2 Replies Latest reply on Apr 12, 2014 3:44 AM by LeftHead
    Label each item and select
    Unique Level 1
      Hi forum,
      I have a document, which has 3 logos (created in indesign and outlined)  .contentType == ContentType.UNASSIGNED.
      I want to select 3 outlined logos individually and resize it... I could only able to select the first two and lable it, when the script is in forward loop...
      bW ();
      function bW () {
      myGroup = app.documents[0].pageItems.everyItem().getElements();
      for (i=0; i<myGroup.length; i++) {
      //myGroupItems = myGroup.pageItems.everyItem();
      if (myGroup[i].fillColor.name == "Paper" &&
      myGroup[i].contentType == ContentType.UNASSIGNED) {
          app.select(myGroup[i])
          burWhite = app.selection;
      //    app.selection = null;
          //app.select(burWhite);
      or
      can able to select the last two when reverse loop..
      bW ();
      function bW () {
      if(myGroup.length>0) {
      for(var i=myGroup.length-1;i>=0;i--){
      burWhite3 = app.selection[0];
      app.select(burWhite3);
      However when resized they all resized in same size, instead of different sizes...
        • 1. Re: Label each item and select
          LeftHead Level 1
          Hi Unique,
          Don't exactly understand the goal and the problem.
          You have same size logos and want the result to be your image (different sizes) ? Of the opposite (different sizes to same size) ?
          • 2. Re: Label each item and select
            LeftHead Level 1
            If it's same size logos to different size logos, something like this should work:
            bW ();
            function bW () {
                var myGroup = app.documents[0].pageItems.everyItem().getElements();
                for (var i=0; i<myGroup.length; i++) {
                    if (myGroup[i].fillColor.name == "Paper" && myGroup[i].contentType == ContentType.UNASSIGNED) {
                        myGroup[i].horizontalScale =  myGroup[i].verticalScale = 100 - (i * 25);
