I've been developing on FlashBuilder4.6 (AIRSDK3.5) now.
Should be changed to 3.5 to 4.0 the AIRSDK me.
However, I have failed in the way until now. (Copy AIRSDK in FLEXSDK)
(Compile I get an error when you create a class of skin)
The procedure, how they are used in FlashBuilder4.7. Wrote.
http://helpx.adobe.com/en/flash-player/release-note/fp_12_air_4_release_notes.html
Of "Authoring Guidelines"
AIR4.0 Would not I use in FlashBuilder4.6?
Please let me know if you find some way to avoid.
I'm sorry .
I was wrong AIRSDK to use. (using the AIRSDK_Compiler.zip downloaded)
I was wrong FLEXSDK to use. (using the flex_sdk_4.6.zip downloaded)
It worked fine if you combine the correct FLEXSDK and AIRSDK.
FLEXSDK: using the "sdks/4.6.0" in FlashBuilder4.6
AIRSDK: using the AdobeAIRSDK.zip download
I could use any AIRSDK4.0 FlashBuilder4.6.
I'm sorry .
