20 Replies Latest reply on Apr 12, 2014 12:41 AM by jc.lachaise
    replace anchored image by a character
    jc.lachaise
      How can i find and replace automaticaly an anchored image placed in a text, by a character ?
        • 1. Re: replace anchored image by a character
          Sajeev Sridharan Level 4
          app.findGrepPreferences = app.changeGrepPreferences = null;
          app.findGrepPreferences.findWhat = '~a'; //finding image
          app.changeGrepPreferences.changeTo = 'image1'; //replacing with text
          app.activeDocument.changeGrep();
          Vandy
          • 2. Re: replace anchored image by a character
            jc.lachaise Level 1
            Thanks Vandy for your reply,
            but your script replace all anchored images, even if they are different images,
            i would like to change each image by a different character,
            and the find and replace ou grep search (â or ~a) find all anchored images,
            i can't find the one i want...
            JCL
            • 3. Re: replace anchored image by a character
              Dave Saunders Level 4
              Only you know which one you want. How do you intend to communicate that to the script?
              Or perhaps I should ask: which character goes with which image? You can use a search to find them all and then cycle through them with a for-loop to replace each individually.
              How much help do you need? Have you written scripts yourself or are you looking for someone to write one for you?
              Dave
              • 4. Re: replace anchored image by a character
                jc.lachaise Level 1
                No, I don't have written the script
                I just don't know how to find a particular image
                If i select and copy a text with a anchored image inside, when i paster it the image disappear.
                I found that ^a or ~a is the code for anchored image, so if i search ^a it finds all anchored image
                but it doesn't make difference between 2 images.
                Do you i any idea how to find a specific anchored image ?
                an ythen i think i can make the script
                JCL
                • 5. Re: replace anchored image by a character
                  You should look for all of them and then cycle through them with a for loop. Here's one way of tackling it that works because anchored pageItems are returned as the pageItems collection of text, so assuming that the anchors you care about are within the selection, this will work:
                  //DESCRIPTION: Replace anchored items in selected text with characters
                  (function(){
                            if (app.documents.length > 0
                                                && app.selection.length == 1
                                                && app.selection[0].hasOwnProperty("baseline")) {
                                      replaceAnchors(app.selection[0]);
                            function replaceAnchors(someText) {
                                      var pageItems = someText.pageItems;
                                      for (var j = pageItems.length - 1; j >= 0; j--) {
                                                var myChar = pageItems[j].parent;
                                                myChar.contents = String.fromCharCode(65 + j);
                  Dave
                  • 6. Re: replace anchored image by a character
                    jc.lachaise Level 1
                    I have tried your script but it doesn't work
                    My anchored image name is "picto+.eps" and i would like to replace it by "§"
                    Do i have to change any think in your script to make it work ?
                    JCL
                    • 7. Re: replace anchored image by a character
                      The script most certainly does work. It just doesn't do what you wanted it to because until now you haven't said what you wanted.
                      And even now I'm thoroughly confused because you said earlier that you had a number of images you wanted to replace, but now you have just one.
                      Where is it? Do you know exactly where in the document? Or do you have to search for it?
                      Does the image appear just once? Or is it in the document many times?
                      Is it linked? Because if so, that's the best way to find it, via the document's links collection.
                      Dave
                      • 8. Re: replace anchored image by a character
                        jc.lachaise Level 1
                        Yes, I have a 600 pages document, with hundreds of anchored images.
                        The person who made this file anchored images to illustrate the text.
                        For exemple : "Grand Hotel de Paris (image of a swiming pool), Hotel de Londres (image of a parking),..."
                        Because i need to work on this file, i would like to replace these anchored images by a type character,
                        with a type i made with those images.
                        and the texte would look like : "Grand Hotel de Paris #, Hotel de Londres §,..."
                        # is an image of swimmingpool, and § is an image of a parking
                        The images are linked actualy, and each image appear dozen of time in the file.
                        JCL
                        • 9. Re: replace anchored image by a character
                          This script does the job. You'll need to update the anchArray to fit your actual needs. You'll see that I added a test case so I could test the script.
                          //DESCRIPTION: Replace Anchored Images with Text
                          (function(){
                                    if (app.documents.length > 0) {
                                              var anchArray = [
                                                        // edit names; add new pairs as needed
                                                        {'name' : "parking.eps", 'char' : "§"},
                                                        {'name' : "swimmingpool.eps", 'char' : "#"},
                                                        {'name' : "o-fc1_setup.pdf", 'char' : "∏"} // my test case
                                              replaceAnchors(app.documents[0], anchArray);
                                    function replaceAnchors(aDoc, anchArray) {
                                              var links = aDoc.links.everyItem().getElements();
                                              for (var j = links.length - 1; j >= 0; j--) {
                                                        var anchor = getAnchor(links[j]);
                                                        if (anchor == null) continue; // link not anchored
                                                        var aChar = getCharacter(links[j].name, anchArray);
                                                        if (aChar != null) {
        anchor.contents = aChar;
                                    function getCharacter(linkName, anchArray) {
                                              for (var j = anchArray.length - 1; j >= 0; j--) {
                                                        if (linkName == anchArray[j].name) {
        return anchArray[j]['char'];
                                              return null;
                                    function getAnchor(link) {
                                              var theChar = link.parent.parent.parent;
                                              if (theChar instanceof Character) {
                                                        return theChar;
                                              return null; // not anchored
                          Dave
                          • 10. Re: replace anchored image by a character
                            jc.lachaise Level 1
                            Great,
                            That works perfectly, and changes all my anchored images to characters.
                            Last request, is it possible to give this character a new font and size to look like exactly as the anchored image.
                            JCL
                            • 11. Re: replace anchored image by a character
                              Yes.
                              Which font? What size? Or do you want the script to get the size of the anchored frame and match that automatically?
                              The mechanics of this would be to set the font and size in the replace Anchors function immediately after setting the contents to the designated character.
                              Dave
                              • 12. Re: replace anchored image by a character
                                jc.lachaise Level 1
                                No,
                                The font is unique "KYBpictoNORMAL", and the size is "28pt"
                                and the space bitween two line (or line spacing) is 24pt
                                That's all
                                JCL
                                • 13. Re: replace anchored image by a character
                                  While this could indeed be done by the script through local formatting (although I wouldn't be able to test it because I don't have the font), you might consider setting up a character style to apply the required parameters, then the script could apply that or you could even apply it using a GREP style (assuming you have no other instances of the characters in question).
                                  Dave
                                  • 14. Re: replace anchored image by a character
                                    jc.lachaise Level 1
                                    Thanks anyway,
                                    If you can put these character specifications in the script
                                    using "Zapf Dingbats" or a style name like "StyleKYB",
                                    it would be perfect,
                                    otherwise i will search and replace the character using GREP.
                                    Thanks for all your help
                                    JCL
                                    • 15. Re: replace anchored image by a character
                                      Here you go. You'll have to create the character style in your document, and I've assumed that it is not inside a CharacterStyleGroup.
                                      //DESCRIPTION: Replace Anchored Images with Styled Text
                                      (function(){
                                                          var anchArray = [
        anchor.appliedCharacterStyle = "StyleKYB"
                                                          return null;
        return theChar;
                                      I'd appreciate you indicating that I have correctly answered your question.
                                      Dave
                                      • 16. Re: replace anchored image by a character
                                        jc.lachaise Level 1
                                        I have a script error on line  : "anchor.appliedCharacterStyle = "StyleKYB".
                                        unexpected value...
                                        Can't we put directly the fonts name and size in the script instead of the style ?
                                        JCL
                                        • 17. Re: replace anchored image by a character
                                          Did you make a character style with that name? That is far and away the easiest and most reliable way to achieve the aim and it also has the benefit of being the most flexible.
                                          Dave
                                          • 18. Re: replace anchored image by a character
                                            jc.lachaise Level 1
                                            Yes, I did.
                                            But it doesn't work.
                                            JCL
                                            • 19. Re: replace anchored image by a character
                                              Could you select a paragraph that includes a character to which you have applied this character style you created, export that to tagged text and then post that tagged text here?
                                              Dave
                                              • 20. Re: replace anchored image by a character
                                                jc.lachaise Level 1
                                                Thanks Dave Dave,
                                                You realy helped me a lot.
                                                JCL
