4 Replies Latest reply on Apr 8, 2014 11:44 PM by Mylenium
    slider sensitivity
    Arrakis Level 1
      Is there a way to decrease slide sensitivity so as to be able to make fine adjustments?
        • 1. Re: slider sensitivity
          You can hold down the Ctrl and Shift keys to change slider value increment step size.
          Mylenium
          • 2. Re: slider sensitivity
            If you are in the Effects Control Panel you can also right click on a slider name, select Edit and change the minimum and maximum values.
            The visible slider range in this instance of Exposure has been reset from .1 to 1, the default is -4 to 4
            I use this all the time, especially with Expression Controls
            • 3. Re: slider sensitivity
              Arrakis Level 1
              IM trying to make an innfinite zoom effect with the generate fractal effect but when I zoom in to a certain point the mandelbrot x and y sliders are just way too snesitive to get it where  I need it.  I have tried shift/command to restruct the movemnet but its doesnt help. I also edited the values down to values of the slider down to 0.00000001 and - 0.00000001 but its still too sensitive! seems like a pretty useless effect if you cannot make very fine adjustments
              • 4. Re: slider sensitivity
                Why bother? There is any number of free fractal generators out there that can generate much more beautiful fractals and export them as an image sequence...
                Mylenium
