3 Replies Latest reply on Apr 15, 2014 8:09 AM by try67
    How to pass a function with the same argument multiple times and return values in variables?
    MatLac Level 3
      The problem I have is I created a function which really is some kind of database.  Basically a bunch of:
      if (a.value == "this number"){
      b.value = "this expression";
      Inside the form are 2 dropdown lists that return numerical values which I want to process through that function and put the return value inside separate variables.
      var a = this.getField("OPE003.EVEN.1.MIP");
      Mip(a);
      var result1 = Mip();
      I tried to overwriting *a* to process the second field
      a = this.getField("OPE003.EVEN.2.MIP");
      Mip(a);
      var result2 = Mip();
      result1 and result2 are put in an array, joined as a string.
      Doing so, I always get the last processing twice as the final result.
      Can I use a function as a batch processing tool that way?
