8 Replies Latest reply on Mar 4, 2015 9:59 AM by charliez57575821
    Question on merge with background function
    Joseph_McDonald Level 1
      Hello, I was wondering if anyone can tell me when it is useful to use the merge with background function.  I did not see anything in the documentation about it. It seems to me that you can just do your edits on the master slide, and you would not need the feature.  If I am misunderstanding please let me know, thanks.
        • 1. Re: Question on merge with background function
          Lilybiri MVP & Adobe Community Professional
          Hello,
          Not sure to be complete here, just my ideas. If you merge objects with the background on a master slide, you'll save on file size because the background will be one image, compared to several objects. You will not be able to edit those objects anymore. Moreover the background of the master slide will always be behind any object. For master slide objects you can have them either on top, where they'll sit on top of the stack, or not. If you have objects timed for the rest of the project, they'll always be on top of the master slide background, but if you have master slide objects, they'll be on top of the object timed for the rest of the project, unless you put that one also always on top. You can turn off to show master slide objects on normal slides, separately from turning off the master slide background. Just some of my ideas. For objects that I want always to be with the background, I will prefer to merge them. For objects that I don't always want, I'll keep the separately, and that is of course always the case for the interactive shape button that you cannot merge with the background (which is just an image, not interactive).
          Lilybiri
          • 2. Re: Question on merge with background function
            Thank you as always, that is the best summary of the merge feature I've seen.
            • 3. Re: Question on merge with background function
              I'm not sure at all as I mentioned that it is complete, but it is based on my experience (with my exploring attitude). Maybe someone else will pop in to add other ideas.
              • 4. Re: Question on merge with background function
                Hello, just offering one of my own observations here.
                When you use Captivate to record the process of using a software application, you are essentially creating a "stop motion" animation movie. Each slide contains a screen capture that is assigned to be the background image.
                Imagine you are recording a software application that contains sensitive information. Information such as a credit card number, customer ID or anything else that really shouldn't be visible in the output.
                Sure, you could cover it up with something such as a Highlight Box, Image or other item, but if you really wanted to ensure that the "real" information would never be revealed, then you would superimpose an object such as a Highlight Box over the area and tell it to be merged with the background. At that point, the background image has been modified exactly as if you had opened it with Microsoft Paint, Photoshop or other image editing software, erased that area and saved it back out.
                A similar situation would occur if perhaps you had recorded an application and its interface later becomes modified. Perhaps there is a new field, button or other object. So instead of re-recording the actions, you are able to simply capture the image of the modified area, paste it in and precisely align it, then merge it with the background to "bake it in" and make it permanent.
                Cheers... Rick
                • 5. Re: Question on merge with background function
                  Thanks for the idea Rick.  I would not have thought of that one myself
                  • 6. Re: Question on merge with background function
                    charliez57575821
                    I have found in Captivate 6 that when merging objects into a recording of software, it works fine... for one object one time. When I want to merge a second object, it seems not to merge into the movie as background but into the slide background behind the movie, effectively disappearing.
                    • 7. Re: Question on merge with background function
                      Whatever the background image is should contain what you merged. This would mean that you have objects on the slide that are essentially covering that area of the slide background.
                      • 8. Re: Question on merge with background function
                        charliez57575821 Level 1
                        I have a mask covering an email address that indicates the client name and a menu item just below it that also reveals a location that is associated with the client. But this covers the mouse motion and the highlighting of the menu item. So I want to add a mask that covers the menu item that highlights with a different name than one that indicates who the client is. After that, I have another mask that shows the mouse on top of that menu item just long enough to simulate the click. What it appears is happening in this case is that when I merge the second object into the background, both objects disappear and there is no option I can find to change the layering positions of them before merging. I can't drag them up or down on the timeline and I can not find any way that I am used to seeing to bring one to the front. So then I delete both to try again and delete both objects from the library. Then when I try to import the first object a second time, it just disappears as soon as I merge. The only way I can keep both objects visible is not to merge them with the background, or so it seems. I can make this work but was hoping to minimize the number of layers and graphics I am managing in order to conceal the client's information.
                        Have I corrupted the video clip?
