2 Replies Latest reply on Apr 7, 2014 4:56 AM by mifamac
    To initiate a validation of all fields in a form
    mifamac
      I have a PDF Form with some fields (A, B, C, D).
      The user fills in the fields with numbers that have to be in an specific range (e.g. between 600 and 1850 mm in field B).
      These fields are validated on return. (fig01-fig03)
      In field D the user can enter a value between min 0 and max dimension that depends on the value entered in field B. This is validated (fig03).
      User enters in field B: 1800; the result is 1200 max. dimension for field D; user enters value 1200 in field D;
      Now my problem:
      User deside to enter a lower value in field B; but the value of field D entered previously is not validated again!
      There should be an additional validation (cross-validation) for field D when the user enters a value in field B; I have no idea how to to this...
      For further explanation 3 pdfs:
      http://gofile.me/24Xga/f77EWFFw
      http://gofile.me/24Xga/jo8tnPOX
      http://gofile.me/24Xga/NlHQkqGI
      Any help is appreciated.
      Thanks in advance
      mifa
        • 1. Re: To initiate a validation of all fields in a form
          One possible solution is to reset field D whenever field B is updated. Otherwise, you will need to copy your validation script (of the D value) into field B and run it when that field is updated as well.
          • 2. Re: To initiate a validation of all fields in a form
            mifamac Level 1
            Hi, thanks for your reply.
            This is my actual code for validation of field b1. It does not work properly. Sometimes the wrong value in field d1 is noted, sometimes not.
            The second problem: Is it possible not only to reject the wrong value but to put in the max. possible value?
            // Benutzerdefinierte Ueberprüfung
            (function () {
                // Get this field value, as a number
                var b1a = +event.value;
                // Max-Min Werte
                var b1max = 1850;
                var b1min = 600;
                // Testen ob Wert über 1850 liegt
                if (b1a > 1850) {
                    // Fehlermeldung
                    app.alert("Wert darf nicht größer sein als 1850!");
                    // Reject the value that the user entered
                    event.rc = false;
                // Testen ob Wert unter 600 liegt
                if (b1a < 600) {
                    // Fehlermeldung
                    app.alert("Wert darf nicht kleiner sein als 600!");
                    event.rc = false;
                // Get the value in the d2max field, as a number
                var v1a = +getField("d1max").value;
                var v2a = +getField("d1").value;
                // Test if this field value is greater than the number of d1max
                if (v2a > v1a) {
                    // Fehlermeldung
                    app.alert("Größe D darf nicht größer sein als " +v1a +"!");
                    event.rc = false;
                if (v2a < 0) {
                    // Fehlermeldung
                    app.alert("Wert darf nicht kleiner sein als 0");
                    event.rc = false;
            mifamac
