1. Re: Can no longer publish after latest Muse update (April 2nd 2014)
CWLMedia Apr 15, 2014 3:05 PM (in response to CWLMedia)Hi all,
So I see the team have been lacking in providing answers to many of the questions here on the forum over the past week - probably not helped by the forums all going down for maintenance for a few days...
But it's been a week now and I STILL can't publish my websites so I'm starting to get a bit antsy - as are clients! This is kinda becoming a big problem for me now...
Any chance someone could take a look at this issue and advise? I mean, this is a pretty big one since at the moment I can't actually do what the software's supposed to enable me to do! :P
Any and all help is as always appreciated.
Thanks.
2. Re: Can no longer publish after latest Muse update (April 2nd 2014)
Zak Williamson (Adobe) Apr 15, 2014 8:42 PM (in response to CWLMedia)What's the complete filename of a file the Publish hangs on?
Is it hanging on the first flie to be uploaded, or have some files been successfully uploaded prior to the hang?
What's the total number of files Muse reports it will be uploading?
If you wait a full 60+ seconds at the point it's hung, does a dialog appear with a "Resume" button? If you click "Resume" does the Publish process proceed and upload additional files?
The "BC site has changed" behavior is a side effect of the half completed publish. Once you've had a successful publish it will go away.
3. Re: Can no longer publish after latest Muse update (April 2nd 2014)
CWLMedia Apr 16, 2014 4:48 AM (in response to Zak Williamson (Adobe))Hi Zak, thanks for the reply.
The filename is whatever is set to be the background fill of the site (I presume the desktop background fill, if mobile versions are set to be different). I've tried a number of different files, sizes and types/formats and the result is still the same, so as far as I can tell it's not the file itself causing the issue...
It uploads all pages (desktop, tablet and phone versions), .css files and .html files, and even the favicon .ico file but then hangs on the first image file, which incidentally is the background fill image.
The total number of files is said to be 154. It gets stuck on file number 24.
Yes the "Resume" dialog appears and upon clicking it just attempts to continue from the hang at the first image file (apparently 66% of the way through).
Re: the "BC site has changed" part - I thought as much but figured worth reporting.
... Incidentally, as I've written this reply, I left the "Resume" dialog open (ie neither clicking "resume" or "cancel" and just as I've finished typing it appears to have published the site successfully?!! (I must've left it for roughly 5 minutes)
Bizarre behaviour... I'm not sure if this will repeat itself with other sites but I'm sure there's a bug here that needs looking at regardless...?!Any thoughts?
