1 Reply Latest reply on Apr 10, 2014 1:45 PM by Jim_Simon
    Migrating to a new server
    Pierre Devereux Level 2
      Hi, I posted this message on the AE forum as well, to get the feel from the AE Team around file migration. I would like to ask the Premier Team the same thing:
      Here goes...:
      When we started a few years back, we used an old XP workstation to house a 2TB disk that we used as our Data storage. After a while, (a long while in fact ) The 2TB was filled, and we installed a second 2TB drive. There were now 2 shared drives on the network, each presenting its own file structure. This, in turn, was backed up to external 3TB drives for our backups. Since we started proper, Data has started growing properly as well, and the second 2TB drive is filling up. As a result, the location for backups is no longer sufficient, and we have bought a NAS device and a DAS device. The NAS currently has 4X3TB drives installed, and the DAS has 3X2TB drives installed.
      I would now loke to migrate all the data from the two drives in the old XP machine accroess to the one partition presented by the NAS device. What is the best way to do this, as I am assuming there will be a lot of file location issues with AE when moving its source data around?
      Also, as an aside, I am trying to figure out the best solution for the new devices - I have the following options:
      1) 2X6TB partitions on the NAS device - using JBOD (or spanning)
           a) Use partition 1 as Data source - no redundancy
           b) Use partition 2 as a backup source - either live daily copy-type backups, or Acronis file level backup
      2) 1X6TB partition on the DAS device used as weekly backups (with daily incrementals) - this backup device would be used for roll-back purposes, in case corrupted data gets backed up on the NAS
      The other option, is:
      1) 1X6TB partition on the NAS using RAID1+0 for striping and redundancy.
           a) If a drive fails, we have the oppurtunity to replace it on the fly, and now having a live "Backup" in case of single disk failure (Double, if each disk is part of one mirror set)
      The final option I can think of is:
      1) 1X6TB partition on the NAS using RAID1+0 for striping and redundancy and enabling volume shadow copy for roll'back file recovery
           b) 1X6TB partition on the DAS device used as weekly backups (with daily incrementals) - This will then be an extra backup for complete hardware failure of the NAS device.
      Any suggestions would be welcome - thanks guys
      Pierre Devereux
