9 Replies Latest reply on Apr 23, 2014 12:09 AM by Trevorׅ
    extract paragraph style name with formating
    hurix@123 Level 1
      All
      kindly help me How to extract ParagraphStyle name with formating to Sample.txt:
      EG:
      Style Name: "Body"
      Font = "15"
      leading = '"18"
      Aligh = "Left"
      etc...
      Regards
      Hurix
      Edit by Dave Saunders: Something is preventing the Reply button from working. I'm hoping this edit will reactivate it.
        • 1. Re: extract paragraph style name with formating
          Dave Saunders Level 4
          OK, that worked.
          Hurix,
          Can you say a little more: which scripting language do you use? How experienced are you?
          When you say "How to extract ParagraphStyle name" what do you mean? Extract from where? I'm guessing the selected text.
          Where do you want Sample.txt to be? On your desktop? In the same folder as your document? What if the document is unsaved?
          Dave
          • 2. Re: extract paragraph style name with formating
            hurix@123 Level 1
            Hi Dave
            I am using JavaScript.
            And my Script is in Below:
            var myStyle = myDoc.paragraphStyles.everyItem().name.join("\n");
            //fso = new ActiveXObject("Scripting.FileSystemObject");
            for(var i= myStyle;i<myStyle.length;i++);
            var filePath = "/Users/hpt/Desktop/In/style.txt";
            var logFile = new File(filePath);
            Paragraph Style Naming Like: "Body text, BL, NL, CT, CN, etc...." I will get separate text file.
            Now am looking for get including with Formatting:
            Eg: Body Text, Font:Minion, Face:Bold, Size:15, Leading:18, etc...
            it is possible,
            Just like export snippets.
            Hurix
            • 3. Re: extract paragraph style name with formating
              Yes, you can do what you want. But your sample has a couple of problems:
              1. Because you joined all the paragraph styles together into a single string, you can use its length to control the for loop. The length of a string is the number of characters in the string.
              2. You only need to create the file once, so do it before the for-loop.
              3. You need to enclose the content of the for-loop in braces.
              I have the impression you want to work this out for your self rather than just have someone write a script for you, so here's how I'd go about it:
              1. I'd make use of JavaScript's toSource() feature to get the values into a string for writing to the file.
              2. But, myParagraphStyle.toSource() produces too much information.
              3. So, I'd create a new object with just the properties of interest and populate that from each paragraph style then use toSource to write that to the file.
              Hope this helps.
              Dave
              • 4. Re: extract paragraph style name with formating
                hurix@123 Level 1
                Thank you Dave
                As per your above guidance i make an effort in my Javscript File. But it shows undefine is not an object.
                "if(myStyle.properties.toSource()){
                for loop
                can you please suggest me
                hurix
                • 5. Re: extract paragraph style name with formating
                  I have appointments for the rest of the morning so I won't be able to help until this afternoon at the earliest (I'm in New Jersey).
                  Dave
                  • 6. Re: extract paragraph style name with formating
                    Trevorׅ Adobe Community Professional
                    Hi all,
                    This is something I threw together
                    doc = app.activeDocument,
                    ps = doc.paragraphStyles.everyItem().getElements().slice(0),
                    l = ps.length,
                    paraStyles = [],
                    c = 0;
                    while (l--) {
                        var styleDetails = [], n = 0, s, x, p, q;
                        s = ps[l].properties;
                        for (x in s) {
                            p = (s[x] && s[x].hasOwnProperty ("name")) ? s[x].name : s[x]; // change according to requirements.
                            if (p && p.constructor.name == "String") p = '"' + p +'"'; // ok if the sctring doesn't contain a " mark
                            else if (x == "tabList") p = getTabList (s[x]);
                            else if (p instanceof Object && p.constructor.name != "Enumerator") {
                                var objProps = [], z = 0;
                                for (q in p) objProps[z++] = q + ": " + p[q]
                                p = x + " {" + objProps.join(", ") + "}";
                            styleDetails[n++] = x + ": " + p;
                        paraStyles[c++] = "{" + styleDetails.join(", ") + "}";
                    temp = new File (Folder (Folder.temp) + "/" + doc.name + " Paragraph Style Properties  " + ("" + new Date).replace(/:/g,"\xB7").replace(/\s\S+$/,"")+ ".txt");
                    temp.encoding = "UTF-8";
                    temp.lineFeed = ($.os[0]=="M") ? "Macintosh" :" Windows";
                    temp.open('w');
                    temp.write("\uFEFF" + paraStyles.join("\r"));
                    temp.close();
                    $.sleep(300);
                    temp.execute(true);
                    function getTabList (t) {
                        var tl = t.length, n, pTabList = [];
                        for (n = 0; n < tl; n++) { // if the leader etc. contains a " then you have to use ' instead of "
                            pTabList[n] = "({alignment: " + t[n].alignment + ', alignmentCharacter: "' + t[n].alignmentCharacter + '", leader: "' +t[n].leader +  '", position: ' + t[n].position + "})";
                        return "[" + pTabList.join(", ") + "]";
                    function getGrepList (g) { // nestedGrepStyles
                        return // couldn't be bothered to do this one, sorry
                        var tl = g.length, n, pnestedGrepList = [];
                            // pTabList[n] = figure for yourself
                    You can then recreate the styles by splitting the string by "\r" and using doScript or Eval.
                    Might be better to produce a tagged doc with <alignment> foo </alignment> type structure to get around quotation porblems
                    However for a simple import export snippet wouldn't this be better?
                    var doc = app.activeDocument,
                          newDoc = app.documents.add(),
                          fp;
                    // if you need to add function to remove app.styles that are automatically added to the new document
                    fp = new File (Folder.temp + "/" + +new Date + ".indd")
                    doc.saveACopy (fp);
                    $.sleep (500);
                    newDoc.importStyles (ImportFormat.TEXT_STYLES_FORMAT, fp); // can add all sorts of things to import or load
                    fp.remove();
                    // You now have a clean new Document to load the styles from using importStyles
                    Trevor
                    • 7. Re: extract paragraph style name with formating
                      Another possibility generate a tagged txt file.
                      Probably the best and easiest method.  The styles will be ready to regenerate when needed.
                      app.doScript("exportParaStyleData ()", ScriptLanguage.JAVASCRIPT, undefined, UndoModes.FAST_ENTIRE_SCRIPT, "exportParaStyleData");
                      function exportParaStyleData() {
                                newPage = doc.pages.add(),
                                paraStyles = doc.paragraphStyles.everyItem().getElements().slice(0),
                                l = paraStyles.length,
                                tf = newPage.textFrames.add({geometricBounds: newPage.bounds, contents: new Array(l+1).join("\r")}),
                                f = new File (Folder.temp + "/" + +new Date + ".txt") /*change as needed*/;
                          while (l--) tf.characters[l].appliedParagraphStyle = paraStyles[l];
                          app.taggedTextExportPreferences.properties = {characterSet: TagTextExportCharacterSet.ASCII /*change as needed*/, tagForm: TagTextForm.VERBOSE};
                          tf.texts[0].exportFile (ExportFormat.TAGGED_TEXT, f, false);
                          newPage.remove();
                          f.execute();
                      Sample Result, quite neat
                      <ASCII-WIN>
                      <Version:9.2><FeatureSet:InDesign-R2L><ColorTable:=<Black:COLOR:CMYK:Process:0,0,0,1><C\=15 M\=100 Y\=100 K\=0:COLOR:CMYK:Process:0.15,1,1,0>>
                      <DefineCharStyle:Character Style 1=<Nextstyle:Character Style 1><cTypeface:Regular><cFont:Action Jackson>>
                      <DefineParaStyle:NormalParagraphStyle=<Nextstyle:NormalParagraphStyle>>
                      <DefineParaStyle:Page Numbers=<Nextstyle:Page Numbers><cSize:6.500000><pTextComposer:HL Single><pLeftIndent:5.112000><pRightIndent:5.112000><cLeading:7.475000><pBreakBefore:Column><pTextAlignment:Center><bnColor:None><numFont:\<TextFont\>><cHindiDigits:Arabic>>
                      <DefineParaStyle:fred=<Nextstyle:fred><cLanguage:English\: UK><pTabRuler:52\,Center\,.\,0\,3\;112\,Center\,.\,0\,\;190\,Left\,.\,0\,\;><cFont:Minion Pro><pRunInGrepStyles:Character Style 1\,\\d\+\"\[\"\]\;><bnListType:Bullet>>
                      <DefineParaStyle:Paragraph Style 1=<BasedOn:fred><Nextstyle:Paragraph Style 1><cColor:C\=15 M\=100 Y\=100 K\=0><cColorTint:100.000000>>
                      <ParaStyle:>
                      <ParaStyle:NormalParagraphStyle>
                      Trevor
                      P.s. Let us know what you went for, I would go for the tagged one
                      • 8. Re: extract paragraph style name with formating
                        hurix@123 Level 1
                        Thanks for your reply
                        It Works, But i need to generate selected elements only,
                        Like: Style Name, Font, size, Space Before and After, etc.
                        Hurix
                        • 9. Re: extract paragraph style name with formating
                          Hi Hurix,
                          Welcome back.
                          Please mark the the question as answered
                          Add the properties you need as instructed in the 3rd line.
                          Trevor
                          // Export Specified Details of Documents ParagraphStyles By Trevor
                          // http://forums.adobe.com/thread/1445961?tstart=0
                          exportParagraphStyleDetails ("appliedFont pointSize spaceAfter spaceBefore"); // add property names separated by a space - The Style Name is included automatically
                          // see http://jongware.mit.edu/idcs6js/pc_ParagraphStyle.html for a list of properties you can add
                          function exportParagraphStyleDetails (props /* A string list of the desired properties */) {
                              l = ps.length,
                              c = 0;
                              props = props.replace(/\s+/g, " ").split(" ");
                              pl = props.length;
                                  var styleDetails = [];
                              while (l--) {
                                  var  myStyle = ps[l];
                                  styleDetails[c++] = "******************************************************************\rParagraph Style Name: " + myStyle.name + "\r******************************************************************"
                                  for (var n = 0; n < pl; n++) {
                                      styleDetails[c] = props[n] + ": " + myStyle[props[n]].toString();
                                      if (myStyle[props[n]].hasOwnProperty ("name")) styleDetails[c] = styleDetails[c].replace (/:.+/, ".name: " + myStyle[props[n]].name);
                                      c++;
                              styleDetails[c++] = "\r";
                              temp = new File (Folder (Folder.temp) + "/" + doc.name + " Paragraph Style Properties " + ("" + new Date).replace(/:/g,"\xB7").replace(/G\S+$/,"")+ ".txt");
                              temp.open('w');
                              temp.write("\uFEFF" + styleDetails.join("\r"));
                              temp.close();
                              $.sleep(300);
                              temp.execute();
