4 Replies Latest reply on Apr 4, 2014 8:51 AM by it@caotti.net
    Text wrap not working
    it@caotti.net Level 1
      I'm using InDesign CS6. I'm trying to wrap text around a circular picture box with a 17 point stroke (stroke is aligned in the center). The text is 70 points and flush left; the circle is on the left with the text box on the right. But when I select both the cirlce and the text box, then turn on text wrap, nothing happens. The fields in the Text Wrap panel that allow you to change the space between the object and the text are all grayed out so I can't change them from 0. I've checked the text box properties and have confirmed that "Ignore text wrap" is not checked.
      Any thoughts on what the problem could be?
