2 Replies Latest reply on Apr 25, 2014 2:03 PM by Zaxist
    Pass variables in symbols to function
    nicholaslue Level 1
      I'd appreciate some quick help on how to pass a variable I set in a symbol to a function in the compositionReady code.
      Right now for each button in a menu I have the code:
      case 'item1':
      sym.getComposition().getStage().clearStage();  //this is a function in compositionReady
      sym.getComposition().getStage().getSymbol("object_details").$("item1").show();
      sym.getComposition().getStage().getSymbol("object_details").getSymbol("item1").play(0);
      break;
      here is the code in compositionReady:
      sym.clearStage = function() {
      sym.getComposition().getStage().$("grid").hide();
      sym.getComposition().getStage().$("othermaps").hide();
      Is there a way to pass the value 'item1' to the function so that I'm not writing the same code over and over?
      Thus:
      case 'item1':
      sym.getComposition().getStage().clearStage("item1");
      break;
      and in compositionReady:
      sym.clearStage = function(itemValue) {
      sym.getComposition().getStage().getSymbol("object_details").$(itemValue).show();
      sym.getComposition().getStage().getSymbol("object_details").getSymbol(itemValue).play(0);
      I know my syntax is totally wrong.  Please help me to see this.  Thank you.
        • 1. Re: Pass variables in symbols to function
          TimJaramillo Level 4
          Your syntax for passing the parameter via the function call, and receiving it in the actual function seems fine.
          One note: I'm assuming when copy/pasting youre code for this thread, you left out the 'switch', in your 'switch/case' code? But it's actually there in your code?
          • 2. Re: Pass variables in symbols to function
            Zaxist Level 4
            this way you can make your codes much shorter :
            case 'item1':
            x.clearStage("item1");
            break;
            //and in compositionReady:
            Stage = sym.getComposition().getStage()
            x = {
            clearStage:function(z){
            Stage.$("grid").hide();
            Stage.$("othermaps").hide();
            Stage.getSymbol("object_details").$(z).show();
            Stage.getSymbol("object_details").getSymbol(z).play(0);
            regards
            Zaxist
