• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
I am taking over management of a coldfusion 9.01 server, but the CFADMIN page does not load.
New Here ,
Apr 07, 2014 Apr 07, 2014
Th error is webpage cannot be found, can someone point me in the right direction?
Views
760
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
We'll need more information than "webpage cannot be found".
There is a possibility that the CF Server services aren't running.  That could cause the error message you are seeing.  But, there are a lot of reasons for that message.  It could be anything.
HTH
^_^
Votes
Translate
Translate
Report
Report
New Here ,
ok, what more do you need?  The services are running, and all of the coldfusion webpages running on the server are up and functional.
I am attempting to launch the webpage http://127.0.0.1/CFIDE/Administrator/index.cfm
The file index.cfm is in the directory C:\inetpub\wwwroot\CFIDE\administrator
I also ran the web connector configuration tool, removing the connectors, restarting COldFusion, and the n again recreating the connectors
what would your next troubleshooting steps be?
Votes
Translate
Translate
Report
Report
Engaged ,
When you say "it doesn't load" can you explain what that means?  Are you getting an error?  If so.. what error.  If the site can't be found then maybe iis is not setup to handle localhost.  Try replacing 127.0.0.1 with the ip address of the server.
Votes
Translate
Translate
Report
Report
LEGEND ,
CF on a local machine _usually_ runs via port 8500.  Try adding the port to the URL: http://127.0.0.1:8500/CFIDE/Administrator
Votes
Translate
Translate
Report
Report
Community Expert ,
The webserver in question is apparently IIS.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
LATEST
In addition to the suggestions above, can you try with a test html page. This would ensure the expected functionality of IIS.
Regards,
Anit Kumar
Votes
Translate
Translate
Report
Report
Community Expert ,
@Matthewrcollins
I would follow these 4 debugging steps:
1) Jot down the current time.
2) Attempt again to open the ColdFusion Administrator page in the browser.
3) Go to the logs directory and read off the entries in exception.log and application.log that correspond to the time in 1).
4) Return to the forum with any relevant error messages.
Votes
Translate
Translate
Report
Report
Resources
Documentation
