When matching two shots from interviews done in the same room at two points in the day, the resulting "correction" is hideous! It almost looks like a negative - all blacks are replaced with pink and orange, there's a lot of noise. What could be causing this? How can it be fixed? The differences in the shots aren't things that I'd think would cause these errors - slightly different temperature, different interview subjects with different clothes. Same wide open white loft space. Any advice would be very much appreciated!
Thanks for your help,
Douglas
My guess is that it's just not a perfect feature. You may have to do the work manually.
