17 Replies Latest reply: Apr 21, 2014 8:17 PM by Joe Riggs RSS
    Premiere CC questions
    Joe Riggs Community Member
      1. Is there a short cut for moving clips up and down between tracks ala FCP7? if you have to set it up mnually what's the command called in the keyboard shortcuts window?
      2. Is there a way to change the timecode on a sequence timeline, so for example you want it to start at 00:01:00:00, instead of 00:00:00:00?  In FCP7 you just go to sequence settings and type it in your desired time.
      3. Does match frame work differently in CC? Sometimes I'll select match frame and it will the correct frame but won't have the wrong in and out points selected.
      4. Easiest way to trim and expand JUST the mutlitrack audio connected to a video clip that is up against other video clips with multitrack audio? Just to clarify I want to keep the video as is, just adjust the edit on the audio.  Lock video track?
      5. Short cut to lock tracks?
