1 Reply Latest reply on Dec 9, 2014 3:21 AM by ana_barros
    Map tags to styles (CS6, Applescript)
    Peter Bossens
      I want to map a series of tags to styles in InDesign, but this seems not to work.
      The inverse, mapping styles to tags, works!
      Any idea? Thanks for your help!
      tell application "Adobe InDesign CS6"
                tell active document
        make XML export map with properties {markup tag:"Header", mapped style:"Header"}
        map XML tags to styles
                end tell
      end tell
        • 1. Re: Map tags to styles (CS6, Applescript)
          ana_barros
          Hello, try
              set myDocument to active document
              tell myDocument
                  set tList to name of every XML tag
                  set tNumItems to count of tList
                  -- XML tag to style mapping by name.
                  repeat with j from 1 to tNumItems
                      set tStyle to item j of tList
                      make XML import map with properties {markup tag:tStyle, mapped style:tStyle}
                  end repeat
                  --Map tags to styles.
                  --Map styles to XML tags by name
                      make XML export map with properties {markup tag:tStyle, mapped style:tStyle}
                  end repeat
                  --Map styles to tags.
                  map styles to XML tags
              end tell
              --Export xml para desktop para pasta a designar
                  export to "xxxxxxxxx:aaaaaaaaa.xml" format "XML"
              end tell
          end tell
