1. Re: Is it possible to designate stapling when printing a PDF form?
PJDarnell May 13, 2014 12:53 PM (in response to PJDarnell)OK...it has been a wild ride, but between our Basis team and the Server team (which handles our printer drivers), here is what they came up with to enable this feature. They really put in the time to figure this out. References to PRD in this document is a reference to our production machine. ZPMLOCL is a printer type used by our users for printing these work order forms. A lot of effort was also given to make sure the driver on the printer supported the stapling feature (most do anymore). This effort is to not only allow stapling, but to also eliminate the pesky banner page which can suddenly start printing with these changes. We are using Xerox printers in our evironment.
Steps for Basis Portion of PRD change on the - Standard Work Order Form - shop paper document
- (STMS) Transport device type ZPMHPLJ4 to PRD with Transport
- SPAD
- Copy zpmhppcl5e.xdc file from AD1 to ADS, in the location below.
4. SA38/SE38* run program RSPO0022 on PRD and Check to see if transport from step 1 moves the assignment below.
If not create assignment the same as in the red box below.5. Finally, stop and then start the XML Form Module Java Service in ADS.
I have no other notes on this setup. I hope this helps you in your efforts to get the stapling feature up and running on your system.
