1. Re: Core Sync Process Choking Systems
David__B Apr 22, 2014 5:43 PM (in response to J.Hanshaw)Hey J,
Sorry for the delay in responding. Are you still seeing the behavior? Does signing out of the Creative Cloud app and back in again make any difference (Gear icon > Preferences > App tab in the General section)? Can you check the version from the preferences just to ensure you have the latest release 1.5.1.369?
- Dave
2. Re: Core Sync Process Choking Systems
bitknit2 Apr 28, 2014 8:03 PM (in response to J.Hanshaw)I, too, see these processes running. I'm not running Flash, I'm not running Photoshop, why, then, are these processes even running at all? I also force quit them right away, if I'm not planning on running an Adobe product.
How do I make this stuff not run unless *I* want it to?
Upon further investigation, I see that I can run Flash CC and Photoshop CC without Core Sync or Creative Cloud at all. How, then, do I uninstall Creative Cloud and Core Sync? I don't want it on my computer if it has to run on boot every time.
3. Re: Core Sync Process Choking Systems
David__B Apr 30, 2014 5:03 PM (in response to bitknit2)Hi Bitknit2,
Are you using file sync? If so, does the behavior still occur if you pause it?
4. Re: Core Sync Process Choking Systems
mroesele May 27, 2014 8:33 AM (in response to David__B)Experiencing exactly the same very annoying problem on a MacBook Air (Core i7): 100% CPU for no obvious reason. For hours.
Drains my battery very fast, even if there are no changed files.
Does not stop after pausing file synching.
Only solution is to quit the CC application and killing the Core Sync service after that.
Please fix this immediately - otherways I am unable to work with CC files.
5. Re: Core Sync Process Choking Systems
florianbredl May 27, 2014 12:45 PM (in response to J.Hanshaw)Same here on a MacBook Pro. 100% CPU. Does not stop after pausing file synching. Does not stop after restarting the CC App. Only solution is to quit all CC applications and killing the Core Sync service via hand.
6. Re: Core Sync Process Choking Systems
derekajack May 28, 2014 1:42 AM (in response to mroesele)Hi mroesele,
Does this occur file sync or when idle?
If during file sync, how many files are syncing/what size are the files?
What version of Mac OS?
What version of the Creative Cloud Desktop App are you running?
7. Re: Core Sync Process Choking Systems
derekajack May 28, 2014 1:42 AM (in response to florianbredl)Hi florianbredle,
8. Re: Core Sync Process Choking Systems
Warner Harress May 28, 2014 2:56 AM (in response to J.Hanshaw)Hi J.Hanshaw
Could you supply me with your log files, this will help me understand your issue further and help you with a possible work around.
CoreSync Log File location -
Mac - /Library/Application Support/Adobe/CoreSync/CoreSync-yyyy-mm-dd.log
Windows - /users/username/Library/Application Support/Adobe/CoreSync/
If you could email me your log files, harress@adobe.com
Warner
9. Re: Core Sync Process Choking Systems
bitknit2 Jun 1, 2014 2:46 AM (in response to J.Hanshaw)Still no help here.
file sync? what is that? I don't use anything called "file sync"
Here's the scenario.
Boot Mac
No Creative Cloud icons in my tool bar at the top.
No Adobe applications running.
Open Activity Monitor
Notice Creative Cloud and Core Sync processes running, using cycles. - FORCE QUIT THEM.
This is my immediate habit now upon booting my Mac.
I want these applications to not run unless I specifically run those applications myself.
10. Re: Core Sync Process Choking Systems
bitknit2 Jun 1, 2014 3:08 AM (in response to bitknit2)Actually, I had a misunderstanding, and thought that I needed to run Creative Cloud to run Adobe Applications.
My solution was to uninstall Creative Cloud.
I no longer see the processes running when I boot my machine.
I have decided I will not use "cloud" services for my content. I do not believe Adobe can keep it secure, anyway.
11. Re: Core Sync Process Choking Systems
derekajack Jun 2, 2014 7:10 AM (in response to bitknit2)Hi Bitknit2,
as you say, you don't need to run Creative Cloud app to run the Adobe apps, however Creative Cloud app is the mechanism for alerting you of available updates to the Adobe apps, and for downloading these updates.
You can turn File Sync off from the Preferences menu if you choose not to use this feature.
With regards to the issue of high CPU usage, we have identified a resolution and will provide the fix in an update later in June. As my colleague Warner mentioned, we may be able to offer a workaround until then.
It would be great if you could use the File Sync feature and let us know what you think.
12. Re: Core Sync Process Choking Systems
mroesele Jun 3, 2014 3:00 AM (in response to derekajack)Hi derekajack
The problem occurs both idle and while file sync is busy.
In the attached screenshot you can see that file sync is busy at the moment.
But it also occured that file sync said something like "all files up to date" and core sync was still busy doing ... well ... something cpu intensive.
And there is something else which i don't understand. When I browse the cc files folder, there are some folders marked with an exclamation mark but all the containing files seem to be synced properly.
That varies. Most of the time almost no files are being synced - and usually it are a few small css files and web images.
latest available - 10.9.3
latest available - 1.6.0.393
Ah. Maybe it is worth mentioning that my iMac which is still running Mountain Lion does not have the 100% CPU issues.
... and did I mention the CPU temperatue of 94° Celsius and the rapid battery drain?
13. Re: Core Sync Process Choking Systems
mroesele Jun 3, 2014 3:36 AM (in response to mroesele)okay. after 50 minutes the process has finished it's work and claimed that all files have been synced.
now "core sync" process is consuming only 0.2% cpu when sync is idle.
there are also no more exclamation marks in cc files folder (in finder).
after that i created an empty folder which has - of course - been synced in a jiffy.
but now the core sync process is using 100% cpu again since 5 minutes. now in idle mode ("all files up to date")
14. Re: Core Sync Process Choking Systems
derekajack Jun 3, 2014 3:41 AM (in response to mroesele)Hi mroesele,
thanks for the additional info. Would you also be able to send me a copy of your coresync log file? The location of the log file is detailed below -
(On Mac, you need to use the Go To Folder option from the Go option in Finder (menu at the top). Then in the pop up enter:
Then select go, this will take you to the folder containing the .log files.)
Please email this to me directly on djack@adobe.com.
15. Re: Core Sync Process Choking Systems
Waynedge Jun 19, 2014 4:39 AM (in response to J.Hanshaw)I am suffering the same problem on Macbook Air mid 213.
even when i tried reducing the download bandwidth to 25% it seams to have no effect. If core sync starts it consumes the whole cpu...
- Core Sync taking up 100% when syncing files
- causing cpu fan to run at full draining battery at a very high rate
- once sync has started the cpu does not decrease even when sync is paused
- it has to be force quit as a process to stop
I have now disabled syncing of files and now use dropbox as an alternative. Dropbox works very well so i know its a not a fault with my machine. Please can you sort this as its now June and the problem is ongoing
cheers
W.
16. Re: Core Sync Process Choking Systems
Warner Harress Jun 19, 2014 9:31 AM (in response to Waynedge)Hi Waynedge,
Thank you for raising this issue on the forums, we are working hard on performance improvements for Creative Cloud, these improvements will be included in future releases.
A work around for now is to let Creative Cloud work on syncing your data/assets until the full sync job is completed, I understand this may take some time and max out your CPU(s) depending on how many assets you have, after sync is finished you shouldn't see this kind off issue again unless you uninstall Creative Cloud and re install).
I hope this helps.
Warner
17. Re: Core Sync Process Choking Systems
mroesele Jun 24, 2014 3:03 AM (in response to Warner Harress)Will Adobe buy me a replacement if my MacBook Air dies of heat stroke?
CPU is boiling (98° C) since 2 hours again.
18. Re: Core Sync Process Choking Systems
derekajack Jun 24, 2014 3:24 AM (in response to mroesele)Hi mroesele,
I responded to your mail.
Warner has suggested a workaround pending our update, where you allow the assets to complete syncing. It may be in your case it's best to switch off sync until we make the update available.
19. Re: Core Sync Process Choking Systems
mroesele Jun 24, 2014 3:51 AM (in response to derekajack)Thanks for the quick reply. That sounds great. I will wait for the update and see if that helps.
20. Re: Core Sync Process Choking Systems
derekajack Jul 7, 2014 1:26 AM (in response to mroesele)Hi,
the update is now available (version 1.7.0.413).
Please go ahead an update to this version.
It would be great to get your feedback.
21. Re: Core Sync Process Choking Systems
derekajack Jul 7, 2014 1:27 AM (in response to Waynedge)Hi,
just to let you know that the latest version of Creative Cloud Desktop (1.7.0.413) is now available and contains many of the improvements we mentioned.
It would be great to get your feedback on the latest update.
22. Re: Core Sync Process Choking Systems
J.Hanshaw Sep 22, 2014 2:57 PM (in response to derekajack)Hello,
I believe I started this thread, so I apologize for the late response (I'm in the Navy Reserve and was shipped out for five months). I have since read the threads and updated to the latest version of Creative Cloud Desktop (Version 1.7.1.418), but I'm still having the same problem, although it doesn't seem to be as bad. It's on both my iMac and MacBook Pro.
derekajack: I've emailed you the most recent CoreSync log file from my MacBook. Just let me know when you find something out.
Thanks!
J.
