3 Replies Latest reply on Apr 6, 2014 8:28 PM by Carl Sun
    Only Fireworks recognised, can't install .zxp for Illustrator
    wöökie
      Brand new Mac, OS up to date. Clean, fresh install of CC, everything up to date. You'd expect things to 'just work' right?
      I've successfully installed a couple of old Fireworks extensions by just double-clicking them. I try the same with the Monotype Skyfonts extension, with the aim of having it available in Illustrator - no dice.
      I get the following…
      … the relevant part of which seems to be 'recognizes at least one product which the extension supports'. My Extension manager window lists only Fireworks CS6 as available and no others (I have PS, IA & ID also installed, so would expect to see them, no?)
      A bit of a poke around on the forums here suggested using Extendscript to run bridge diagnostics and see if the paths are correct. They seem to be, although the path name and display name don't match it appears to be consistent.
      I'm now out of ideas. What next?
      Like I said, you'd expect a fresh install to just work, right?
      T.
      Full diagnostics below…
      Result: BridgeTalk Diagnostics
                Info:
                          Name = estoolkit-4.0
                          Status = PUMPING
                          Group = cs
                          Path = /Applications/Adobe ExtendScript Toolkit CC/ExtendScript Toolkit.app
                          Version = 2.0
                          Build = ES 4.5.5
                          Next serial number = 40
                          Logging: = OFF
                          Now = 13:52:08
                                    Message Version = 2.05
                                    Authentication = ON
                                    Digest = ON
                Thread: estoolkit-4.0#thread
                          Avg. pump interval = 40ms
                          Last pump = 58ms ago
                          Ping: 7
                                    ECHO_REQUEST: ECHO_RESPONSE
                                              Timeout = undefined
                                              Handler = undefined
                                    STATUS: PUMPING
                                              Timeout = undefined
                                              Handler = undefined
                                    MAIN: MAIN
                                              Timeout = undefined
                                              Handler = installed
                                    LAUNCHED: LAUNCHED
                                              Timeout = undefined
                                              Handler = installed
                                    DIAGNOSTICS: DIAGNOSTICS
                                              Timeout = undefined
                                              Handler = installed
                                    INFO: INFO
                                              Timeout = undefined
                                              Handler = installed
                                    SETUPTIME: thread=0ms, left=29ms
                                              Timeout = undefined
                                              Handler = undefined
                Instances: 3
                          estoolkit-4.0#dbg:
                                              msg[13:52:07]: 00000035
                                                        @BT>Version = 2.05
                                                        Target = estoolkit-4.0#dbg
                                                        Sender = estoolkit-4.0#dbg
                                                        Sender-ID = localhost:mac981
                                                        Timeout = 13:52:08
                                                        Type = Ignore
                                                        Response-Request = Timeout
                                                        Headers = (no headers)
                                                        Timestamp = 13:52:07
                                                        Serial-Number = 35
                                                        Received = undefined
                                                        Result = undefined
                                                        Error = undefined
                                                        Body = (empty)
                                    Incoming: 1
                                    Outgoing: 0
                                    Handler: 9
                                              ExtendScript = for all messages
                                              Error = for only msg #25
                                              Error = for only msg #27
                                              Error = for only msg #31
                                              Result = for only msg #35
                                              Error = for only msg #35
                                              Timeout = for only msg #35
                                              Result = for only msg #37
                                              Error = for only msg #37
                          estoolkit-4.0#estk:
                                              msg[13:52:07]: 00000037
                                                        @BT>Version = 2.05
                                                        Target = estoolkit-4.0#estk
                                                        Timeout = 14:02:07
                                                        Type = Debug
                                                        Response-Request = Result Error
                                                        Serial-Number = 37
                                                        Result = undefined
                                                        Error = undefined
                                                        Body: 107 bytes
        Text = <get-properties engine="main" object="$.global" exclude="undefined,builtin,prototype" all="true" max="20"/>
                                    Incoming: 1
                                    Outgoing: 0
                                    Handler: 1
                          estoolkit-4.0: (main)
                                    Incoming: 0
                                    Outgoing: 0
                                    Handler: 1
                Targets: 9
                          Connector = PCD
                          Installed: 0
                          Running: 0
                                    fireworks-12.0:
                                              Group = cs
                                              Path = /Applications/Adobe Fireworks CS6/Adobe Fireworks CS6.app
                                              Display Name = Adobe Fireworks CS6
                                              MsgAuthentication = ON
                                              MsgDigest = ON
                                              ESTK = OFF
                                              BundleID = com.adobe.Fireworks
                                              Status = (not running)
                                              ExeName = Adobe Fireworks CS6.app
                                    ame-7.0:
                                              Group = cs
                                              Path = /Applications/Adobe Media Encoder CC/Adobe Media Encoder CC.app
                                              Display Name = Adobe Media Encoder
                                              MsgDigest = ON
                                              ESTK = ON
                                              BundleID = com.adobe.ame.application
                                              ExeName = Adobe Media Encoder CC.app
                                    bridge-6.064:
                                              Group = cs
                                              Path = /Applications/Adobe Bridge CC/Adobe Bridge CC.app
                                              Display Name = Bridge CC
                                              MsgDigest = ON
                                              ESTK = ON
                                              BundleID = com.adobe.bridge6
                                              ExeName = Adobe Bridge CC.app
                                    estoolkit-4.0: PUMPING
                                              Group = cs
                                              Display Name = ExtendScript Toolkit CC
                                              MsgDigest = ON
                                              ESTK = ON
                                              Status = PUMPING
                                              Info:
                                                        Group = cs
                                                        Version = 2.0
                                                        Build = ES 4.5.5
                                                        Next serial number = 46
                                                        Logging: = OFF
                                                        Now = 13:52:08
        Authentication = ON
        Digest = ON
                                                        Last pump = 260ms ago
                                                        Ping: 7
        Timeout = undefined
        Handler = undefined
        STATUS: PUMPING
        Timeout = undefined
        Handler = undefined
        MAIN: MAIN
        Timeout = undefined
        Handler = installed
        LAUNCHED: LAUNCHED
        Timeout = undefined
        Handler = installed
        Timeout = undefined
        Handler = installed
        INFO: INFO
        Timeout = undefined
        Handler = installed
        Timeout = undefined
        Handler = undefined
                                              ExeName = ExtendScript Toolkit.app
                                    exman-6.0: IDLE
                                              Group = cs
                                              Path = /Applications/Adobe Extension Manager CS6/Adobe Extension Manager CS6.app
                                              Display Name = Adobe Extension Manager CS6
                                              MsgDigest = ON
                                              ESTK = OFF
                                              BundleID = com.adobe.exman
                                              Status = IDLE
                                              Info:
                                                        Group = cs
                                                        Version = 2.0
                                                        Build = ES 3.92.104
                                                        Next serial number = 3
                                                        Logging: = OFF
                                                        Now = 13:52:10
        Authentication = ON
        Digest = ON
                                    exman-6.0: IDLE
                                              Thread: exman-6.0#thread
                                                        Avg. pump interval = 0ms
                                                        Last pump = 396809ms ago
                                                        Ping: 7
        Timeout = undefined
        Handler = undefined
        STATUS: IDLE
        Timeout = undefined
        Handler = undefined
        MAIN: MAIN
        Timeout = undefined
        Handler = installed
        LAUNCHED: LAUNCHED
        Timeout = undefined
        Handler = installed
        Timeout = undefined
        Handler = installed
        INFO: INFO
        Timeout = undefined
        Handler = installed
        SETUPTIME: thread=0ms, left=1ms
        Timeout = undefined
        Handler = undefined
                                              ExeName = Adobe Extension Manager CS6.app
                                    illustrator-17.064: IDLE
                                              Group = cs
                                              Path = /Applications/Adobe Illustrator CC/Adobe Illustrator.app
                                              Display Name = Adobe Illustrator CC
                                              MsgDigest = ON
                                              ESTK = ON
                                              BundleID = com.adobe.illustrator
                                              Status = IDLE
                                              Info:
                                                        Group = cs
                                                        Version = 2.0
                                                        Build = ES 4.5.5
                                                        Next serial number = 7
                                                        Logging: = OFF
                                                        Now = 13:52:11
        Authentication = ON
        Digest = ON
                                              Thread: illustrator-17.064#thread
                                                        Avg. pump interval = 3688ms
                                                        Last pump = 405ms ago
                                                        Ping: 7
        Timeout = undefined
        Handler = undefined
        STATUS: IDLE
        Timeout = undefined
        Handler = undefined
        MAIN: MAIN
        Timeout = undefined
        Handler = installed
        LAUNCHED: LAUNCHED
        Timeout = undefined
        Handler = installed
        Timeout = undefined
        Handler = installed
        INFO: INFO
        Timeout = undefined
        Handler = installed
        SETUPTIME: thread=0ms, left=0ms
        Timeout = undefined
        Handler = undefined
                                              ExeName = Adobe Illustrator.app
                                    indesign-9.064:
                                              Group = cs
                                              Path = /Applications/Adobe InDesign CC/Adobe InDesign CC.app
                                              Display Name = Adobe InDesign CC
                                              MsgDigest = ON
                                              ESTK = ON
                                              BundleID = com.adobe.InDesign
                                              ExeName = Adobe InDesign CC.app
                                    photoshop-70.032:
                                              Group = cs
                                              Path = /Applications/Adobe Photoshop CC/Adobe Photoshop CC.app
                                              Display Name = Adobe Photoshop CC
                                              MsgDigest = ON
                                              ESTK = ON
                                              BundleID = com.adobe.Photoshop
                                              ExeName = Adobe Photoshop CC.app
                                    switchboard-3.064:
                                              Group = cs
                                              Path = /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/MacOS/SwitchBoard.app
                                              Display Name = SwitchBoard 3.0
                                              MsgDigest = ON
                                              ESTK = OFF
                                              ExeName = SwitchBoard.app
                          Installed: 6
                          Running: 3
                          Groups: 140
                                    cs3:
                                              acrobat-8.0
                                              aftereffects-8.0
                                              soundbooth-1.0
                                              bridge-2.0
                                              contribute-4.5
                                              devicecentral-1.0
                                              dreamweaver-9.0
                                              encore-3.0
                                              estoolkit-2.0
                                              fireworks-9.0
                                              flash-9.0
                                              illustrator-13.0
                                              indesign-5.0
                                              indesignserver-5.0
                                              incopy-5.0
                                              photoshop-10.0
                                              premiere-3.0
                                              premierepro-3.0
                                              stockphotos-1.5
                                              audition-3.0
                                    cs4:
                                              acrobat-9.0
                                              aftereffects-9.0
                                              soundbooth-2.0
                                              bridge-3.0
                                              contribute-5.0
                                              devicecentral-2.0
                                              dreamweaver-10.0
                                              encore-4.0
                                              estoolkit-3.0
                                              fireworks-10.0
                                              flash-10.0
                                              illustrator-14.0
                                              indesign-6.0
                                              indesignserver-6.0
                                              incopy-6.0
                                              photoshop-11.*
                                              premierepro-4.0
                                              audition-4.0
                                              ame-1.0
                                              exman-2.0
                                    cs5:
                                              acrobat-9.0
                                              aftereffects-10.0
                                              soundbooth-3.0
                                              bridge-4.0
                                              contribute-6.0
                                              devicecentral-3.0
                                              dreamweaver-11.0
                                              encore-5.0
                                              estoolkit-3.5
                                              fireworks-11.0
                                              flash-11.0
                                              illustrator-15.0
                                              indesign-7.0
                                              indesignserver-7.0
                                              incopy-7.0
                                              photoshop-12.*
                                              premierepro-5.0
                                              audition-5.0
                                              ame-2.0
                                              exman-3.0
                                              flashbuilder-4.0
                                              flashcatalyst-1.0
                                    ts1:
                                              captivate3-en_us
                                              captivate3-fr_fr
                                              captivate3-it_it
                                              captivate3-ja_jp
                                              captivate3-es_es
                                              captivate3-de_de
                                    ts2:
                                              captivate-4.0
                                    el2:
                                              captivate-5.0
                                    as1:
                                              acrobat-10.0
                                    ts3:
                                              robohelp-9.0
                                              framemaker-10.0
                                    cs55:
                                              aftereffects-10.5
                                              audition-4.0
                                              bridge-4.1
                                              contribute-6.1
                                              devicecentral-3.5
                                              dreamweaver-11.5
                                              encore-5.1
                                              estoolkit-3.6
                                              fireworks-11.1
                                              flash-11.5
                                              illustrator-15.1
                                              indesign-7.5
                                              indesignserver-7.5
                                              incopy-7.5
                                              photoshop-55.*
                                              premierepro-5.5
                                              ame-2.5
                                              exman-5.5
                                              flashbuilder-4.5
                                              flashcatalyst-1.5
                                              switchboard-2.0
                                    el25:
                                              captivate-5.5
                                    cs60:
                                              aftereffects-11.0
                                              audition-5.0
                                              bridge-5.*
                                              contribute-6.88
                                              devicecentral-4.0
                                              dreamweaver-12.0
                                              encore-6.0
                                              estoolkit-3.8
                                              fireworks-12.0
                                              flash-12.0
                                              illustrator-16.*
                                              indesign-8.0
                                              indesignserver-8.0
                                              incopy-8.0
                                              photoshop-60.*
                                              premierepro-6.0
                                              ame-6.0
                                              exman-6.0
                                              flashbuilder-4.52
                                              switchboard-2.0
                                              prelude-1.0
                                              speedgrade-6.0
                                    el60:
                                              captivate-60.*
                                    ts4:
                                              robohelp-10.0
                                              framemaker-11.0
                                    cs70:
                                              audition-6.0
                                              bridge-6.*
                                              dreamweaver-13.0
                                              encore-7.0
                                              fireworks-13.0
                                              flash-13.0
                                              illustrator-17.*
                                              indesign-9.*
                                              indesignserver-9.0
                                              incopy-9.*
                                              photoshop-70.*
                                              premierepro-7.0
                                              ame-7.0
                                              exman-7.0
                                              flashbuilder-5.0
                                              prelude-2.0
                                              estoolkit-4.0
                                              aftereffects-12.0
                                    el70:
                                              captivate-70.*
                                    cs70:
                                              switchboard-3.*
