5 Replies Latest reply on Apr 8, 2014 3:46 PM by Jim_Simon
    Plugin development for premiere, adobe example  error LNK1104: cannot open file 'C:\Program Files\Ad
    Alex B Martin
      Hello,
      I downloaded the Premiere Pro CS 5.5 Win SDK, i open the project SDK_Exporter in Visual Studio 2008, when i hit debug i get the following error
      Error1fatal error LNK1104: cannot open file 'C:\Program Files\Adobe\Common\Plug-ins\CS6\MediaCore\ExporterSDK.prm'
      How can i resolve ?
        • 1. Re: Plugin development for premiere, adobe example  error LNK1104: cannot open file 'C:\Program Files\Ad
          Alex B Martin Level 1
          BuildLog.htm
          Build Log
          Build started: Project: SDK_Exporter, Configuration: Debug|x64
          Command Lines
          Creating temporary file "c:\PRODUCCION\cinemartin\Cinec\Premiere Pro CS5.5 Win SDK\Examples\Projects\SDK_Exporter\x64\Debug\RSP00000A1093610836.rsp" with contents
          /OUT:"C:\Program Files\Adobe\Common\Plug-ins\CS6\MediaCore\ExporterSDK.prm" /INCREMENTAL /DLL /MANIFEST /MANIFESTFILE:"x64\Debug\ExporterSDK.prm.intermediate.manifest" /MANIFESTUAC:"level='asInvoker' uiAccess='false'" /DEBUG /PDB:".\Debug/SDK_File_Compiler.pdb" /SUBSYSTEM:WINDOWS /DYNAMICBASE:NO /IMPLIB:".\Debug/SDK_File_Compiler.lib" /MACHINE:X64 vfw32.lib msacm32.lib winmm.lib comctl32.lib kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib
          ".\Debug\SDK_File.obj"
          ".\Debug\SDK_Segment_Utils.obj"
          ".\x64\Debug\SDK_Exporter.res"
          ".\Debug\SDK_Exporter.obj"
          ".\Debug\SDK_Exporter_Params.obj"
          ".\x64\Debug\ExporterSDK.prm.embed.manifest.res"
          Creating command line "link.exe @"c:\PRODUCCION\cinemartin\Cinec\Premiere Pro CS5.5 Win SDK\Examples\Projects\SDK_Exporter\x64\Debug\RSP00000A1093610836.rsp" /NOLOGO /ERRORREPORT:PROMPT"
          Output Window
          Linking...
          LINK : cannot create map for .ILK file; linking nonincrementally
          LINK : fatal error LNK1104: cannot open file 'C:\Program Files\Adobe\Common\Plug-ins\CS6\MediaCore\ExporterSDK.prm'
          Results
          Build log was saved at "file://c:\PRODUCCION\cinemartin\Cinec\Premiere Pro CS5.5 Win SDK\Examples\Projects\SDK_Exporter\x64\Debug\BuildLog.htm"
          SDK_Exporter - 1 error(s), 0 warning(s)
          Any solution, any idea why  ?
          • 2. Re: Plugin development for premiere, adobe example  error LNK1104: cannot open file 'C:\Program Files\Ad
            In release mode
            Build Log
            Build started: Project: SDK_Exporter, Configuration: Release|x64
            Command Lines
            Creating temporary file "c:\PRODUCCION\cinemartin\Cinec\Premiere Pro CS5.5 Win SDK\Examples\Projects\SDK_Exporter\x64\Release\RSP00000B109364052.rsp" with contents
            /I "..\..\Headers" /I "..\..\Utils" /D "_WINDLL" /FD /EHsc /MD /Fo"x64\Release\\" /Fd"x64\Release\vc90.pdb" /c /TP ".\SDK_Exporter_Params.cpp"
            ".\SDK_Exporter.cpp"
            "..\..\Utils\SDK_Segment_Utils.cpp"
            "..\..\Utils\SDK_File.cpp"
            Creating command line "cl.exe @"c:\PRODUCCION\cinemartin\Cinec\Premiere Pro CS5.5 Win SDK\Examples\Projects\SDK_Exporter\x64\Release\RSP00000B109364052.rsp" /nologo /errorReport:prompt"
            Creating command line "rc.exe /fo"x64\Release/SDK_Exporter.res" ".\SDK_Exporter.rc""
            Creating temporary file "c:\PRODUCCION\cinemartin\Cinec\Premiere Pro CS5.5 Win SDK\Examples\Projects\SDK_Exporter\x64\Release\RSP00000C109364052.rsp" with contents
            /OUT:"C:\Program Files\Adobe\Common\Plug-ins\CS6\MediaCore\ExporterSDK.prm" /DLL /MANIFEST /MANIFESTFILE:"x64\Release\ExporterSDK.prm.intermediate.manifest" /MANIFESTUAC:"level='asInvoker' uiAccess='false'" /DYNAMICBASE /NXCOMPAT /MACHINE:X64 kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib
            ".\x64\Release\SDK_File.obj"
            ".\x64\Release\SDK_Segment_Utils.obj"
            ".\x64\Release\SDK_Exporter.res"
            ".\x64\Release\SDK_Exporter.obj"
            ".\x64\Release\SDK_Exporter_Params.obj"
            Creating command line "link.exe @"c:\PRODUCCION\cinemartin\Cinec\Premiere Pro CS5.5 Win SDK\Examples\Projects\SDK_Exporter\x64\Release\RSP00000C109364052.rsp" /NOLOGO /ERRORREPORT:PROMPT"
            Output Window
            Compiling...
            SDK_Exporter.cpp
            SDK_File.cpp
            Generating Code...
            Compiling resources...
            Microsoft (R) Windows (R) Resource Compiler Version 6.1.6723.1
            Copyright (C) Microsoft Corporation.  All rights reserved.
            Linking...
            Results
            Build log was saved at "file://c:\PRODUCCION\cinemartin\Cinec\Premiere Pro CS5.5 Win SDK\Examples\Projects\SDK_Exporter\x64\Release\BuildLog.htm"
            Helpp
            • 3. Re: Plugin development for premiere, adobe example  error LNK1104: cannot open file 'C:\Program Files\Ad
              • RESOLVED LOOKING AT THE PAST
                1.Zac Lam,01-dic-2013 10:43   in reply to Alex B MartinReport
                Hi Alex, Are you launching Visual Studio with administrative privileges?  If not, you won’t be able to generate the .aex in certain protected folders because of a Windows security restriction.
                Was this helpful? Yes   No
