• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Problem with CFExecute...
New Here ,
Apr 10, 2014 Apr 10, 2014
I am trying to use cfexecute to run a video conversion application. The application is installed at:
C:\Program Files\SourceTec\vee\vee.exe
The video I want to convert is stored in the temp directory as returned by GetTempDirectory() which in this case is:
C:\ColdFusion9\runtime\servers\coldfusion\SERVER-INF\temp\wwwroot-tmp\
I've tried a wide range of different ways to call this program and whenever it seems like I'm getting close, I get the following error:
Error: Failed to open the source file "C:\ColdFusion9\runtime\bin\vee".
I don't have any files in that directory and am not attempting to access it explicitly but ColdFusion keeps trying to find something in that directory and I don't understand why.
The following code works:
<cfexecute name="C:\Program Files\SourceTec\vee\vee.exe" arguments="vee -v" timeout="300" variable="results"></cfexecute>
...but all it does is display the version number of the video encoder engine: Version: 3.2 (Build 322)
When running this code:
<cfexecute name="C:\Program Files\SourceTec\vee\vee.exe" arguments="vee #GetTempDirectory()#test.avi -i" timeout="300" variable="results" ></cfexecute>
...It should look at the test.avi file in the temp directory and return info about it (-i). Instead, I get the error I mentioned above:
Why is CF looking in C:\ColdFusion9\runtime\bin\vee for a source file?
Views
1.2K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Apr 11, 2014 Apr 11, 2014
Why another 'vee' as argument? I expected something like
<cfset moviePath = GetTempDirectory() & "test.avi">
arguments="#moviePath# -i" timeout="300" variable="results" ></cfexecute>
Votes
Translate
Translate
Guide ,
I don't know if this is your issue, but I've had problems with passing paths with spaces in them.  They need to get wrapped in quotes when passed to the command line, and <cfexecute> doesn't do that by default.  Try changing this:
to this:
<cfexecute name="""C:\Program Files\SourceTec\vee\vee.exe"""
Note that there are a total of three double-quotes before and after the path to the executable.  The outermost are your original name argument quotes, the inner two send an escaped set of quotes into the command line.
HTH,
-Carl V.
Votes
Translate
Translate
Report
Report
New Here ,
Thanks Carl. That is a good tip but sadly it did not resolve the issue. I'm still getting the same error.
Votes
Translate
Translate
Report
Report
Guide ,
Try escaping the arguments= part the same way.
-Carl V.
Votes
Translate
Translate
Report
Report
Community Expert ,
Votes
Translate
Translate
Report
Report
Guide ,
Was wondering that myself...
Votes
Translate
Translate
Report
Report
New Here ,
Apr 14, 2014 Apr 14, 2014
LATEST
I think that was it. Thanks so much. I am now able to get the video info. I still can't do a successful conversion but I don't think it is related to CFExecute. Thank you guys! I really appreciate it.
Votes
Translate
Translate
Report
Report
Resources
Documentation
