1. Re: Frustration: Cannot "edit" Solr collections?
Charlie Arehart Apr 8, 2014 1:52 PM (in response to WolfShade)I don’t know for sure, but have you checked to see if CFCollection (the tag used for creating/managing collections, as an alternative to the Admin) might have more flexibility for you? Worth a check.
/charlie
2. Re: Frustration: Cannot "edit" Solr collections?
WolfShade Apr 8, 2014 2:06 PM (in response to Charlie Arehart)Hi, Charlie,
Thanks for the reply. But CFCOLLECTION can only help if I know what's being indexed. For the Solr collections that we have in production, I personally know what to index in seven of them. Three can be guessed, somewhat. The rest, no one knows what is being indexed (it was never documented, and the developer who originally created them has "moved on to greener pastures".)
^_^
3. Re: Frustration: Cannot "edit" Solr collections?
Lynux Apr 15, 2014 6:54 AM (in response to WolfShade)can you log into the solr server and check the indexes in there?. I know I can login (outside of CF), as i've done it here. Can't recall if if gives you more info, it would I'd imagine.
4. Re: Frustration: Cannot "edit" Solr collections?
WolfShade Apr 15, 2014 7:40 AM (in response to Lynux)Hi, Lynux.
I can do nothing from within CFAdmin that will indicate what is being indexed in any collection. There was a time when you could log in through a port, but that turned into a security issue, so the fix was to disable remoting into that port number, so I can't remotely log in to check, if there is any way of determining what's indexed, that way.
V/r,
^_^
5. Re: Frustration: Cannot "edit" Solr collections?
Lynux Apr 15, 2014 7:50 AM (in response to WolfShade)Strange admins if they need to lock you on on the internal network, normal to firewall external traffic but internet is pointless, its supposed to be a secure network isnt it?, so only "good guys" should be on the network anyway. Sorry I dont think there is anything you can do if its locked down like this.
6. Re: Frustration: Cannot "edit" Solr collections?
WolfShade Apr 15, 2014 8:14 AM (in response to Lynux)I'm running CF on my dev machine, so despite the lockdown, I did some looking around and tried browsing to http://127.0.0.1:8983/solr and got nothing. Then I viewed the jetty.xml file, and it turns out that they switched to port 8985, so I tried that. Success.. I can access the Solr server directly. However, I'm looking around at everything, and I'm not finding anywhere in the Solr admin that will tell me what is being indexed in these Solr collections. If you know where that might be indicated, I might be able to document what collections in production are indexing. (Correction: I can pass that along to the production SA and let him figure it out. )
Thank you,
^_^
7. Re: Frustration: Cannot "edit" Solr collections?
Does anyone know if it's possible to see what is being indexed by looking at the Solr Server admin?
V/r,
^_^
8. Re: Frustration: Cannot "edit" Solr collections?
TangoKilo May 21, 2014 5:45 AM (in response to WolfShade)Hey WolfShade,
Have you found your answer?
If not, have you looked on the Solr admin page under the core you have, look at [stats] and [core] from there... is that what you are after?
I have been dealing with an overzealous security enviornement as well for a long time, it really does make development and reverse engineering much more difficult than it needs to be...
goold luck, TK
