3 Replies Latest reply on Aug 28, 2007 7:54 AM by kglad
    targetInstanceName ???
    D3 Level 1
      I've seen script that uses this targetInstanceName and I'm not sure how it works. I'm trying to use the following code but don't understand how or where to reference either a external SWF or a movie clip that is on _parent.
      Can anyone help me with this? Thanks in advance!!
      // Public: pTarget
      // Object: Reference to target movieclip
      pTarget = this._parent[this._targetInstanceName];
      // Public: pMovie
      // Object: File to load
      pMovie = this._filePath;
        • 1. Re: targetInstanceName ???
          what are you trying to accomplish?
          • 2. Re: targetInstanceName ???
            D3 Level 1
            Thanks for the response Kglad,
            Well I been searching for a prebuilt flash movie controller that uses a slider that controls a SWF. Same concept as a regular media player. I only found one, it was written by some guy named Dave Stroy, and it really works great. I'm only have one problem with it. He uses pTarget as a var name and path and also uses pMovie as a file path? I'm not sure what his logic is there. I can put an absolute path in the pTarget to a movie clip on the _root and it works fine except it doesn't automatically play when loaded and that's what I need it to do. So I'm not sure if I'm breaking any code by putting in this absolute path and if I don't I'm not sure how this _targetInstanceName works?
            Here's the entire code:
            | Movie Controller Component |
            | by davestroy March 27, 2003 |
            | Control external Squeezed swf |
            | stay cool! davestroy@davstroy.net |
            // Private: #initclip
            // Global definitions for all instances on stage
            #initclip
            for (clip in this){
            this.clip.useHandCursor = false;
            #endinitclip
            /* PUBLIC PROPERTIES */
            // Public: pTarget
            // Public: pMovie
            // Public: pMovie
            // Object: Width of progress bar
            pProgressWidth = this._progressWidth;
            frame.top._width = pProgressWidth;
            frame.bot._width = pProgressWidth;
            frame.right._x = pProgressWidth;
            /* PRIVATE PROPERTIES */
            // Private: pPlaying
            // Bool:
            pPlaying = false;
            // Private: pDragging
            // Bool:
            pDragging = false;
            // Private: pPercent
            // Int: Percent loaded
            pPercent = 0;
            // Private: pSliderX
            // Int: Initial x pos of slider
            pSliderX = slider._x;
            * PUBLIC MEMBER FUNCTIONS
            * Public: Most common functions to control
            * target movie state (play, stop, load, etc)
            this.Reset = function(){
            pPercent = 0;
            pPlaying = false;
            pTarget.unloadMovie();
            this.Play = function(){
            pTarget.play();
            pPlaying = true;
            this.Load = function(aMovie){
            if (aMovie != null){
            pMovie = aMovie;
            pTarget.loadMovie(pMovie);
            pPlaying = true;
            setClipState(cPlay);
            this.Stop = function(){
            pTarget.stop();
            pPlaying = false;
            this.Rewind = function(){
            pTarget.gotoAndStop(1);
            pPlaying = false;
            slider._x = pSliderX;
            * PRIVATE MEMBER FUNCTIONS
            * Private: Update elements depending on
            * target movies current state.
            this.onEnterFrame = function(){
            if(pPercent < 100 ){
            Loading();
            if(pDragging){
            Dragging();
            }else if (pPlaying){
            Playing();
            this.Loading = function(){
            if (pTarget.getBytesTotal() == 0) return;
            //pPercent = Math.round((pTarget.getBytesLoaded() / pTarget.getBytesTotal()) * 100);
            //progress._xscale = pPercent;
            pPercent = pTarget.getBytesLoaded() / pTarget.getBytesTotal();
            progress._width = Math.round(pPercent * frame.top._width);
            this.Playing = function(){
            var dif = pTarget._currentframe / pTarget._totalframes;
            var curpos = dif * (progress._width - progress.slider._width);
            slider._x = Math.round(curpos);
            //Timecode();
            this.Timecode = function(){
            var sec = Math.round(pTarget._currentframe / 12);
            var min = int(sec/60);
            sec -= min * 60;
            if(min < 10) min = "0" + min;
            if(sec < 10) sec = "0" + sec;
            timecode.text = min+":"+sec;
            this.Dragging = function(){
            var dif = slider._x / progress._width;
            var curframe = Math.round(dif * pTarget._totalframes);
            pTarget.gotoAndStop(curframe);
            * SLIDER FUNCTIONS
            * Private: Control target movie from draging the slider
            * Overrides Play, Stop, Rewind and Pause functions
            this.slider.onPress = function(){
            pDragging = true;
            startDrag(this,false,0,this._y,this._parent._width-this._width,this._y);
            this.slider.onRelease = function(){
            pDragging = false;
            stopDrag();
            if(pPlaying) this._parent.Play();
            this.slider.onReleaseOutside = function(){
            pDragging = false;
            stopDrag();
            * PROGRESS FUNCTIONS
            * Private: Control target movie from pressing the progress bar
            this.progress.onPress = function(){
            var curframe = Math.round(((_xmouse - progress._x) / progress._width) * pTarget._totalframes);
            if(pPlaying){
            pTarget.gotoAndPlay(curframe);
            }else{
            Playing();
            * PLAY, STOP, PAUSE, REWIND
            * Set state of buttons and command target movie
            this.setClipState = function(obj){
            if(pCurbut == obj) return;
            obj.gotoAndStop("On");
            pCurbut.gotoAndStop("Off");
            pCurbut = obj;
            this.cPlay.onRelease = function(){
            setClipState(this);
            this.cPause.onRelease = function(){
            setClipState(this);
            this._parent.Stop();
            this.cStop.onRelease = function(){
            setClipState(this);
            this._parent.Rewind();
            if(this.pMovie != ""){
            this.Load();
            stop();
            • 3. Re: targetInstanceName ???
              there is no _targetInstanceName in flash. that's a custom property that must be in the code somewhere.
              i built a custom class for a slider that allows a user to control any movieclip property including its _currentframe, as well as, a number of other things for which sliders are used.
