1. Re: Help with setting up full width site?
agm 123 Apr 11, 2014 1:02 PM (in response to Picturequest)When you want to create a full sceen effect you have to extend your object/image outside the page size to the
ends of the grey area. See attached image.
Make sure you see the red lines appear on each side of the page when you extend your artwork to the edge.
This effect works for base objects for photos make sure you have "scale to fill" marked when inserting
it in a box.
2. Re: Help with setting up full width site?
Picturequest Apr 11, 2014 1:15 PM (in response to agm 123)The first part worked. Thank you. But regarding the image. I just dragged and dropped it in. It is scalled to both sides as with the black menu bar to the red lines and it says 100% on both sides but it does not preview full screen?
How do I set "scale to fill" if I dragged and dropped or do I need to reimport it a new way?
So create an empty box and place it in there instead? not 100% sure.
3. Re: Help with setting up full width site?
agm 123 Apr 11, 2014 1:38 PM (in response to Picturequest)Create a box first, size the vertical to fit, extend the horizontal to the ends, making sure you see the red keylines, then select the "Fill" dropdown and import your image through there. Select the "Scale to Fill" fitting option.
4. Re: Help with setting up full width site?
Picturequest Apr 11, 2014 2:53 PM (in response to agm 123)That worked. Thanks. So no more drag and drop:-)
