2 Replies Latest reply on Nov 1, 2014 3:23 PM by desistx
    Fonts not available within InDesign
    RJames
      I have recently been updated to CC. Upon opening an InDesign file I am prompted to find a missing font (Lucida Sans OTF - Oblique).
      In the past this has been rather simple, but now the required font is not provided in the drop-down list. However, the font is provided in Illustrator.
      How do I go about loading in this font? It used to be so simple.
      Note: Lucida Sans OTF Roman & Demibold Roman are still available and have opened fine.
      Ross
        • 1. Re: Fonts not available within InDesign
          Migintosh Level 4
          If you go to your applications folder and find the InDesign and Illustrator folders, you will see a Fonts folder in each. If you place fonts into these folders, they will be available to that application only. That means that if you put your font in InDesign's Fonts folder, Illustrator won't be able to use it unless a copy is also placed in the Illustrator Fonts folder. You probably had your missing font in the InDesign fonts folder of your previous version. If you still have that version loaded, you will find it there. If you have trashed it, you still have the one in the Illustrator Fonts folder.
          You can use the operating system's fonts folders if you prefer, or a font manager, but I believe the application Fonts folders were intended as a quickie way to use a font without having to modify the OS or envoke a font manager, but you can continue to use it for all of your InDesign fonts if you wish. Other than a font not being active in other programs, I don't know of any downside.
          • 2. Re: Fonts not available within InDesign
            desistx
            I have the same problem. Only the Regular version of some fonts show in the IdCC font chooser, but all other forms are not shown. The font is Skia in this instance (Unique name  Skia; 10.0d4e1; 2014-08-18), but it applies to many others. PhotoshopCC also does not display any form but Regular, nor does IllustratorCC.
            What's up with this?
