers a and b
              return b ? gcd(b, a % b) : a;
          function getRatioString(x, y) {
              // Create a ratio string given two numbers (assumed to be positive integers)
              var d = gcd(x, y);
              return "" + ( x / d ) + ":" + ( y / d );
          You can then do something like:
          // Custom calculation script
          (function () {
              // Get the field values, as numbers
              // Assume validate scripts force positive integers
              var x = +getField("a").value;
              var y = +getField("b").value;
              // Show the ratio string
              event.value = x > 0 && y > 0 ? getRatioString(x, y) : "";
          but you should check that both numbers are positive integers somewhere. I'm assuming the fields have custom validate scripts that force positive integers.
          • 2. Re: Ratio in calcualted field
            ALeon Level 1
            Thanks George,
            That helps a great deal. I appreciate the assist.
            Anthony Leon
            Administrative Coordinator I
            Broward County Parks and Recreation
            Description: Description: Description: Description: Broward County Logo
