7 Replies Latest reply on Apr 11, 2014 4:19 AM by Trevorׅ
    Select item(s) in layer
    AsOne Level 1
      Hi all,
      How do I select Item(s) in specific layer name
      my code is
      var layer=app.activeDocument.layers.everyItem().getElements("Info Layer");
      can any one correct this, help will be appreciate
      Steve
        • 1. Re: Select item(s) in layer
          Sajeev Sridharan Level 4
          myObject = app.documents[0].pageItems;
          for (var i=0; i <myObject.length; i++)
              if(myObject[i].itemLayer.name=="Info Layer")
                  myObject[i].select();
          Vandy
          • 2. Re: Select item(s) in layer
            Trevorׅ Adobe Community Professional
            Hi Steve & Vandy
            No need to do a loop
            Turn all Items yellow
            app.activeDocument.layers.itemByName("Layer 1").pageItems.everyItem().fillColor = "Yellow"
            Get Elements
            myLayersItems = app.activeDocument.layers.itemByName("Layer 1").pageItems.everyItem().getElements()
            Trevor
            • 3. Re: Select item(s) in layer
              csm_phil Level 4
              Hi Steve,
              Please try the below JS code, I just alernate the vandy method.
              var mylayer = myDoc.layers.itemByName("Layer 2");
              for (var i=0; i <mylayer.allPageItems.length; i++){
                      mylayer.allPageItems[i].select();
              thx,
              csm_phil
              • 4. Re: Select item(s) in layer
                csm_phil Level 4
                HI Trevor,
                I have a doubt with the below js lines, If steve want to move the particular layer page items. In this case the below lines not working, So we have to loop it? Because he request to select the particular layer page items. so that, vandy loop the page items right!
                Get Elements
                thx,
                csm_phil
                • 5. Re: Select item(s) in layer
                  Sorry Phil, I don't agree with you on this.
                  There is very rarely a case for "Selecting" an object,
                  To move the all the items to another layer one would just use
                  app.activeDocument.layers.itemByName("Layer 1").pageItems.everyItem().move(app.activeDocument.layers.itemByName("Layer 2"))
                  Trevor
                  • 6. Re: Select item(s) in layer
                    Dave Saunders Level 4
                    Let's just clarify that Trevor's examples work only if the active document has layers with the exact names he's using in his sample code.
                    Dave
                    • 7. Re: Select item(s) in layer
                      But with a limited amount of imagination it can be quite easily adapted
