This content has been marked as final.
Show 1 reply
1. Re: How do I delete "AppHelp (Default) - Index"?
Captiv8r Apr 7, 2014 8:21 PM (in response to Pete Thayer)Hi there
To sort the index, right click inside the index and you should see an option to sort.
As far as deleting, you likely are trying to delete the Index file nominated as the Default. If your goal is to delete this file, right-click the other one and try setting it as Default. Once you do that you should see the Delete option is now available. But it should be fairly straightforward to just select an index term and press and hold the Delete key to rapidly delete terms.
Cheers... Rick
