2 Replies Latest reply on May 30, 2007 4:49 AM by mouse jockey
    Data binding question
    mouse jockey
      My main application utilises a popup window component (a titlewindow in a separate file). Once opened, the popup contains a datagrid whose dataprovider is defined as a bindable public var array in a separate AS file. This gives me a '1120 access of undefined property' error.
      How can I get the datagrid to 'see' the bindable data please?
        • 1. Re: Data binding question
          BLXWebMaster
          Can you post your code?
          Are you missing a ";"?
          • 2. Re: Data binding question
            mouse jockey Level 1
            From my research, meanwhile, I think I need a reference variable.
            Here's the plot so far:
            Main mxml file contains
            <script source="/scripts/keyboard.as"/>
            <script source="/scripts/mysql.as"/>
            mxml stuff ........ etc. ....
            MXML titlewindow component file (used for popup), and called from main mxml file, contains datagrid with dataprovider = "{MySQLDataArray}"
            but MySQLDataArray can't be seen in the component file (it lives in the mysql.as file). I understand that I can add a bindable local variable thus is the titlewindow component file with:
            <mx:Script>
            [Bindable]
            private var localVar:Array;
            </mx:Script>
            and change the datagrid dataprovider to dataprovider = "{localVar}"
            but how do I get the localVar to reference the MySQLDataArray variable in the mysql.as file?
