1 Reply Latest reply on Jul 2, 2007 1:24 PM by kazcoling
    FDB question
    fdahfdadf
      I am looking at the docs for the break command to set breakpoints in FDB.
      break [args]
      Sets a breakpoint at the specified line or function. The
      argument can be a line number or function name. With no
      arguments, the break command sets a breakpoint at the
      currently stopped line (not the currently listed line).
      If you specify a line number, fdb breaks at the start of code for
      that line. If you specify a function name, fdb breaks at the
      start of code for that function.
      There does not seem to be support for having the same function name in different files. - Is there a workaround for this?
      For instance if have 2 .mxml files foo.mxml and bar.mxml how can specify that a breakpoint should be set in foo.mxml for function dothis() and not be set in bar.mxml if bar.mxml has a dothis() function also?
      -john
        • 1. Re: FDB question
          kazcoling
          Hi John,
          If you set a current file to the one you would like to set a breakpoint, you should be able to set it to the function even if the same function is used in a multiple files. You can set a current file by 'cf [filename]'.
          Please try it out and let me know if it works.
          Kazue
          Flex Builder QE
          Adobe Systems, Inc.
