6 Replies Latest reply on Apr 10, 2014 5:06 AM by AadMetz
    CC syncing
    AadMetz Newcomer
      I know this is the InDesign section, but the guys of the Creative Cloud section are not not replying.
      http://forums.adobe.com/message/6270889#6270889
      So here my question:
      After the CC update, my CC desktop app is syncen for 1 week.
      How does I solve this problem?
        • 1. Re: CC syncing
          Willi Adelberger Ninja
          What part is not syncen? Fonts? Apps? Files? Behance?
          If it is the files part, take care if all items have compatible names, or go to the ocal and remte file location and delete everything there. (Of course save everything else you need on a different drive.) Some programs (like InDesign) are also sometimes creating incompatible invisible filenames. They have to be deleted. But the user can also make the same mistake.
          If it is the font part, take care that you have not installed a font with the very same name on your local computer. Then you don't need to sync this font from the TypeKit.
          Is it the App part? Then look whichprogram is guilty. Uninstall it with the uninstaller. Quit the CC application. Launch the CC application and install it again.
          • 2. Re: CC syncing
            AadMetz Newcomer
            @Willi: It is file syncing.
            I removed all files in the folder. But it is still syncing:
            • 3. Re: CC syncing
              Did you also remove all files on the remote folder on Adobe's side. Click in FIles (in your Screenshoot in the Bestande-Section on the Button CreativeCloud.com and delete there aafter connection all files which are visible
              • 4. Re: CC syncing
                AadMetz Newcomer
                When I select the tab Bestanden I get this:
                When I click ont the lowest button CreativeCloud.com, I'll linked to the webiste, but that one gives an error.
                When I clikc on the button Map openen, I get the local folder and that one is empty.
                • 5. Re: CC syncing
                  Ok, I don't know why you get the error when you go to CreativeCloud.com. This is the problem. It might be a firewall, some problem in your Internet connection, I don't know. If you can resolve this problem, you have resolved the other problem too.
                  Maybe that you should another browser or go there once from another computer.
                  Folder (Map) open brings you to your local copy, but it is not the problem here.
                  • 6. Re: CC syncing
                    AadMetz Newcomer
                    I get this error (for almost 1 week):
