1 Reply Latest reply on Apr 11, 2014 11:34 AM by WolfShade
    get data from differnt table?
    no_name_123
      I have been looking around all over google and I just can find a good example of a join query
      for what i want to do.
      lets say you have two tables i created for example, from same server.
      create table table_a (employee_id int, stars int);
      insert into table_a values (1, 1);
      insert into table_a values (1, 0);
      insert into table_a values (2, 1);
      insert into table_a values (3, 1);
      create table table_b (employee_id_number int, dept_name varchar(25));
      insert into table_b values (1, 'deptone');
      insert into table_b values (2, 'depttwo');
      insert into table_b values (3, 'deptthree');
      insert into table_b values (4, 'deptfour');
      I want to be able to ouput the max which i have been able to do with this below code:(this doesnt use the tables above)
      <cfquery datasource="Intranet" name="getMaxstars">
                select submitterdept, sum((rating1+rating2+rating3+rating4+rating5)/5)/count(1) average_rating
      from CSEReduxResponses
      group by submitterdept
      order by 2 desc
      </cfquery>
      <cfset average_rating_max = 0>
      <cfoutput query="getMaxstars">
          <cfif average_rating GTE average_rating_max>
              <cfset average_rating_max = average_rating>
          </cfif>
      </cfoutput>
      <cfoutput>#average_rating_max#</cfoutput>
      But i want to use the other table so i can output the dept_name that matches the employee_id MAX number.
      Can anyone help me the best way to do this, i feel really lost,thanks.
        • 1. Re: get data from differnt table?
          WolfShade Level 4
          LEFT OUTER JOIN will get all data from table A and all related data from table B.
          A standard JOIN will only get data that is related between tables.
          <cfquery datasource="dsnName" name="sampleLOJ">
          SELECT a.columnA, a.columnB, b.columnA, b.columnB
          FROM tableA a LEFT OUTER JOIN tableB b ON b.colunnA = a.columnA
          </cfquery>
          This will get all data from tableA and all related data from tableB, where columnA in both are identical.
          <cfquery datasource="dsnName" name="sampleJOIN">
          FROM tableA a JOIN tableB b ON b.colunnA = a.columnA
          </cfquery>
          This will get only the data from tableA and related tableB data that have identical columnA entries.
          ^_^
