1. Re: 389 pages. Text frames ALL too far to the left, but...
straightlife Apr 11, 2014 3:08 PM (in response to straightlife) -
2. Re: 389 pages. Text frames ALL too far to the left, but...
P Spier Apr 11, 2014 3:21 PM (in response to straightlife)You'll be surprised by how fast you can do 389 pages by snapping to guides.
But it might be worth trying (on a copy) setting up the new page size and set the margin guides to match the current position, then enable layout adjustment, go to the master pages and adjust the margins to the correc values and hoepfully the text frames will move.
3. Re: 389 pages. Text frames ALL too far to the left, but...
straightlife Apr 11, 2014 5:10 PM (in response to P Spier)Peter, text frames didn't move.
How do I find "align to guides?"
4. Re: 389 pages. Text frames ALL too far to the left, but...
P Spier Apr 11, 2014 5:18 PM (in response to straightlife)That was snap tp guides, and that's waht you want to happen whne you move things manually.
But did you start with your margin guides set to where the text frame are now. Even if that's radically incorrect, you want to have the frames snapped to exisiting guides BEFORE you enable Layout adjustment, then you can enable Layout adjustment, and when you correct the margins, the frames SHOULD move to match.
5. Re: 389 pages. Text frames ALL too far to the left, but...
straightlife Apr 11, 2014 5:23 PM (in response to P Spier)Peter, I just want to MOVE the margins. I DON'T want a new page size.
unfortunately, when I move the margins on the master, the margins move, but the text boxes do not.
So, I've figured out how to snap to guides.
Now I've gotta go page by page.
Then I'll move the photos to center in the new margins.
6. Re: 389 pages. Text frames ALL too far to the left, but...
P Spier Apr 11, 2014 5:32 PM (in response to straightlife)You don't need to change the page size.
The way layout adjustment works is that bjcts sanpped to guides will remain snapped to guides when you change the guide positions. This means if layout adjust ment is first DISabled and you reset the margins on your master pages to match where the text frames are now, you can then enable Layout adjustment and rest the margins to new values and the text frames, becasue the are snapped to the old margin guides, will move and even change size if necessary to remain snapped to the new margin guide locations.
7. Re: 389 pages. Text frames ALL too far to the left, but...
straightlife Apr 11, 2014 6:11 PM (in response to P Spier)I'm confused. Are margin guides different from ruler guides. Because I don't know how to snap to margin guides.
8. Re: 389 pages. Text frames ALL too far to the left, but...
straightlife Apr 11, 2014 6:27 PM (in response to straightlife)THANK YOU. So you snap the margins to the ruler guides and, exactly as you explained, everything moves like it should. THANKS THANKS!
