9 Replies Latest reply on Apr 13, 2014 10:25 PM by zamvil
    How to get a zip file from webservice
    zamvil
      I'm trying to get a zip file from a NET web service but I get this error:
      Cannot perform web service invocation GetPolicy.
      The fault returned when invoking the web service operation is:
      org.apache.axis2.AxisFault: Must Understand check failed for header http://tempuri.org/ : FileName at org.apache.axis2.engine.AxisEngine.checkMustUnderstand(AxisEngine.java:105) at org.apache.axis2.engine.AxisEngine.receive(AxisEngine.java:171) at org.apache.axis2.description.OutInAxisOperationClient.handleResponse(OutInAxisOperation.java:364) at org.apache.axis2.description.OutInAxisOperationClient.send(OutInAxisOperation.java:421) at org.apache.axis2.description.OutInAxisOperationClient.executeImpl(OutInAxisOperation.java:229) at org.apache.axis2.client.OperationClient.execute(OperationClient.java:165) at org.tempuri.EmissionServiceStub.getPolicy(EmissionServiceStub.java:222) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:601) at coldfusion.xml.rpc.Axis2S... '
      This is my code.
      <cfinvoke webservice = "http://URL.com.mx/IntegrationService/EmissionService.svc?wsdl"
                method = "GetPolicy"
                returnvariable="aString" >
              <cfinvokeargument name="clave" value="ABCR2O14"/>
              <cfinvokeargument name="producto" value="ABCGUA"/>
              <cfinvokeargument name="llave" value="ABC53D35OUHGX2O14"/>
              <cfinvokeargument name="fileExtension" value="zip"/>
              <cfinvokeargument name="policy" value="001_PRO-RCSED_00000002_01_0"/>
              <cfinvokeargument name="fileName" value="caratula"/>
          </cfinvoke>
      The result must have a binary file I must use the content type "Application/Octet-Stream" and a header "Content-Disposition".
      I don't know if I have to use CFHTTP for get the file.
      Any recomendation?
        • 1. Re: How to get a zip file from webservice
          BKBK Adobe Community Professional & MVP
          Going by the error message, we may send fileName as a header , and include the header mustUnderstand (having just found out cfhttpparam wont accept mustUnderstand as attribute). Something like this:
          <cfhttp url="http://URL.com.mx/IntegrationService/EmissionService.svc?wsdl" method="post" path="C:\temp" file="my_saved_file.zip">
              <cfhttpparam type="header" name="fileName" value="caratula">
              <cfhttpparam type="header" name="mustUnderstand" value="true">
              <cfhttpparam name="clave" value="ABCR2O14">
              <cfhttpparam name="producto" value="ABCGUA">
              <cfhttpparam name="llave" value="ABC53D35OUHGX2O14">
              <cfhttpparam name="fileExtension" value="zip">
              <cfhttpparam name="policy" value="001_PRO-RCSED_00000002_01_0">
          </cfhttp>
          <cfheader name="Content-Disposition" value="attachment; filename=my_saved_file.zip">
          <cfcontent type="application/octet-stream" file = "C:\temp\my_saved_file.zip" deleteFile = "no">
          Message was edited by: BKBK
          • 2. Re: How to get a zip file from webservice
            zamvil Level 1
            Thanks BKBK.
            And how can I tell to the cfhttp that I want to use the GetPolicy method from the webservice?
            Is it correct that in the parameters that I need to send put type="formField" because is required in the cfhttpparman and you missed.
            Like this:
            <cfhttpparam type="formField" name="clave" value="ABCGU4R2O14">
            I already run but the zip file is empty.
            • 3. Re: How to get a zip file from webservice
              Yes, add type="formfield". I also think you may add the method as the parameter
              <cfhttpparam type="formField" name="method" value="GetPolicy">
              • 4. Re: How to get a zip file from webservice
                zamvil Level 1
                I still receive an empty zip file.
                I looking for and trying from a SOAP request.
                Thanks.
                • 5. Re: How to get a zip file from webservice
                  zamvil Level 1
                  I dumped the cfhhtp and this is
                  struct
                  Charset[empty string]
                  ErrorDetail[empty string]
                  FilecontentA CFHttp.Filecontent variable is not created if a file path is specified.
                  HeaderHTTP/1.1 415 Cannot process the message because the content type 'application/x-www-form-urlencoded' was not the expected type 'text/xml; charset=utf-8'. Connection: close Date: Sun, 13 Apr 2014 16:24:28 GMT Server: Microsoft-IIS/6.0 X-Powered-By: ASP.NET X-AspNet-Version: 2.0.50727 Cache-Control: private Content-Length: 0
                  MimetypeUnable to determine MIME type of file.
                  Responseheader
                  struct
                  Cache-Controlprivate
                  Connectionclose
                  Content-Length0
                  DateSun, 13 Apr 2014 16:24:28 GMT
                  ExplanationCannot process the message because the content type 'application/x-www-form-urlencoded' was not the expected type 'text/xml; charset=utf-8'.
                  Http_VersionHTTP/1.1
                  ServerMicrosoft-IIS/6.0
                  Status_Code415
                  X-AspNet-Version2.0.50727
                  X-Powered-ByASP.NET
                  Statuscode415 Cannot process the message because the content type 'application/x-www-form-urlencoded' was not the expected type 'text/xml; charset=utf-8'.
                  TextYES
                  • 6. Re: How to get a zip file from webservice
                    Statuscode     415 Cannot process the message because the content type 'application/x-www-form-urlencoded' was not the expected type 'text/xml; charset=utf-8'.
                    That suggests to me that the service expects you to make a SOAP call. You could do something like this, substituting somevar1, someVar2 and someDomain for the relevant values:
                    <!--- SOAP message to send to Web Service--->
                    <cfsavecontent variable="msg"><?xml version="1.0" encoding="UTF-8" ?>
                        <soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
                         <soapenv:Body>
                         <tns:someVar1 soapenv:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:tns="http://www.someDomain.com/services/soap/">
                                <fileName      xsi:type="xsd:string">caratula</fileName>
                                <clave         xsi:type="xsd:string">ABCR2O14</clave>
                                <producto      xsi:type="xsd:string">ABCGUA</producto>
                                <llave         xsi:type="xsd:string">ABC53D35OUHGX2O14</llave>
                                <fileExtension xsi:type="xsd:string">zip</fileExtension>
                                <policy        xsi:type="xsd:string">001_PRO-RCSED_00000002_01_0</policy>
                          </tns:someVar1>
                          </soapenv:Body>
                          </soapenv:Envelope>
                    </cfsavecontent>
                    <!--- Invoke web service and send message--->
                        <cfhttpparam type="header" name="content-type" value="text/xml">
                        <cfhttpparam type="header" name="SOAPAction" value="">
                        <cfhttpparam type="header" name="content-length" value="#len(msg)#">
                        <cfhttpparam type="header" name="charset" value="utf-8">
                        <cfhttpparam type="xml"    name="someVar2" value="#trim(msg)#">
                    </cfhttp>
                    <!--- Web Service response --->
                    • 7. Re: How to get a zip file from webservice
                      zamvil Level 1
                      Thanks.
                      I already did the SOAP Request and it was Ok.
                      And this was the response
                      Statuscode200 OK
                      Filecontent<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/"><s:Header><h:FileName s:mustUnderstand="1" xmlns:h="http://tempuri.org/">001_PRO-RCSED_00000002_01_0-CaratulaDA.zip</h:FileName><h:Length s:mustUnderstand="1" xmlns:h="http://tempuri.org/">112484</h:Length><h:errors s:mustUnderstand="1" i:nil="true" xmlns:h="http://tempuri.org/" xmlns:i="http://www.w3.org/2001/XMLSchema-instance"/></s:Header><s:Body><RemoteFileInfo xmlns="http://tempuri.org/"><FileByteStream>UEsDBBQAAAAIAByLUNhcmF0dWxhREEucGRmCgAgAAAAAAABABgAbu9TA5AO9Ryux9+LErXhD t8BxP81lr5/4yNXHjA38qnTbZ0aJXizRXs0ErmRXXFYVNwblS1j7CxzbOIjgG</FileByteStream></RemoteFile Info></s:Body></s:Envelope>
                      And so know, I need to transform the FileByteStream to a file.
                      • 8. Re: How to get a zip file from webservice
                        zamvil Level 1
                        I already parse the XML response and get the fileByteStream
                        <cfset soapResponse = xmlParse(trim(httpResponse.fileContent)) />
                        <cfset results = xmlSearch(soapResponse,"//*[local-name()='FileByteStream']") />
                        <cfset filebyteS = results[1].xmltext />
                        Do you know how can I tranform the fileByteStream to a file?
                        • 9. Re: How to get a zip file from webservice
                          zamvil Level 1
                          Yesssss ....I have the solution.
                          <cfcontent type="application/octet-stream" variable="#ToBinary(results[1].xmltext)#">
                          Finally I have the ZIP file!
                          For to make the XML SOAP Request I used the SOAPUI Aplication. It make me the XML and send as a parameter.
                          Thanks BKBK
